Following on from this topic i am finally getting round to flashing a clean install of Pi-Hole.
My plan is to keep my OG pihole running whilst I flash and setup the new instance.
Reason being my ISP provided router is very lockdown and is a total ball ache to change settings.
So i was planning on using an old spare Pi have to setup pihole, unbound and wiregaurd, whilst keeping the OG pihole running, and then swapping out the sd card.
But, it dawned on me i may have conflicts with ports etc. as i will be, albeit briefly, running 2 instances at the same time.
So is it possible to set pihole running on port other than 53, and then change it once i am back to running only 1 pihole?
I know this seems very convoluted and unnecessary, but my ISP router is lock down to buggary, and takes some effort to enable / disable settings, and requires multiple reboots, which takes anywhere up to 8-10 minutes each.This, plus me not remembering exactly what i had to modify to get it to plat nice with Android (IPV6) and DHCP means i really want to avoid it.
