PiHole Not Blocking Anything
Expected Behavior:
Recently, my PiHole instance stopped blocking anything. I have Pi-hole running on a Docker container on a Linux server and while Pi-hole sees all the queries coming in, nothing is blocked.
  • Operating System (Family and Version): Ubuntu 20.04.6 LTS (Focal Fossa)
  • Docker compose file or Docker run command
version: "3"
services:
  pihole:
    container_name: pihole
    image: pihole/pihole:latest
    ports:
      - "[MY_IP]:53:53/tcp"
      - "[MY_IP]:53:53/udp"
      - "67:67/udp"
      - "80:80/tcp"
      - "443:443/tcp"
    environment:
      TZ: America/Chicago
    volumes:
      - './etc-pihole/:/etc/pihole/'
      - './etc-dnsmasq.d/:/etc/dnsmasq.d/'
    cap_add:
      - NET_ADMIN
    restart: unless-stopped
  • Docker engine version: Docker version 27.5.1, build 9f9e405
Actual Behavior:
All my devices are connected to my router -> router has custom DNS servers pointed to the pi-hole server. Query Logs show every query I'm making but they're all green and allowed; however, when I click on the "Active Clients" link under "Total Queries", it shows all my devices as > 24 hours ago. I'm also unable to manually deny anything from "query logs"; nothing happens.
Any idea what could've changed? Not sure how to even troubleshoot this at this point.
Thanks!
https://tricorder.pi-hole.net/Kqq6mhlD/
