Hi, I´m following up on this post here (sorry, was away for awhile)
It´s still not working and I´m not sure what to do ....
Running on a raspberry pi 3B
uname -a
Linux home-core 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l GNU/Linux
my docker-compose (again)
version: "3"
services:
pihole:
container_name: pihole
image: pihole/pihole:2022.02.1
#image: pihole/pihole
network_mode: host
environment:
TZ: 'Europe/Berlin'
ServerIP: ${ServerIP}
WEBPASSWORD: secret
DNSMASQ_USER: root
volumes:
- ./etc-pihole/:/etc/pihole/
- ./etc-dnsmasq.d/:/etc/dnsmasq.d/
#- /etc/localtime:/etc/localtime:ro
dns:
- 127.0.0.1
- 1.1.1.1
cap_add:
- NET_ADMIN
restart: unless-stopped
startup log
s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] 01-resolver-resolv: applying...
[fix-attrs.d] 01-resolver-resolv: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 05-changer-uid-gid.sh: executing...
[cont-init.d] 05-changer-uid-gid.sh: exited 0.
[cont-init.d] 20-start.sh: executing...
::: Starting docker specific checks & setup for docker pihole/pihole
cap[cap_sys_nice] not permitted[i] Installing configs from /etc/.pihole...
[✓] Installed /etc/dnsmasq.d/01-pihole.conf
[✓] Installed /etc/dnsmasq.d/06-rfc6761.conf
Existing DNS servers detected in setupVars.conf. Leaving them alone
::: Pre existing WEBPASSWORD found
DNSMasq binding to default interface: eth0
Added ENV to php:
"TZ" => "Europe/Berlin",
"PIHOLE_DOCKER_TAG" => "2022.05",
"PHP_ERROR_LOG" => "/var/log/lighttpd/error.log",
"ServerIP" => "192.168.1.9",
"CORS_HOSTS" => "",
"VIRTUAL_HOST" => "192.168.1.9",
Using IPv4 and IPv6
::: Preexisting ad list /etc/pihole/adlists.list detected ((exiting setup_blocklists early))
::: Testing lighttpd config: Syntax OK
::: All config checks passed, cleared for startup ...
::: Enabling Query Logging
[i] Enabling logging...
[✓] Logging has been enabled!
::: Docker start setup complete
Checking if custom gravity.db is set in /etc/pihole/pihole-FTL.conf
Pi-hole version is v5.10 (Latest: v5.10)
AdminLTE version is v5.12 (Latest: v5.12)
FTL version is v5.15 (Latest: v5.15)
Container tag is: 2022.05
[cont-init.d] 20-start.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
Starting lighttpd
Starting crond
Starting pihole-FTL (no-daemon) as root
[services.d] done.
docker info
Client:
Context: default
Debug Mode: false
Plugins:
app: Docker App (Docker Inc., v0.9.1-beta3)
buildx: Docker Buildx (Docker Inc., v0.8.2-docker)Server:
Containers: 4
Running: 4
Paused: 0
Stopped: 0
Images: 4
Server Version: 20.10.16
Storage Driver: overlay2
Backing Filesystem: extfs
Supports d_type: true
Native Overlay Diff: true
userxattr: false
Logging Driver: json-file
Cgroup Driver: cgroupfs
Cgroup Version: 1
Plugins:
Volume: local
Network: bridge host ipvlan macvlan null overlay
Log: awslogs fluentd gcplogs gelf journald json-file local logentries splunk syslog
Swarm: inactive
Runtimes: runc io.containerd.runc.v2 io.containerd.runtime.v1.linux
Default Runtime: runc
Init Binary: docker-init
containerd version: 212e8b6fa2f44b9c21b2798135fc6fb7c53efc16
runc version: v1.1.1-0-g52de29d
init version: de40ad0
Security Options:
seccomp
Profile: default
Kernel Version: 5.10.103-v7l+
Operating System: Raspbian GNU/Linux 10 (buster)
OSType: linux
Architecture: armv7l
CPUs: 4
Total Memory: 3.749GiB
Docker Root Dir: /var/lib/docker
Debug Mode: false
Registry: <too many links in post>
Labels:
Experimental: false
Insecure Registries:
127.0.0.0/8
Live Restore Enabled: falseWARNING: No memory limit support
WARNING: No swap limit support
WARNING: No kernel memory TCP limit support
WARNING: No oom kill disable support
And here I am .....
