Originally published at: Pi-hole Web v5.18.2 and Core v5.15.1 released – Pi-hole
As always, please read through the changelog before updating with pihole -up
. (A new tag for docker image will arrive in due course.)
Update 2023-01-25:
Core v5.15.3 released to address an issue with the PHP config for the admin page:
- Change lighttpd options
min_procs
value to1
by @rdwebdesign in #5149
Web v5.18.3 released with a security fix for CVE-2023-23614:
- Fix insecure persistent login token by @4n4nk3 d31cf9d (GHSA-33w4-xf7m-f82m)
Update 2023-01-23:
Core v5.15.2 released with small patch to prevent rare issues on new installs:
- Ensure that the directory /run/lighttpd exists, and that it is owned by www-data by @PromoFaux in #5143
Notes
- When running gravity, if you receive a notice that Pi-hole is ignoring “non-domains” – this is not an error and is for information only. Sometimes lists contain hostnames or regex that are not compatible when importing with gravity – but it does not nessacerily mean action needs to be taken. In previous releases we made this appear more severe than it actually is.
- To clarify changes in the last release – if you receive a 403 response when navigating to
http://ip.address
this is entirely expected and does not constitute a bug. There are some workarounds and tweaks mentioned in the previous release notes if you absolutely have to browse to the web interface by IP. Else, just usehttp://pi.hole
or manually append/admin
when browsing via IP (or update your bookmarks)
Pi-hole Web changes:
What’s Changed
- Add default value for $ver in func.php by @yubiuser in #2497
- Show two decimals on doughnutTooltip if total share shown is less than 1% by @yubiuser in #2502
- Tweak deleting message by @yubiuser in #2498
- Attenuate non-domain warning by @yubiuser in #2507
- remove hard-coded /admin/ path by @gstrauss in #2461
- Do not return ‘false’ if IDNA<->UNICODE conversion fails by @yubiuser in #2479
New Contributors
Full Changelog: v5.18.1...v5.18.2
Pi-hole Core changes:
What’s Changed
- Include mod_accesslog with new config by @PromoFaux in #5121
- Run updatechecker after gravity by @yubiuser in #5137
- Only remove the
server.modules+=
from new config if lighttpd version is < 1.4.56 by @PromoFaux in #5133 - Cleanup if startup failed by @yubiuser in #5052
- Reduce number of false positives when gravity unable to import domains – change the wording of the output by @PromoFaux in #5128
- Change php socket path back to /run/lighttpd/ from /tmp by @PromoFaux in #5139
- Always set lighttpd config dir permissions by @yubiuser in #5038
Full Changelog: v5.15...v5.15.1
