Revan67
September 25, 2018, 7:57pm
1
For whatever reason when I attempt to pull up the pihole admin page i get an error message either saying the connection was refused or could not connect. I have reinstalled pihole twice on CentOS 7 fresh installs each time and the same issue keeps coming up.
IP is static 192.168.1.5
Gateway: 192.168.1.254
Everything seems to be fine allowances for firewalld are enable for http and dns and selinux is disabled. Not sure what is going on here.
Debug Token: jc5i3srv0y
jfb
September 25, 2018, 8:28pm
3
Your debug log shows lighttpd is not running, and that serves the web page.
[โ] dnsmasq daemon is unknown
[โ] lighttpd daemon is failed
[โ] pihole-FTL daemon is active
[โ] Block page X-Header: X-Header does not match or could not be retrieved.
[โ] Web interface X-Header: X-Header does not match or could not be retrieved.
The debug log didn't report any ports in use (unusual), so please post the output of this command:
sudo netstat -nltup | grep 'Proto\|:53 \|:67 \|:80 \|:471โ
jfb
September 25, 2018, 8:41pm
5
Has the web admin interface ever worked for you with this OS?
Run the following and paste the text output (no need for a screen capture)
sudo netstat
Revan67
September 26, 2018, 12:02am
6
Yes I have had it working before on CentOS.
[root@pihole ~]# sudo netstat
Active Internet connections (w/o servers)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 96 pihole.paragon.loca:ssh 192.168.1.101:49946 ESTABLISHED
Active UNIX domain sockets (w/o servers)
Proto RefCnt Flags Type State I-Node Path
unix 3 [ ] DGRAM 8009 /run/systemd/notify
unix 2 [ ] DGRAM 8011 /run/systemd/cgroups-agent
unix 2 [ ] DGRAM 11602 /run/systemd/shutdownd
unix 5 [ ] DGRAM 8028 /run/systemd/journal/socket
unix 14 [ ] DGRAM 8030 /dev/log
unix 2 [ ] DGRAM 14011 /var/run/chrony/chronyd.sock
unix 3 [ ] STREAM CONNECTED 13152
unix 3 [ ] STREAM CONNECTED 21744
unix 3 [ ] STREAM CONNECTED 21772
unix 3 [ ] STREAM CONNECTED 13153 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 17545
unix 2 [ ] DGRAM 12709
unix 3 [ ] STREAM CONNECTED 21717
unix 3 [ ] STREAM CONNECTED 21769
unix 3 [ ] STREAM CONNECTED 17155 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 21768
unix 3 [ ] STREAM CONNECTED 21715
unix 3 [ ] STREAM CONNECTED 21771
unix 3 [ ] STREAM CONNECTED 21714
unix 3 [ ] STREAM CONNECTED 21721
unix 3 [ ] STREAM CONNECTED 21765
unix 3 [ ] STREAM CONNECTED 21720
unix 3 [ ] STREAM CONNECTED 21718
unix 3 [ ] STREAM CONNECTED 21766
unix 3 [ ] STREAM CONNECTED 21724
unix 3 [ ] STREAM CONNECTED 21760
unix 3 [ ] STREAM CONNECTED 21723
unix 3 [ ] STREAM CONNECTED 21763
unix 3 [ ] STREAM CONNECTED 21762
unix 3 [ ] STREAM CONNECTED 20621
unix 2 [ ] DGRAM 63479
unix 3 [ ] STREAM CONNECTED 21748
unix 3 [ ] STREAM CONNECTED 21711
unix 3 [ ] STREAM CONNECTED 17058
unix 3 [ ] STREAM CONNECTED 17410
unix 3 [ ] STREAM CONNECTED 21747
unix 3 [ ] STREAM CONNECTED 17735
unix 3 [ ] DGRAM 12054
unix 3 [ ] STREAM CONNECTED 21708
unix 3 [ ] STREAM CONNECTED 19563 /run/systemd/journal/stdout
unix 2 [ ] DGRAM 13164
unix 3 [ ] STREAM CONNECTED 21745
unix 3 [ ] STREAM CONNECTED 21707
unix 3 [ ] STREAM CONNECTED 20568
unix 3 [ ] STREAM CONNECTED 17061
