Please ensure that you are running the latest version of the beta code. Run pihole -up to update to the latest, then verify that the problem still exists before reporting it.
Problem with Beta 5.0:
Is it possible to add a (safe) function to reset the ftl-statistics? While searching for it I only found a solution by deleting the old database.
An example where this is usefull: Getting a exact view on the summary after deleting or deactivating an upstream-DNS.
Thanks in advance to all of you for the awesome work!
sudo service pihole-FTL stop
sudo sqlite3 /etc/pihole/pihole-FTL.db "DELETE FROM queries WHERE timestamp > (cast(strftime('%s', 'now') as int))-24*60*60"
sudo service pihole-FTL start
This will selectively remove the last 24 hours without destroying the entire database.
I don't agree. This is not a frequently performed task and generally falls into the "edge case" category. Adding code for this occasional use is not warranted, in my opinion.
Flushing logs does flush the long-term database, but only the last 24h. This seems a bit counterintuitive - why does it flush at all (not not just the logs) and why not all data?
Because it involves an FTL restart. And FTL would re-import the history when it would still be in the database. The net effect would be that everything looks to be still there.
Because this was originally meant more in a "I want to hide some things happened recently" way. Very much like browsers offer you to delete the data only partially (without loosing everything). I can see that there may be a need to get both. However, flushing the entirety of the logs can easily be obtained by deleting the database. Flushing it only partially is a bit more involved as you need an SQL instruction.
