Router cause "Rate Limit" Warning
Hello, I set up my pi-hole a few years ago and now got a new router.
Try to set it up like the once before but get "rate Limit" warning.....
Here is my recent log:
https://tricorder.pi-hole.net/k71AHnqB/
I appreciate anyones help :slight_smile:
Thanks
Oliver
Your new router may be routing DNS queries through itself. If this is the case, all your DNS queries to Pi-hole will appear to originate from the router, and this can drive a rate limit to be exceeded.
You can check and see which IP's on your LAN are making the most queries:
echo ">top-clients withzero (15) >quit" | nc localhost 4711
You can also change your rate limit if needed.
Thanks for helping me with my prob!
There are several IPs, with the name give from the router.
So everything seems to be fine....if alle requests were routed thought the router the error would appear within from minutes and die devices wouldn't be there with names.
I deleted the error several times and within a few days it is back and every time it ist the router.....
