Pihole records surge of DNS queries
I'm fairly new to Pihole and not very technical
Pihole detects a surge of DNS queries, that temporarily disconnects my internet. Originally, Pihole would crash because of the surge of DNS queires. So following possible deadlock in dataloader · Issue #1355 · pytorch/pytorch · GitHub comments, I increased the SHM size. However, as discussed this is only a bandaid solution to a larger problem.
Following the discussion from: FTL Offline - Lost Connection to API
I receive a surge of queries from these two domains
0 1121708 api.engage.bidsystem.com
1 404326 216.58.202.4.in-addr.arpa
I logged the queries as they came in to determine which device was the issue, using tail -f /var/log/pihole.log
May 30 05:19:03 dnsmasq[1460]: forwarded api.engage.bidsystem.com to 1.1.1.1
May 30 05:19:03 dnsmasq[1460]: forwarded api.engage.bidsystem.com to 127.17.0.1
May 30 05:19:03 dnsmasq[1460]: query[A] api.engage.bidsystem.com from 127.0.0.1
May 30 05:19:03 dnsmasq[1460]: reply error is SERVFAIL
And this is the FTL log
[2020-05-30 05:20:34.705 1460] Resizing "/FTL-queries" from 89653248 to 89915392
[2020-05-30 05:20:38.994 1460] Resizing "/FTL-queries" from 89915392 to 90177536
[2020-05-30 05:20:43.971 1460] Resizing "/FTL-queries" from 90177536 to 90439680
[2020-05-30 05:20:48.180 1460] Resizing "/FTL-queries" from 90439680 to 90701824
[2020-05-30 05:20:58.438 1460] Resizing "/FTL-queries" from 90701824 to 90963968
[2020-05-30 05:21:03.176 1460] Resizing "/FTL-queries" from 90963968 to 91226112
[2020-05-30 05:21:18.942 1460] Resizing "/FTL-queries" from 91226112 to 91488256
[2020-05-30 05:21:41.008 1460] Resizing "/FTL-queries" from 91488256 to 91750400
[2020-05-30 05:22:03.200 1460] Resizing "/FTL-queries" from 91750400 to 92012544
[2020-05-30 05:22:07.724 1460] Resizing "/FTL-queries" from 92012544 to 92274688
[2020-05-30 05:22:43.593 1460] Resizing "/FTL-queries" from 92274688 to 92536832
And if I black list the domain, I just get
May 30 05:32:17 dnsmasq[1460]: forwarded fcmconnection.googleapis.com to 127.17.0.1
May 30 05:32:17 dnsmasq[1460]: query[A] fcmconnection.googleapis.com from 127.0.0.1
May 30 05:32:17 dnsmasq[1460]: Maximum number of concurrent DNS queries reached (max: 150)
May 30 05:32:27 dnsmasq[1460]: query[A] fcmconnection.googleapis.com from 127.0.0.1
May 30 05:32:27 dnsmasq[1460]: forwarded fcmconnection.googleapis.com to 127.17.0.1
May 30 05:32:27 dnsmasq[1460]: query[A] catalog-public-service-prod06.ol.epicgames.com from 172.17.0.1
May 30 05:32:27 dnsmasq[1460]: cached catalog-public-service-prod06.ol.epicgames.com is
May 30 05:32:27 dnsmasq[1460]: cached catalogv2-svc-prod06-pub-772318179.us-east-1.elb.amazonaws.com is 54.174.108.91
May 30 05:32:27 dnsmasq[1460]: cached catalogv2-svc-prod06-pub-772318179.us-east-1.elb.amazonaws.com is 18.211.165.162
May 30 05:32:27 dnsmasq[1460]: cached catalogv2-svc-prod06-pub-772318179.us-east-1.elb.amazonaws.com is 54.82.245.68
May 30 05:32:27 dnsmasq[1460]: cached catalogv2-svc-prod06-pub-772318179.us-east-1.elb.amazonaws.com is 107.21.53.189
May 30 05:32:27 dnsmasq[1460]: cached catalogv2-svc-prod06-pub-772318179.us-east-1.elb.amazonaws.com is 34.236.122.157
May 30 05:32:27 dnsmasq[1460]: cached catalogv2-svc-prod06-pub-772318179.us-east-1.elb.amazonaws.com is 34.193.244.184
May 30 05:32:27 dnsmasq[1460]: cached catalogv2-svc-prod06-pub-772318179.us-east-1.elb.amazonaws.com is 35.171.214.220
May 30 05:32:27 dnsmasq[1460]: cached catalogv2-svc-prod06-pub-772318179.us-east-1.elb.amazonaws.com is 34.233.159.184
May 30 05:32:27 dnsmasq[1460]: query[A] www.google.com from 172.17.0.1
May 30 05:32:27 dnsmasq[1460]: forwarded www.google.com to 127.17.0.1
May 30 05:32:27 dnsmasq[1460]: query[A] www.google.com from 127.0.0.1
May 30 05:32:28 dnsmasq[1460]: forwarded fcmconnection.googleapis.com to 127.17.0.1
May 30 05:32:28 dnsmasq[1460]: query[A] www.google.com from 127.0.0.1
May 30 05:32:28 dnsmasq[1460]: forwarded www.google.com to 127.17.0.1
May 30 05:32:28 dnsmasq[1460]: query[A] fcmconnection.googleapis.com from 127.0.0.1
I am not too sure how to determine whats causing the issue, and how to resolve it.
Thank you,
Kind Regards
Smackso
Pihole and internet working normally
Surge of DNS queries that disconnects internet
Sorry I cant upload the debug token, I am not sure why. I get the folllowing
  • A local copy of the debug log can be found at: /var/log/pihole_debug.log
Seems as if you've created a DNS loop.
IP 127.17.0.1 seems to be one of your upstream DNS servers configured in Pihole.
But 127.17.0.1 is Pi-hole:
pi@ph5:~ $ dig +short chaos txt version.bind @127.17.0.1
"dnsmasq-pi-hole-2.81"
So DNS queries go loopty loop.
Okay, so I just remove the 127.17.0.1 from the upstream DNS servers,
and replace it with another server, ie Cloudflare.
I was just following a guide from: Install Pi-hole on Windows 10 and live ad-free forever | Andrew Denty, who had noted that the DNS1 server had to be localhost in order for the Pihole to work.
Thank you!!
Is this running on docker? DNS1 is an environment variable for Docker. It's not for an upstream value.
Version 5 eliminates the need for docker containers to use localhost anymore.
Yes, its running on docker on my main pc. I am not too sure what you mean.
I just followed the guide from above, and it advised to put DNS1 as 127.17.0.1.
I had a look at the environmental variables for docker on the Github page. And it says DNS1 is for the primary upstream provider.
My internet has been working fine for the last 2 hours.
So many blogs with Pi-hole instructions that fall short.
This one included.
Read the docs and things might clear up a bit:
Yeah I tried following the setup link, but I am not very technical. I appreciate the help.
My internet has been working fine for the last 24 hrs.
Thank you!
