pihole-FTL 3.0 fails to start on Raspbian Jessie reboot
[FTL starts automatically after system reboot, pihole web admin console shows stats]
_[Resolved dnsmasq issue by manually installing newer dnsmasq version as indicated in; URL
However restarting Raspbian Jesse does not restart pihole-FTL
web admin shows “FTL offline” and “Lost connection to API across the top”
the command sudo service pihole-FTL status shows:
Loaded: loaded (/etc/init.d/pihole-FTL)
Active: inactive (dead)
the command sudo service pihole-FTL restart resolves the issue, until the next system reboot…
]_
[zb4n5xgdm1]
Thanks in advance!
Check dnsmasq version:
pi@noads:~ $ dnsmasq -v
Dnsmasq version 2.76
Thanks for the response.
dnsmasq is 2.76 as seen below. I had manually updated dnsmaq to the latest version. Now the only issue is that pihole-FTL fails to start automatically on system reboot.
pi@raspberrypi:~ $ dnsmasq -v
Dnsmasq version 2.76  Copyright (c) 2000-2016 Simon Kelley
Compile time options: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify
Do you have logs of when FTL tries to start on boot and fails?
I really wanted to troubleshoot this but I read on another thread (lost link) that re-installing pihole after manually updating dnsmasq helped in some cases.
So I uninstalled and reinstalled pihole and FTL starts automatically on reboot. I added a comment on the update dnsmasq post in case it helps others:
to uninstall
pihole uninstall
to install
curl -sSL https://install.pi-hole.net | bash
Thanks @deHakkelaar and @Mcat12
