Set adlist to ignore ssl certs
Hardware Pi 4 & Pi VM & Pi 3b+
download a adlist from gitlab server ignore ssl self signed cert
--- Issue when setting up a local gitlab server i am not using ssl within my own network when i set pihoe to pull an adlist from it nothing happens im assuming it is due to a self signed cert error.
https://tricorder.pi-hole.net/4MGf0eRX/
http://192.168.0.31/HSCS_Block_List.txt
Why not make this a file, and skip the whole http process?
Hello jfb,
This is working as a workaround when i tried to use gitlab with this URL - https://192.168.0.43/wdbissler/blocklist/-/raw/main/HSCS_Blocklist.txt it would just give an error due to ssl. I have not found a way to turn ssl off on gitlab. currently the .31 is running a .bat file on widows to pull down the file from gitlab and make it available via its iis service. was trying to remove the middle man.
if it is not possible this will continue to work. i know with wget you can run it like 'wget –no-check-certificate https://192.168.0.43/wdbissler/blocklist/-/raw/main/HSCS_Blocklist.txt'
jfb,
I like that option. I may just try this out setting up a local git repo local and see how it goes - thank you for the suggestion.
