Hey guys, I´m new here and have a question:
-Updating the stats on GUI
All counters are set to 0
Total queries...etc
I found different solutions but nothing worked for me, including these:
Remove the line log-queries=extra from /etc/dnsmasq.d/01-pihole.conf
sudo service pihole-FTL restart
I tried to install php5-json but its installed.
I got the data directly from the API and everything is 0
{"domains_being_blocked":124347,"dns_queries_today":0,"ads_blocked_today":0,"ads_percentage_today":0,"unique_domains":0,"queries_forwarded":0,"queries_cached":0,"clients_ever_seen":0,"unique_clients":0,"status":"enabled"}
Windows 10 (DNS entry (v4/v6) is pihole) and in the same local network.
epm028u20t
What is your Pi-hole version ? (pihole -v)
Your OS ? (cat /etc/os-release)
If you ping flurry.com (from the raspberry pi terminal) does it resolve into your Pi-hole IP ?
Pi-hole v3.3 and v3.3.1 are not supported on Jessie:
You have a few options:
- Install or update to Raspbian Stretch
- Update dnsmasq to a version > 2.72
- Join the FTLDNS beta
- Downgrade to an older version of Pi-hole
Thank for your help.
@Mcat12 Installing Debian Stretch was right and helps.
