Hello this is my first post. I have been trying to download and troubleshoot this but it appears to not be working. I am unsure what my issue is. I tried to fix it by running pihole -r. It did not work so then I reconfigured it, but now I am unable to even get to the admin page.
I have followed the advice on some of the other posts but appear to have a mixture of them all. Here is the debug token: 4oillqhkii
Pi-hole version is v3.3.1 (Latest: v3.3.1)
AdminLTE version is v3.3 (Latest: v3.3)
FTL version is v3.0 (Latest: v3.0)
pi@raspberrypi:~ $ sudo systemctl status dnsmasq
â—Ź dnsmasq.service - dnsmasq - A lightweight DHCP and caching DNS server
Loaded: loaded (/lib/systemd/system/dnsmasq.service; enabled)
Drop-In: /run/systemd/generator/dnsmasq.service.d
└─50-dnsmasq-$named.conf, 50-insserv.conf-$named.conf
Active: failed (Result: exit-code) since Fri 2018-04-27 17:51:02 UTC; 3min 12s ago
Process: 4236 ExecStartPre=/usr/sbin/dnsmasq --test (code=exited, status=1/FAILURE)
Apr 27 17:51:02 raspberrypi dnsmasq[4236]: dnsmasq: extraneous parameter at line 37 of /etc/dnsmasq.d/01-pihole.conf
Apr 27 17:51:02 raspberrypi systemd[1]: dnsmasq.service: control process exited, code=exited status=1
Apr 27 17:51:02 raspberrypi systemd[1]: Failed to start dnsmasq - A lightweight DHCP and caching DNS server.
Apr 27 17:51:02 raspberrypi systemd[1]: Unit dnsmasq.service entered failed state.
pi@raspberrypi:~ $ sudo systemctl status pihole-FTL
â—Ź pihole-FTL.service - LSB: pihole-FTL daemon
Loaded: loaded (/etc/init.d/pihole-FTL)
Active: inactive (dead)
pi@raspberrypi:~ $ dig pi-hole.net
# (c) 2015, 2016 by Jacob Salmela
# Network-wide ad blocking via your Raspberry Pi
# http://pi-hole.net
# dnsmasq config for Pi-hole
# Pi-hole is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 2 of the License, or
# (at your option) any later version.
# FILE AUTOMATICALLY POPULATED BY PI-HOLE INSTALL/UPDATE PROCEDURE. #
# IF YOU WISH TO CHANGE THE UPSTREAM SERVERS, CHANGE THEM IN: #
# /etc/pihole/setupVars.conf #
# ANY OTHER CHANGES SHOULD BE MADE IN A SEPERATE CONFIG FILE #
# OR IN /etc/dnsmasq.conf #
localise-queries
no-resolv
cache-size=10000
log-queries=extra
local-ttl=2
log-async
server=208.67.222.222
server=208.67.220.220
interface=eth0
I reinstalled it. Reran through all of the suggestions you gave me. Repaired it and it still doesn't appear to work. I can't even get the Admin Gui to appear. Still having the FTL issues
The devs will take a look at your debug code, there might be more stuff happening there than what we could have fixed with the the basic troubleshooting we did ...
