Query results not return to LAN computers
Computers with DNS set to pi-hole IP 192.168.1.15 should query and get query results from pi-hole returned
tcpdump -i int udp 53 shows results being received by pi-hole machine but results are not resolved and returned to the machines. nmap shows port 53 udp open as filtered on this linux pi-hole.
https://tricorder.pi-hole.net/ydlcnvtkhz!
nslookup -type=txt -class=chaos version.bind 192.168.1.15
On Pi-hole as well as on one of your clients (linux/win/mac) ?
Thanks for your reply, so i have the results of the command:
Pi-hole Ubuntu server 192.168.1.15:
~$ nslookup -type=txt -class=chaos version.bind 192.168.1.15
Server: 192.168.1.15
Address: 192.168.1.15#53
version.bind text = "dnsmasq-pi-hole-2.80"
Macbook OSX 192.168.1.109:
monos-MacBook-Pro:~ mono$ ssh 192.168.1.15
mono@192.168.1.15's password:
monos-MacBook-Pro:~ mono$ nslookup -type=txt -class=chaos version.bind 192.168.1.15
I ran ssh to show connectivity is fine from the Mac running only pi-hole as its DNS, but with DNS there very much an error. In fact running tcpdump on the pi-hole server shows that the nslookup requests did arrive from the Mac, pi-hole is simply not answering for some reason? See below. Please note I do not use the pi-hole DHCP, but my tp-link router, however if manually setting the DNS on the Mac it should work in my expectations.
$ sudo tcpdump -i enp2s0 udp port 53
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on enp2s0, link-type EN10MB (Ethernet), capture size 262144 bytes
13:47:41.631205 IP 192.168.1.109.60603 > safeharbour.domain: 19394+ TXT CHAOS? version.bind. (30)
13:47:41.633412 IP safeharbour.20450 > resolver2.opendns.com.domain: 48058+ PTR? 109.1.168.192.in-addr.arpa. (44)
13:47:41.688327 IP resolver2.opendns.com.domain > safeharbour.20450: 48058 NXDomain* 0/1/0 (103)
13:47:46.635323 IP 192.168.1.109.60603 > safeharbour.domain: 19394+ TXT CHAOS? version.bind. (30)
13:47:51.636746 IP 192.168.1.109.60603 > safeharbour.domain: 19394+ TXT CHAOS? version.bind. (30)
Does below one show the correct interface + IP ?
sudo grep 'IPV[4,6]_ADDRESS\|PIHOLE_INTERFACE' /etc/pihole/setupVars.conf
Firewall active ?
sudo iptables -L -n
Check router for below or similar security settings:
Thanks for the reply.
sudo greo 'IPV[4,6]_ADDRESS\|PIHOLE_INTERFACE' /etc/pihole/setupVars.conf
Returns the correct IP and interface and that is all.
My router is a TP-Link Archer VR400 with none of the DNS rebind protection.
I monitor tcpdump traffic on the pihole and it is only ever one way, inbound! The pi-hole host itself performs lookups fine via pi-hole.
One question, if I can see my incoming queries via tcpdump [-i int udp port 53] on the pi-hole, why can't I see them in the pi-hole query log http://192.168.1.15/admin/queries.php ?
