Pihole FTL Ver. 5.8 won't update
Pi-hole present versions:
Pi-hole V5.6
FTL V5.8
Web Interface V5.8
The pi-hole web interface states there is an update for the FTL but listed below is what I get when I try pihole -up. It then suggests to do a 'sudo apt-get update' but that doesn't seem to fix the problem. Any suggestions what needs done to get FTL updated? I am not very good with linux so keep any suggestions fairly simple.
Thanks,
pi@raspberrypi:~ $ pihole -up
[i] Checking for updates...
[i] Pi-hole Core: up to date
[i] Web Interface: up to date
[i] FTL: update available
[i] FTL out of date, it will be updated by the installer.
[✓] Root user check
    .ccccc:,.
     :cccclll:.      ..,,
      :ccccclll.   ;ooodc
       'ccll:;ll .oooodc
         .;cll.;;looo:.
[✗] Update local cache of available packages
Error: Unable to update package cache. Please try "sudo apt-get update"
pi@raspberrypi:~ $ sudo apt-get update
Get:1 Index of /raspbian buster InRelease [15.0 kB]
Get:2 Index of /debian buster InRelease [32.6 kB]
Reading package lists... Done
E: Repository 'Index of /raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
E: Repository 'Index of /debian buster InRelease' changed its 'Suite' value from 'testing' to 'oldstable'
pi@raspberrypi:~ $
Thanks that fixed my problem! As I said, I don’t know much about linux yet.
