The issue I am facing:
I am trying to set up pi-hole with no password in Umbrel. Under the app, when you open it, it says to set up without a password to type "sudo pihole -a -p" into the command line. But when ssh into my rpi 4 in umbrel and issue this command, the result is as follows.
icap-NUC11PAHi7:~$ ssh umbrel@umbrel.local
umbrel@umbrel.local's password:
Linux umbrel 5.10.103-v8+ #1529 SMP PREEMPT Tue Mar 8 12:26:46 GMT 2022 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Jul 22 02:03:54 2022 from 10.1.1.111
umbrel@umbrel:~ $ sudo pihole -a -p
[sudo] password for umbrel:
sudo: pihole: command not found
Details about my system:
Pi-Hole app on Umbrel - using rpi4. I can access the app but cannot enter the CL instructions.