hostname is safeharbour:
23:16:16.344329 IP (tos 0x0, ttl 255, id 18198, offset 0, flags [none], proto UDP (17), length 68)
192.168.1.109.63415 > safeharbour.domain: [udp sum ok] 41826+ A? p52-streams.icloud.com. (40)
23:16:17.610550 IP (tos 0x0, ttl 255, id 65524, offset 0, flags [none], proto UDP (17), length 57)
192.168.1.109.53053 > safeharbour.domain: [udp sum ok] 4912+ A? twitter.com. (29)
23:16:18.344837 IP (tos 0x0, ttl 255, id 32086, offset 0, flags [none], proto UDP (17), length 68)
I have updated my iptables rules, as it just seems pi-hole replies do not occur outbound. However they are all fine I believe:
$ sudo iptables -L -n --line-number
Chain INPUT (policy ACCEPT)
num target prot opt source destination
1 f2b-sshd tcp -- 0.0.0.0/0 0.0.0.0/0 multiport dports 22
2 f2b-sshd tcp -- 0.0.0.0/0 0.0.0.0/0 multiport dports 22
3 f2b-sshd tcp -- 0.0.0.0/0 0.0.0.0/0 multiport dports 22
4 ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 multiport dports 445
5 ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 multiport dports 445
6 ACCEPT all -- 0.0.0.0/0 0.0.0.0/0
7 ACCEPT all -- 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
8 ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:22
9 ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp spt:53
10 ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:53
11 ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 multiport dports 80,443
12 DROP all -- 0.0.0.0/0 0.0.0.0/0
13 ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp spt:53
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
1 ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp spt:53
2 ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:53
3 ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:53
4 ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp spt:53
Also see my listening DNS ports
sudo netstat -nltup | grep ":53 "
tcp 0 0 127.0.0.1:53 0.0.0.0:* LISTEN 4820/pihole-FTL
tcp 0 0 192.168.1.15:53 0.0.0.0:* LISTEN 4820/pihole-FTL
tcp6 0 0 ::1:53 :::* LISTEN 4820/pihole-FTL
tcp6 0 0 fe80::9eb6:54ff:fe09:53 :::* LISTEN 4820/pihole-FTL
udp 0 0 127.0.0.1:53 0.0.0.0:* 4820/pihole-FTL
udp 0 0 192.168.1.15:53 0.0.0.0:* 4820/pihole-FTL
udp6 0 0 ::1:53 :::* 4820/pihole-FTL
udp6 0 0 fe80::9eb6:54ff:fe09:53 :::* 4820/pihole-FTL
ifconfig -a
please
host and pi hole plz
Am no iptables expert but to me it looks like your rules setup might be missconfigured.
The INPUT chain has rule #12 dropping everything before rule #13 to allow TCP 53.
So if a packet traverses the rules, it gets dropped even before it can reach rule #13.
And usually rule #1 is along the lines of below for a more efficient rules set:
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0 state RELATED,ESTABLISHED
Try disabling iptables or flushing the rules to diagnose.
Also look for other security settings that might block traffic.
Default pihole-FTL is listening on all IP's 0.0.0.0:
pi@noads:~ $ sudo netstat -nltup | grep 'Proto\|:53 \|:67 \|:80 \|:471[1-8] '
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      27450/lighttpd
tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      5235/pihole-FTL
tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      5235/pihole-FTL
tcp6       0      0 :::80                   :::*                    LISTEN      27450/lighttpd
tcp6       0      0 :::53                   :::*                    LISTEN      5235/pihole-FTL
tcp6       0      0 ::1:4711                :::*                    LISTEN      5235/pihole-FTL
udp        0      0 0.0.0.0:53              0.0.0.0:*                           5235/pihole-FTL
udp        0      0 0.0.0.0:67              0.0.0.0:*                           5235/pihole-FTL
udp6       0      0 :::53                   :::*                                5235/pihole-FTL
Check for alien dnsmasq/pihole-FTL config files not belonging to Pi-hole:
sudo grep -v '^#\|^$' -R /etc/dnsmasq.*
pi-hole
ifconfig -a
enp2s0    Link encap:Ethernet  HWaddr 9c:b6:54:09:33:ee
          inet addr:192.168.1.15  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::9eb6:54ff:fe09:33ee/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:270878 errors:0 dropped:61 overruns:0 frame:0
          TX packets:379435 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:98348702 (98.3 MB)  TX bytes:476378468 (476.3 MB)
          Interrupt:18
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:1623 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1623 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:143851 (143.8 KB)  TX bytes:143851 (143.8 KB)
mac host joining, not on vpn:
