pihole -up fails with “Could not resolve host github.com” after FTL error, internet breaks when Tailscale is connected
  • pihole -up should be able to resolve GitHub and complete updates.
  • pihole -d should upload the debug log to tricorder.pi-hole.net successfully.
The VPS should have normal internet and DNS access, including when Tailscale is enabled.
  • Operating System: Ubuntu Linux on a Hetzner VPS
  • Hardware: Hetzner Cloud VPS (4 GB RAM)
  • Docker: Not using Docker
Situation:
  • Pi-hole installed directly on the Hetzner VPS
  • Tailscale installed and used
  • No reverse proxy
Limited experience with firewalls or UFW, so misconfiguration is possible
The first run of pihole -up failed with an FTL-related error.
Since then, every update attempt fails with a DNS resolution error:
  [✓] Building dependency package pihole-meta.deb
  [✓] Installing Pi-hole dependency package
  [i] Checking for updates...
fatal: unable to access 'https://github.com/pi-hole/pi-hole.git/': Could not resolve host: github.com
  Error: Unable to update local repository. Contact Pi-hole Support.
Running pihole -d completes locally, but the upload fails due to DNS resolution:
[✓] ** FINISHED DEBUGGING! **
    * Error message: curl: (6) Could not resolve host: tricorder.pi-hole.net
   * A local copy of the debug log can be found at: /var/log/pihole/pihole_debug.log
No connection when connected to tailscale. Can reach pihole dashboard.
See above
Please share the output from the following two commands: sudo tailscale dns status and cat /etc/resolv.conf
I suggest you take a look at:
And the whole thread of Pihole with Tailscale DNS error
That was it. Thanks!
