Hi guys,
my last working image is from 2022.02. When I use the latest the WebUI won´t start.
When I change it back everything works normally.
Has something changed generally ?
Thanks and Greetings,
Julian
Hi guys,
Julian
Please post your docker run
or docker-compose.yml
file.
Hi there,
here you are: (and thanks in advance )
version: "3"
pihole:
container_name: pihole
image: pihole/pihole:2022.02.1
network_mode: host
environment:
TZ: 'Europe/Berlin'
ServerIP: ${ServerIP}
WEBPASSWORD: <Iwonttellya)
volumes:
- './etc-pihole/:/etc/pihole/'
- './etc-dnsmasq.d/:/etc/dnsmasq.d/'
dns:
- 127.0.0.1
- 1.1.1.1
cap_add:
- NET_ADMIN
restart: unless-stopped
Cheers,
Julian
Can you run docker compose up
and show the output from the startup logs?
Thanks.
root@home-core:~/pi-hole# docker logs pihole
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] 01-resolver-resolv: applying...
[fix-attrs.d] 01-resolver-resolv: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 05-changer-uid-gid.sh: executing...
[cont-init.d] 05-changer-uid-gid.sh: exited 0.
[cont-init.d] 20-start.sh: executing...
::: Starting docker specific checks & setup for docker pihole/pihole[i] Installing configs from /etc/.pihole...
[✓] Installed /etc/dnsmasq.d/01-pihole.conf
[✓] Installed /etc/dnsmasq.d/06-rfc6761.conf
Existing DNS servers detected in setupVars.conf. Leaving them alone
::: Pre existing WEBPASSWORD found
DNSMasq binding to default interface: eth0
Added ENV to php:
"TZ" => "Europe/Berlin",
"PIHOLE_DOCKER_TAG" => "2022.04.3",
"PHP_ERROR_LOG" => "/var/log/lighttpd/error.log",
"ServerIP" => "192.168.1.9",
"CORS_HOSTS" => "",
"VIRTUAL_HOST" => "192.168.1.9",
Using IPv4 and IPv6
::: Preexisting ad list /etc/pihole/adlists.list detected ((exiting setup_blockl ists early))
::: Testing lighttpd config: Syntax OK
::: All config checks passed, cleared for startup ...
::: Enabling Query Logging
[i] Enabling logging...
[✓] Logging has been enabled!
::: Docker start setup complete
Checking if custom gravity.db is set in /etc/pihole/pihole-FTL.conf
Pi-hole version is v5.10 (Latest: v5.10)
AdminLTE version is v5.12 (Latest: v5.12)
FTL version is v5.15 (Latest: v5.15)
Container tag is: 2022.04.3
[cont-init.d] 20-start.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
Starting crond
Starting lighttpd
Starting pihole-FTL (no-daemon) as pihole
[services.d] done.
[fix-attrs.d] done.
Added ENV to php:
"CORS_HOSTS" => "",
Using IPv4 and IPv6
::: Preexisting ad list /etc/pihole/adlists.list detected ((exiting setup_blocklists early))
[cont-init.d] done.
Starting crond
Starting lighttpd
[services.d] done.
I don't see anything wrong yet. lighttpd
is running in the container and you are being sent assets from the web server. I wouldn't expect 304
from a fresh setup, you may have old things in your browser cache.
What URL are you using for that view?