ifconfig -a
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
        options=1203<RXCSUM,TXCSUM,TXSTATUS,SW_TIMESTAMP>
        inet 127.0.0.1 netmask 0xff000000
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
        nd6 options=201<PERFORMNUD,DAD>
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
EHC29: flags=0<> mtu 0
EHC26: flags=0<> mtu 0
XHC20: flags=0<> mtu 0
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
        ether 28:cf:e9:1d:02:0b
        inet6 fe80::1ca9:ed17:628:6125%en0 prefixlen 64 secured scopeid 0x7
        inet 192.168.1.111 netmask 0xffffff00 broadcast 192.168.1.255
        media: autoselect
        status: active
p2p0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 2304
        ether 0a:cf:e9:1d:02:0b
        media: autoselect
        status: inactive
awdl0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1484
        ether 9e:bc:7f:96:2a:af
        inet6 fe80::9cbc:7fff:fe96:2aaf%awdl0 prefixlen 64 scopeid 0x9
        media: autoselect
        status: active
en1: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
        options=60<TSO4,TSO6>
        ether 32:00:16:70:8e:40
        media: autoselect <full-duplex>
        status: inactive
en2: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
        ether 32:00:16:70:8e:41
        status: inactive
bridge0: flags=8822<BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500
        options=63<RXCSUM,TXCSUM,TSO4,TSO6>
        Configuration:
                id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0
                maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200
                root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0
                ipfilter disabled flags 0x2
        member: en1 flags=3<LEARNING,DISCOVER>
                ifmaxaddr 0 port 10 priority 0 path cost 0
        member: en2 flags=3<LEARNING,DISCOVER>
                ifmaxaddr 0 port 11 priority 0 path cost 0
        media: <unknown type>
        status: inactive
utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
        inet6 fe80::a0d2:65cf:6476:80e1%utun0 prefixlen 64 scopeid 0xd
utun1: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
        inet6 fe80::38f7:2b5f:8041:68a8%utun1 prefixlen 64 scopeid 0xe
OK My bad it was iptables! Those rules were updated from the still failing system so i'm starting from scratch with rules again. Cheers!!!!! tcpdump below, pi-hole hostname is safeharbour/192.1681.1.15 Thanks Guys. :slight_smile: I did think on Firewalls it was good practice to drop all s the last rule.
22:46:41.787040 IP safeharbour.domain > 192.168.1.111.50559: 21983 3/0/0 CNAME session-origin-live.bbc.net.uk., A 212.58.244.215, A 212.58.249.137 (109)
22:46:42.853797 IP 192.168.1.111.62385 > safeharbour.domain: 4186+ A? nav.files.bbci.co.uk. (38)
22:46:42.854311 IP safeharbour.34948 > resolver2.opendns.com.domain: 48274+ A? nav.files.bbci.co.uk. (38)
22:46:42.856092 IP 192.168.1.111.65465 > safeharbour.domain: 10147+ A? homepage.files.bbci.co.uk. (43)
22:46:42.856517 IP safeharbour.44482 > resolver2.opendns.com.domain: 2571+ A? homepage.files.bbci.co.uk. (43)
22:46:42.873095 IP resolver2.opendns.com.domain > safeharbour.34948: 48274 3/0/0 CNAME nav.files.bbci.co.uk.edgekey.net., CNAME e3891.dscf.akamaiedge.net., A 104.82.74.185 (136)
22:46:42.873400 IP safeharbour.domain > 192.168.1.111.62385: 4186 3/0/0 CNAME nav.files.bbci.co.uk.edgekey.net., CNAME e3891.dscf.akamaiedge.net., A 104.82.74.185 (136)
22:46:42.887113 IP resolver2.opendns.com.domain > safeharbour.44482: 2571 3/0/0 CNAME homepage.files.bbci.co.uk.edgekey.net., CNAME e3891.dscf.akamaiedge.net., A 104.82.74.185 (146)
22:46:42.887392 IP safeharbour.domain > 192.168.1.111.65465: 10147 3/0/0 CNAME homepage.files.bbci.co.uk.edgekey.net., CNAME e3891.dscf.akamaiedge.net., A 104.82.74.185 (146)
Nothing I can see in your output shows an glaring network issues, I can see at least.
IMO, if this is not a production machine, restore IP Tables to default and test to either confirm it is indeed an IP TAbles issue or not. back up IP Tables of course before.
I know network ACLs can cause some really unexpected behavior.
https://sharadchhetri.com/2014/02/22/how-to-backup-and-restore-iptables-on-linux-systems/
I would also turn down all your interfaces on your ubuntu machine for troubleshooting; just keep en0 up.
A softer approch would be to observe requests by:
watch --interval=5 'iptables -nvL | grep -v "0 0"'
(lifted from:
Bottom of the article)
That's how Cisco does it. "implicit deny rule"
if a permit rule doesn't allow it, it it gets dumped.
