Hello again!!it's https://tricorder.pi-hole.net/1uonkk400a
This is the place for contacting us. All the developers are here. Email is not a good way to get us involved.
For an unkown reason,when I click the token it says not available..Please,could someone verify that it's ok and you can view it??
Tokens expire after 48 hours.
So I should create another one here!Thanks so much!!
Ok,I just uploaded this: https://tricorder.pi-hole.net/bdh1pfze3p
BUT again,I get permission denied..Just verify that you can see it and it's only my problem..Thanks again!!
Only the developers have access to the logs, you will not be able to access that URL.
oh,that's why!!Thanks really..
Please,could a developer verify that you can see the token??should I create another one,or wait and create it tomorrow after it will expire??could I provide you info another way,without the expiration??
Why are you running a development version of FTL?
[i] Core: v4.3.2 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.3.2-0-ge41c4b5
[i] Web: v4.3.2 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.3.2-0-g38d8e77
[ā] FTL: vDev-c3ee98b (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
Sorry if my answer is dummy..I just installed pi hole with the command:curl -sSL https://install.pi-hole.net | bash
I also tried to go to the beta version because it wasn't working..Should I uninstall and install again pihole??
Yes, you have a mix of versions on your system now.
OK!here is the new token,with the new installation..https://tricorder.pi-hole.net/c3n6zpoaz9
just to verify again..I go to the IPv4 section of my connection (lets say PC) and I enter to the DNS the address of my pihole.Then,nothing happens..
The debug log shows everything working without issues. What IP address are you entering?
192.168.1.32 it's the IP shown in my router menu for raspberry pi.
I also tried to add the raspberry pi address not only to the IPv4 connection of my pc.But also to the modem-router DNS server,on the DHCP pool..Again,nothing worked..
Pi-hole is working at that address. All the tests are good.
The only other thing I can think of is that the router is blocking you from using a local DNS server. Some have a feature called DNS Rebind protection
that will drop any DNS packets for a local server unless the feature is disabled.
I suppose I have to change my router then..Thing is that I now saw that on the pihole admin (network) it says that my PC is using pihole.but Ads are displayed as always..am i missing something??
also nslookup pi.hole 192.168.1.32 returns the address of the pi.hole.the problem is that it doesn't filter ads..
Show us an example please.