unix 3 [ ] STREAM CONNECTED 21751
unix 3 [ ] STREAM CONNECTED 17292 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 19559 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 17059 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 21750
unix 2 [ ] DGRAM 17089
unix 2 [ ] DGRAM 17081
unix 3 [ ] STREAM CONNECTED 21710
unix 3 [ ] STREAM CONNECTED 17062 /run/systemd/journal/stdout
unix 3 [ ] DGRAM 12055
unix 3 [ ] STREAM CONNECTED 21754
unix 2 [ ] STREAM CONNECTED 65590
unix 3 [ ] STREAM CONNECTED 21753
unix 3 [ ] STREAM CONNECTED 12008
unix 3 [ ] STREAM CONNECTED 13082 /run/systemd/journal/stdout
unix 2 [ ] DGRAM 21849
unix 3 [ ] STREAM CONNECTED 21759
unix 3 [ ] STREAM CONNECTED 17073 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 21757
unix 3 [ ] STREAM CONNECTED 21756
unix 3 [ ] STREAM CONNECTED 17012
unix 3 [ ] STREAM CONNECTED 21726
unix 3 [ ] STREAM CONNECTED 21700
unix 3 [ ] STREAM CONNECTED 17271 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 20431
unix 3 [ ] STREAM CONNECTED 16831
unix 3 [ ] STREAM CONNECTED 13836 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 14043 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 13989
unix 2 [ ] DGRAM 63955
unix 2 [ ] DGRAM 21675
unix 2 [ ] DGRAM 17724
unix 2 [ ] DGRAM 17549
unix 3 [ ] STREAM CONNECTED 21704
unix 2 [ ] DGRAM 13995
unix 3 [ ] STREAM CONNECTED 21703
unix 2 [ ] DGRAM 20681
unix 2 [ ] DGRAM 17295
unix 3 [ ] STREAM CONNECTED 14062 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 17712
unix 3 [ ] STREAM CONNECTED 17104
unix 3 [ ] STREAM CONNECTED 14041
unix 3 [ ] STREAM CONNECTED 17517 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 21701
unix 2 [ ] DGRAM 28086
unix 3 [ ] STREAM CONNECTED 14042
unix 3 [ ] STREAM CONNECTED 16744
unix 3 [ ] STREAM CONNECTED 13990 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 21727
unix 3 [ ] STREAM CONNECTED 21735
unix 3 [ ] STREAM CONNECTED 21736
unix 3 [ ] STREAM CONNECTED 16300
unix 3 [ ] STREAM CONNECTED 21729
unix 3 [ ] STREAM CONNECTED 21730
unix 2 [ ] DGRAM 16298
unix 3 [ ] STREAM CONNECTED 16299
unix 3 [ ] STREAM CONNECTED 21732
unix 3 [ ] STREAM CONNECTED 21733
unix 3 [ ] STREAM CONNECTED 18896 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 17261
unix 3 [ ] STREAM CONNECTED 21738
unix 3 [ ] STREAM CONNECTED 17655 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 21739
unix 3 [ ] STREAM CONNECTED 18895
unix 3 [ ] STREAM CONNECTED 20951 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 21741
unix 2 [ ] DGRAM 39490
unix 3 [ ] STREAM CONNECTED 21742
Just out of curiosity I decided to check on lighttpd
[root@pihole ~]# journalctl |grep lighttpd
Sep 25 15:30:39 pihole.paragon.local lighttpd[973]: 2018-09-25 15:30:39: (configfile.c.1451) pclose "cat external.conf 2>/dev/null"failed: Success
Sep 25 15:30:39 pihole.paragon.local lighttpd[973]: 2018-09-25 15:30:39: (configfile.c.1289) source: /etc/lighttpd/lighttpd.conf line: 94 pos: 1 parser failed somehow near here: (EOL)
Sep 25 15:30:39 pihole.paragon.local systemd[1]: lighttpd.service: main process exited, code=exited, status=255/n/a
Sep 25 15:30:39 pihole.paragon.local systemd[1]: Unit lighttpd.service entered failed state.
