Some Ideas
So i have some ideas how to make it simpler to use pi-hole
  1. on the Webinterface under settings just under the query logging box an box where we can (if there is) update pi-hole over an simple click of the button
  2. right to the 1. button an button to "reset" all ststistics of the pihole (not the password and configs ;-))
  3. an possibility of getting an notification that there is an update
  4. settings where i can turn on autoupdate if i want so
  5. and as last an option to switch between the 24h and the from 00:00 queries graph
    btw there is still the issue that if my timestamp is 24h the queries of today are from these 24h not from 00:00
regards kint
I'm going to close this FR as it contains 5 individual FR and it is hard to follow the implementation on all of them simultaniously.
There are a number of FR out there that wish like to see a update through the web ui, but it is technically impossible:
Please vote here if you support this FR:
This has been implemented. Available updates are shown in the footer of the dashboard.
