Pihole Whitelist and Blacklist Empty After Update
Problem with Beta 5.0:
After updating to Beta 5.0 the Whitelist and Blacklist are both empty. Not sure if it's connected but the Groups Link also throws an error
https://tricorder.pi-hole.net/sdvyhfhbot
The PiHole is still blocking things from my old list, but it is also blocking things I was not blocking before. I tried looking at other threads and tried some suggestions in this thread
(Whitelist and black list Failure - #20 by DL6ER)
[ pihole checkout web fix/check_idn]
and got this message back
This branch no longer exists. It was merged into the beta 5.0.
pihole checkout web release/v5.0
Looks good. May want to pihole -up to catch the latest beta fixes.
Now, for the cause of the issue:
[80] is in use by apache2 (https://discourse.pi-hole.net/t/hardware-software-requirements/273#ports)
HTTP/1.1 200 OK
Date: Thu, 30 Apr 2020 00:21:52 GMT
Server: Apache/2.4.38 (Raspbian)
Last-Modified: Fri, 20 Mar 2020 22:21:42 GMT
ETag: "29cd-5a150b5c51006"
Accept-Ranges: bytes
Content-Length: 10701
Vary: Accept-Encoding
Content-Type: text/html
[✗] Web interface X-Header: X-Header does not match or could not be retrieved.
HTTP/1.1 200 OK
Set-Cookie: PHPSESSID=vr2akrm0dj2rnq5tn0rnf6lql0; path=/
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
Pragma: no-cache
Content-Type: text/html; charset=UTF-8
And is this right? You have over 1600 manual domain wildcard and regex entries??
   1686     3        1  0             (^|\.)airfind\.com$        2020-04-29 23:58:07  2020-04-29 23:58:07  Migrated from /etc/pihole/regex.list
After you made these changes, is your problem resolved? All the black and whitelists have reappeared?
