Pihole blocking whitelisted domain/none blocked domain
Hey,
www.postbank.de should open without problems
pihole seems to block it (not shown in query log)
more information: https://discourse.pi-hole.net/t/banking-postbank-de-rai-login-is-not-working
(i 've been told to create a new topic for this)
zq28aoqitq
thanks a lot.
same problem for me
Can you just add it to the whiteless?
Looks like its blocked on some of my lists. Maybe just whitelists and see what happens.?
$ pihole -q postbank.de
Match found in list.42.hosts-file.net.domains :
postbank.de.kundenkonto-postbank-6756370708-postbank.ru
www.postbank.de.kundenkonto-postbank-6756370708-postbank.ru
a strange thing. the url
https://www.postbank.de/privatkunden/pk_sicherheit_kartenlimit.html
is working. the url
not
I followed the old discussion as a lurker, but i might have a solution to this problem, which i run into myself the last couple of weeks.
To me it looks like postbank.de doesn't resolve, only if Cloudflare is one of the chosen upstream-providers. After i disabled 1.1.1.1 an swiched to Google & Level3, postbank.de has no problem loading.
On top, i found a just 18 days old support-posting from a Cloudflare Staffer, explaining that they have trouble resolving postbank.de
The root cause is that postbank.de nameservers return slightly invalid proof of non-existence, which breaks resolvers implementing RFC8198 . We’re trying to work with the operator to fix this, as the only workaround is disabling DNSSEC which unfortunately brings its own problems.
@don_misu : You might want to consider removing the "solved"-Checkmark on top of the old discussion, pointing to whitelisting the scam-domain "[...]-postbank.ru" - as this does not work, it might cause more harm than good.
