Setting up recursive DNS on a new pi hole
Hey everyone!
I'm moving my pi hole from an old laptop to a container in my proxmox. Furthermore I want to use it as a recursive DNS so I'm setting up unbound. I got the pi hole setup and unbound up and running listening to port 5335 but when I test the dig command:
dig @127.0.0.1 -p 5335 dnssec.works
It fails.
I edited the unbound file /etc/unbound/unbound.conf.d/pi-hole.conf using nano and remove the hashtag so that it is listening to Port 5335.
I verified that unbound is running, I verified that it's listening to the port but the dig command continues to fail. I can ping the address from the container.
Pfsense is my router and configure to push all DNS queries to my current pi hole at a static IP.
I haven't switched over to the new DNS yet but I kind of want to make sure that the dig command is working before I go through the steps of assigning the static IP to the new pi hole container.
Not sure where I missed here would appreciate some insight.
Thanks.
This is my netstats:
@Pi-Hole-New:~# netstat -tuln
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State
tcp        0      0 127.0.0.1:5335          0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN
tcp6       0      0 ::1:25                  :::*                    LISTEN
tcp6       0      0 ::1:4711                :::*                    LISTEN
tcp6       0      0 :::53                   :::*                    LISTEN
tcp6       0      0 :::22                   :::*                    LISTEN
tcp6       0      0 :::80                   :::*                    LISTEN
udp        0      0 127.0.0.1:5335          0.0.0.0:*
udp        0      0 0.0.0.0:53              0.0.0.0:*
udp6       0      0 :::53                   :::*
Something is listening on 5335, most likely unbound.
The guide doesn't have that line commented out to begin with, how did you create that file?
ping won't do much to help with DNS troubleshooting, what is the exact output of your dig commands? Do other DNS queries work, like pi-hole.net and only dnssec.works is failing?
Hey Dan,
All dig commands fail this is the error message:
@Pi-Hole-New:~# dig @127.0.0.1 -p 5335 google.com
;; communications error to 127.0.0.1#5335: timed out
nano /etc/unbound/unbound.conf.d/pi-hole.conf
I got the text from the unbound documentation:
server:
    # logfile: "/var/log/unbound/unbound.log"
    verbosity: 0
    interface: 127.0.0.1
    port: 5335
    do-ip4: yes
    do-udp: yes
    do-tcp: yes
    do-ip6: no
    prefer-ip6: no
    # If you use the default dns-root-data package, unbound will find it automatically
    root-hints: "/var/lib/unbound/root.hints"
    # Trust glue only if it is within the server's authority
    harden-glue: yes
    harden-dnssec-stripped: yes
    use-caps-for-id: no
    # IP fragmentation is unreliable on the Internet today, and can cause
    # transmission failures when large DNS messages are sent via UDP. Even
    # when fragmentation does work, it may not be secure; it is theoretically
    # possible to spoof parts of a fragmented DNS message, without easy
    # detection at the receiving end. Recently, there was an excellent study
    # >>> Defragmenting DNS - Determining the optimal maximum UDP response size for DNS <<<
    # by Axel Koolhaas, and Tjeerd Slokker (https://indico.dns-oarc.net/event/36/contributions/776/)
    # in collaboration with NLnet Labs explored DNS using real world data from the
# the RIPE Atlas probes and the researchers suggested different values for
    # IPv4 and IPv6 and in different scenarios. They advise that servers should
    # be configured to limit DNS messages sent over UDP to a size that will not
    # trigger fragmentation on typical network links. DNS servers can switch
    # from UDP to TCP when a DNS response is too big to fit in this limited
    # buffer size. This value has also been suggested in DNS Flag Day 2020.
    edns-buffer-size: 1232
    prefetch: yes
    # One thread should be sufficient, can be increased on beefy machines. In reality for most users running on small>
    num-threads: 1
    so-rcvbuf: 1m
    private-address: 10.0.0.0/8
    private-address: fd00::/8
    private-address: fe80::/10
Leave this commented out, unless you have manually downloaded the list.
I did manually download it.
What is the output of:
sudo ss -tulpn sport = 5335
It should tell you what process is bound to the port.
How did you install unbound? Did you use the package manager?
Correct I used: apt install unbound
Then comment that line out again and allow the package management to handle the root hints.
@Pi-Hole-New:~# ss -tulpn sport = 5335
Netid    State     Recv-Q    Send-Q       Local Address:Port         Peer Address:Port    Process
udp      UNCONN    0         0                127.0.0.1:5335              0.0.0.0:*        users:(("unbound",pid=605,fd=3))
tcp      LISTEN    0         256              127.0.0.1:5335              0.0.0.0:*        users:(("unbound",pid=605,fd=4))
Still not working. Reading the unbound documentation I think I need to set interface-automatic: <yes or no> to yes. something about changing the listening interface.
Tools > Generate Debug Log
