Rate Limited and Concurrent DNS troubleshooting
I'm setting up a Pi-hole with Unbound on a Pi3B, following popular guides and the docs, but as soon as I direct all DNS requests via my DDWRT router I get "Maximum number of concurrent DNS quries reached" and "Client at 192.168.1.1 has been rate-limited" messages.
This creates issues to the point of uploading my debug log failing. I don't know how to identify if I have a DNS loop, or how to see out potentially problematic clients/programs. Please let me know what additional info I can provide.
Forwarding all DNS queries to my pi-hole via my router should not cause issues to be flagged.
When forwarded, I get "Maximum number of concurrent DNS quries reached" and "Client at 192.168.1.1 has been rate-limited" messages.
This is my debug log: https://pastebin.com/fjeZM0EG
Please DM me for password, or if there's another effective way to upload a debug log and get a token.
Edit file /etc/pihole/pihole-FTL.conf and change the rate limit to 0/0. This will disable rate limiting while you troubleshoot.
Then restart FTL with pihole restartdns.
Then upload a debug log and post the token URL here.
Thank you for your response. I followed your instructions, and while "Client at 192.168.1.1 has been rate-limited" is temporarily resolved, the end of the log still reads:
  • A local copy of the debug log can be found at: /var/log/pihole/pihole_debug.log
This will temporarily reset the nameserver on the Pi to bypass Pi-Hole DNS.
sudo nano /etc/resolv.conf
Edit the nameserver line to nameserver 9.9.9.9 or your preferred third party DNS service, save and exit
Run
and upload the debug log.
That worked:
https://tricorder.pi-hole.net/HV9ORVBx/
Edit: This is wrong, I had my router configured to get things working, let me generate a new token.
Correct token: https://tricorder.pi-hole.net/7786JTXl/
Take a look at this thread - some discussion on why all your DNS queries appear to originate from your router. You may be able to change this behavior.
Your debug log shows no evidence of a DNS loop.
Thank you for the info. Reading those and doing some more searches pointed me to Pi-hole and ddwrt settings - #6 by graysky2
The setting there listed for DDWRT router firmware seems to fix a few of my issues, but if I have it configured that way and I unplug my pihole entirely, machines on my network are still getting dns from somewhere.
If I use option 2 from the link you posted (How do I configure my devices to use Pi-hole as their DNS server?), it makes sense until I get to this part: https://discourse.pi-hole.net/uploads/default/original/3X/1/b/1bf6f47237ed033108e52fa16313d34d1c227474.png
Which seems to be in conflict with setting that to "127.0.0.1#5335".
Further testing looks like wireless devices are all working properly, but my wired devices are not.
This is embarrassing, I just needed to restart my client.
To be clear, the thing that resolved my issue was dhcp-option=6,192.168.my.ip from this post Pi-hole and ddwrt settings - #6 by graysky2
Glad you got it resolved.
Me too, thank you for your help.
