Query log - advanced filtering - Domain -> not working
Are there smth wrong in advanced Filtering? If I see in query log a domain like here
googleapis.com it's not selectable in domain list and so I can't select all requests which done to this domain
Have you tried typing the domain name in the searh window (regardless of which pull downs are shown), and then selecting refresh?
I am able to search for google.com (not shown in the pull down) and this displays the correct filtered results.
Sure I tried:
And in V5 we could type also just parts of domains and got result
OK, I removed the database completely and restarted. Now I can select properly, but no wildcards or domains only. This is a big step backwards compared to V5
e.g.: google.com shows only google.com but not reminders-pa.clients6.google.com or clients2.google.com ...
In v5.x you first had to get all data and all processing worked in your local browser. For v6 we implemented server-side pagination which - so far - wasn't able to do wildcard matching. This has just been added in
https://github.com/pi-hole/FTL/pull/1678
Instead of the completely random wildcard matching, we decided to opt for "real" wildcards with the wildcard character *. So what you want could be achieved with *google.com (hint: It'd also match google.com itself). But our wildcard implementation goes beyond that, you can use a wildcard in any place you want: *fla*.c* will match cloudflare.com, flamewar.com and others.
sounds great :ok_hand:
4 posts were split to a new topic: Query Log "All Time" broken
