since 2 days my pihole stops resolving dns and the only fix is to reinstall it. After a few minutes / hours it stops again resolving dns. My fritzbox changes the dns to 8.8.8.8 then to avoid network downtimes. If I remove the alternate dns I couldn't reach anything outsite. I can ping everything without problems with the pi.
The only thing I changed is the webinterface port to 8093
2003:c8:df0f:3300:ceb3:69a3:740e:6001 does not match the IP found in /etc/pihole/setupVars.conf
(Use IPv6 ULA addresses for Pi-hole)
fe80::bd13:c13b:421d:ab37 does not match the IP found in /etc/pihole/setupVars.conf
And:
[✓] monetizer101.com is :: via localhost (::1)
[✗] Failed to resolve monetizer101.com via Pi-hole (2003:c8:df0d:8a00:366a:9023:8a06:d037)
[✓] doubleclick.com is 2a00:1450:4001:81b::200e via a remote, public DNS server (2001:4860:4860::8888)
