Bis auf FTL und dnsmasq scheint alles zu laufen. Merkwürdig dass mein System den Service von dnsmasq nicht finden kann, im Debuglog aber Version 340 angezeigt wird.
Dnsmasq soll sowieso durch unbound bzgl DoT ersetzt werden.
Thank you for your reply.
But why i couldn't start the Pihole FTL?
If i type:
sudo service pihole-FTL start
it shows:
Not running
chown: Zugriff auf '/etc/pihole/dhcp.leases' nicht möglich: Datei oder Verzeichnis nicht gefunden
Failed to set capabilities on file `/usr/bin/pihole-FTL' (Operation not supported)
The value of the capability argument is not permitted for a file. Or the file is not a regular (non-symlink) file
dnsmasq: failed to create listening socket for port 53: Permission denied
In V4.0, dnsmasq is embedded in pihole-FTL, and dnsmasq no longer runs as a separate process. The debug log will show dnsmasq as either failed or inactive. Process pihole-FTL should be shown running on port 53.
I've changed the unbound port to 5353 like in the setup guide, restartet the services... now nameresolve is dead...
Don't changed anything in the systemsettings.
The problem is that nslookup also fails. So i deceided to uninstall unbound first.
Same Problem.
Unbound didn't start.
Network down and i couldn't found how i return back to dhcp, wich file does pihole changed?
Ive checked everything i could find....
Because of the many problems, ive decided to start with a fresh Devuan, without unbound first.
Now installation breaks at:
[✓] Starting pihole-FTL service
[✓] Enabling pihole-FTL service to start on reboot
[✓] Deleting existing list cache
[✗] DNS service is not running
[✓] Starting DNS service
[✗] DNS resolution is not available
So the installation crashes my systemdns, i'm not able to install or update any packages...
No more. I've installed a clean Devuan. There is no unbound anymore.
But if i now want to install pi-hole it breaks installation with "dns service not running".
The problem is that this changes also my systemresolver and then my system isn't working correctly.
Also ich habe schon mal lokalisieren können dass er bei jedem Neustart die Datei /etc/resolv.conf überschreibt, mit dem Inhalt von localhost also 127.0.0.1 obwohl ich während der Installation gesagt habe werte nicht als statisch setzen. Bevor ich Pihole installiert hatte stand dort mein Gateway drin. Unbound ist nicht installiert, dennoch bricht er die Installation vorzeitig ab aus o.g. Grund...
Hast du eine Idee? Im Webinterface steht Lost connection to API?
Nachtrag:
Was mich auch sehr stutzig macht, bei meinem ersten Versuch als unbound vorher installiert war, stand im Debuglog immerhin dass er via localhost eine DNS-Auflösung machen konnte, nur nicht via Pihole. Mittlerweile kommt bei beiden ein Fehler.
Your debug log is showing a number of problems, perhaps related to your OS, which I believe is unsupported.
FTL is not running:
*:22 sshd (IPv4)
*:22 sshd (IPv6)
*:80 lighttpd (IPv4)
*:80 lighttpd (IPv6)
Since FTL is not running, your web interface won't show any statistics (these are from FTL) and your Pi-Hole won't function properly. The section of the debug log below is the test for function - in this case the test cannott find a blocked domain in gravity to test, because your gravity list is empty.
[✗] Failed to resolve via localhost (127.0.0.1)
[✗] Failed to resolve via Pi-hole (192.168.178.153)
[✓] doubleclick.com is 216.58.207.174 via a remote, public DNS server (8.8.8.8)
No. We install only a sys-v script (/etc/init-d/pihole-FTL). We do not use anysystemd specific parts at the moment. This will change in the future, but we will always do your best to keep compatibility to both, sysV and systemd.
This is a major issue of your system and likely the main reason for everything that is not working. Is /usr/bin/pihole-FTL a regular exectuable? If so, then your system does not support setting capabilities which means that much more has been changed under the hook (not only systemd has been replaced). There is a solution for you available in case you confirm that capabilities are not available on the OS you used. Furthermore, Pi-hole v4.1 will be able to deal with such a scenario automatically and improves support for such special OS.
Ja, das passt so. Diese Fehlermeldung kommt immer dann wenn man den Pi-hole DHCP Server nicht nutzt, ist jedoch nur kosmetischer Natur und wird in v4.1 nicht mehr da sein.
