I am running raspbian jesse.
I am running:
pihole version
Pi-hole version is v3.3-130-g2e6a937 (Latest: v3.3.1)
AdminLTE version is v3.2.1-179-g3fd9b4d (Latest: v3.3)
FTL version is vDev-8ef6f31 (Latest: v3.0)
I have installed the new dnsmasq because with the version of pihole I am using it appears to be incompatible.
I appear to have dnsmasq running, when I turn this off I am unable to resolve uris:
sudo systemctl status dnsmasq
● dnsmasq.service - dnsmasq - A lightweight DHCP and caching DNS server
Loaded: loaded (/lib/systemd/system/dnsmasq.service; enabled)
Drop-In: /run/systemd/generator/dnsmasq.service.d
└─50-dnsmasq-$named.conf, 50-insserv.conf-$named.conf
Active: active (running) since Fri 2018-05-11 03:21:54 UTC; 5min ago
Process: 17636 ExecStop=/etc/init.d/dnsmasq systemd-stop-resolvconf (code=exited, status=0/SUCCESS)
Process: 20110 ExecStartPost=/etc/init.d/dnsmasq systemd-start-resolvconf (code=exited, status=0/SUCCESS)
Process: 20105 ExecStart=/etc/init.d/dnsmasq systemd-exec (code=exited, status=0/SUCCESS)
Process: 20101 ExecStartPre=/usr/sbin/dnsmasq --test (code=exited, status=0/SUCCESS)
Main PID: 20109 (dnsmasq)
CGroup: /system.slice/dnsmasq.service
└─20109 /usr/sbin/dnsmasq -x /run/dnsmasq/dnsmasq.pid -u dnsmasq -r /run/dnsmasq/resolv.conf -7 /etc/dnsmasq.d,.dpkg-dist,.dpkg-old,.dpkg-new --local-service
May 11 03:21:54 raspberrypi dnsmasq[20101]: dnsmasq: syntax check OK.
May 11 03:21:54 raspberrypi systemd[1]: Started dnsmasq - A lightweight DHCP and caching DNS server.
I am also running pihole-ftl but it doesn't appear to be able to start:
sudo systemctl status pihole-FTL
Loaded: loaded (/etc/init.d/pihole-FTL)
Active: active (exited) since Fri 2018-05-11 03:30:42 UTC; 2s ago
Process: 25417 ExecStop=/etc/init.d/pihole-FTL stop (code=exited, status=0/SUCCESS)
Process: 25490 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
May 11 03:30:42 raspberrypi pihole-FTL[25490]: Not running
May 11 03:30:42 raspberrypi pihole-FTL[25490]: rm: cannot remove ‘/var/run/pihole/FTL.sock’: No such file or directory
May 11 03:30:42 raspberrypi su[25504]: Successful su for pihole by root
May 11 03:30:42 raspberrypi su[25504]: + ??? root:pihole
May 11 03:30:42 raspberrypi su[25504]: pam_unix(su:session): session opened for user pihole by (uid=0)
May 11 03:30:42 raspberrypi pihole-FTL[25490]: FTL started!
May 11 03:30:42 raspberrypi systemd[1]: Started LSB: pihole-FTL daemon.
I am unable to restart it using sudo service pihole-FTL status or sudo systemctl status pihole-FTL
It throws an error, when trying to start:
## but this file exists and is owned by pihole
ls -la /var/run/pihole/
total 0
drwxr-xr-x 2 pihole pihole 60 May 11 03:36 .
drwxr-xr-x 24 root root 880 May 11 02:23 ..
srwxrwxrwx 1 pihole pihole 0 May 11 03:36 FTL.sock
I have added lists from List Generator ¦ Firebog. I added the tick lists and 2 porn lists.
I have run pihole -g to update the lists several times. They update correctly, but once it has run I notice:
[✓] Consolidating blocklists
[✓] Extracting domains from blocklists
[i] Number of domains being pulled in by gravity: 2575158
[✓] Removing duplicate domains
[i] Number of unique domains trapped in the Event Horizon: 2341775
[i] Number of whitelisted domains: 2
[i] Number of blacklisted domains: 0 <---- 0?!!!?!?
I have verified that a domain I want to block is inside of the blocklist:
pihole -q pornhub.com -exact
Exact matches for pornhub.com found in:
list.42.raw.githubusercontent.com.domains
list.43.github.com.domains
I have checked my DNS:
-> % scutil --dns | grep 'nameserver\[[0-9]*\]'
nameserver[0] : 192.168.1.112 <--- IP of my pi-hole
In actuality, when I visit https://pornhub.com, the page loads.
When running pihole -d I noticed the following
May 11 02:16:31 dnsmasq[6070]: failed to load names from /etc/pihole/local.list: No such file or directory
May 11 02:16:31 dnsmasq[6070]: failed to load names from /etc/pihole/black.list: No such file or directory
May 11 02:16:31 dnsmasq[6070]: failed to load names from /etc/pihole/gravity.list: No such file or directory
8zuax2tfk0