Sep 25 15:30:39 pihole.paragon.local systemd[1]: lighttpd.service failed.
Sep 25 15:40:23 pihole.paragon.local systemd[1]: lighttpd.service: main process exited, code=exited, status=255/n/a
Sep 25 15:40:23 pihole.paragon.local lighttpd[1785]: 2018-09-25 15:40:23: (configfile.c.1451) pclose "cat external.conf 2>/dev/null"failed: Success
Sep 25 15:40:23 pihole.paragon.local lighttpd[1785]: 2018-09-25 15:40:23: (configfile.c.1289) source: /etc/lighttpd/lighttpd.conf line: 94 pos: 1 parser failed somehow near here: (EOL)
Sep 25 15:40:23 pihole.paragon.local systemd[1]: Unit lighttpd.service entered failed state.
Sep 25 15:40:23 pihole.paragon.local systemd[1]: lighttpd.service failed.
Sep 25 16:33:58 pihole.paragon.local lighttpd[3902]: 2018-09-25 16:33:58: (configfile.c.1451) pclose "cat external.conf 2>/dev/null"failed: Success
Sep 25 16:33:58 pihole.paragon.local lighttpd[3902]: 2018-09-25 16:33:58: (configfile.c.1289) source: /etc/lighttpd/lighttpd.conf line: 94 pos: 1 parser failed somehow near here: (EOL)
Sep 25 16:33:58 pihole.paragon.local systemd[1]: lighttpd.service: main process exited, code=exited, status=255/n/a
Sep 25 16:33:58 pihole.paragon.local systemd[1]: Unit lighttpd.service entered failed state.
Sep 25 16:33:58 pihole.paragon.local systemd[1]: lighttpd.service failed.
Revan67
September 26, 2018, 12:22am
8
After revewing the journalctl I posted I searched the 'cat external.conf 2>/dev/null'
expression and found this thread. Pihole admin unavailable / lighttpd stopped ยท Issue #2391 ยท pi-hole/pi-hole ยท GitHub
Commenting out the last line of /etc/lighttpd/lighttpd.conf
corrected the issue. Lighttpd is now running and and the admin portal is up and running. Very strange....
For refence line 93 and 94 of the conf file
# Add user chosen options held in external file
#include_shell "cat external.conf 2>/dev/null"
And my current status of lighttpd
[root@pihole ~]# systemctl status lighttpd
โ lighttpd.service - Lightning Fast Webserver With Light System Requirements
Loaded: loaded (/usr/lib/systemd/system/lighttpd.service; enabled; vendor preset: disabled)
Active: active (running) since Tue 2018-09-25 20:17:43 EDT; 4min 1s ago
Main PID: 4366 (lighttpd)
CGroup: /system.slice/lighttpd.service
โโ4366 /usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf
โโ4367 /usr/bin/php-cgi
โโ4368 /usr/bin/php-cgi
โโ4369 /usr/bin/php-cgi
โโ4370 /usr/bin/php-cgi
โโ4371 /usr/bin/php-cgi
โโ4372 /usr/bin/php-cgi
โโ4373 /usr/bin/php-cgi
โโ4374 /usr/bin/php-cgi
Sep 25 20:17:43 pihole.paragon.local systemd[1]: Started Lightning Fast Webserver With Light System Requirements.
Sep 25 20:17:43 pihole.paragon.local systemd[1]: Starting Lightning Fast Webserver With Light System Requirements...
Sep 25 20:18:14 pihole.paragon.local sudo[4380]: lighttpd : TTY=unknown ; PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
bcambl
September 26, 2018, 12:37am
9
This has been fixed for next release.
system
Closed
October 17, 2018, 12:37am
10
