Should I use Pi-hole as WAN DNS too?
Hi all,
My LAN dns setting point to Pi-hole:
Should I use Pi-hole in WAN dns settings too, or leave default as follow?:
Thanks
Generally not.
Some routers won't let you use an address which appears on a network they control. Others, will accept the setting, but stop working properly, without displaying an error. Many routers continually ping out to help determine connectivity, and do a DNS test each time.
Your screenshot looks like an Asus or merlin, they fall in the last category.
Its Asus.
When I set pi-hole as wan dns I saw many request from router.
So leave Google dns as wan dns?
Yes, so long as everything else is working with Pi-hole and your network, then it's best to leave the WAN DNS settings be.
This is correct. See also:
