Pi-hole V6 Custom Ports
trying to get version 6 to run on custom webport but it does not seem to work, not sure what I am doing wrong
my old start command before upgrade worked fine I would connect to port 8888 as I have a webserver running on port 80 and 443
docker run -e ServerIP=172.16.99.100 -e TZ=America/Toronto -e WEBPASSWORD=XXXX -e WEB_PORT=8888 -p 8888:8888 -p 53:53/tcp -p 53:53/udp -v /var/pihole:/etc/pihole -v /var/dnsmasq.d:/etc/dnsmasq.d pihole/pihole
the new one which seems to take the variables but the web interfaces dont work
docker run -p 53:53/tcp -p 53:53/udp -p 8888:8888/tcp -p 1443:1443/tcp -e TZ=America/Toronto -e FTLCONF_webserver_api_password="XXXX" -e FTLCONF_dns_listeningMode=all -v ./etc-pihole:/etc/pihole -v ./etc-dnsmasq.d:/etc/dnsmasq.d --cap-add SYS_ADMIN --cap-add CAP_SYS_TIME --cap-add NET_RAW --cap-add=NET_ADMIN --cap-add CAP_SYS_NICE --restart unless-stopped pihole/pihole:latest
output from running above shows 80 and 443 like it's ignoring the port settings
 [i] Setting up user & group for the pihole user
  [i] PIHOLE_UID not set in environment, using default (1000)
  [i] PIHOLE_GID not set in environment, using default (1000)
  [i] Starting FTL configuration
  [i] Assigning password defined by Environment Variable
  [i] Starting crond for scheduled scripts. Randomizing times for gravity and update checker
  [i] Ensuring logrotate script exists in /etc/pihole
  [i] Gravity migration checks
  [i] Existing gravity database found - schema will be upgraded if necessary
  [i] pihole-FTL pre-start checks
  [i] Setting capabilities on pihole-FTL where possible
  [i] Applying the following caps to pihole-FTL:
        * CAP_CHOWN
        * CAP_NET_BIND_SERVICE
        * CAP_NET_RAW
        * CAP_NET_ADMIN
        * CAP_SYS_NICE
        * CAP_SYS_TIME
  [i] Starting pihole-FTL (no-daemon) as pihole
  [i] Version info:
      Core version is v6.0 (Latest: v6.0)
      Web version is v6.0 (Latest: v6.0)
      FTL version is v6.0 (Latest: v6.0)
2025-02-19 05:11:18.371 EST [57M] INFO: ########## FTL started on 47a1bfa35a83! ##########
2025-02-19 05:11:18.371 EST [57M] INFO: FTL branch: master
2025-02-19 05:11:18.371 EST [57M] INFO: FTL version: v6.0
2025-02-19 05:11:18.371 EST [57M] INFO: FTL commit: eaa7dbb4
2025-02-19 05:11:18.371 EST [57M] INFO: FTL date: 2025-02-18 17:19:26 +0000
2025-02-19 05:11:18.371 EST [57M] INFO: FTL user: pihole
2025-02-19 05:11:18.371 EST [57M] INFO: Compiled for linux/amd64 (compiled on CI) using cc (Alpine 14.2.0) 14.2.0
2025-02-19 05:11:18.641 EST [57M] INFO: 2 FTLCONF environment variables found (2 used, 0 invalid, 0 ignored)
2025-02-19 05:11:18.641 EST [57M] INFO:    [✓] FTLCONF_dns_listeningMode is used
2025-02-19 05:11:18.641 EST [57M] INFO:    [✓] FTLCONF_webserver_api_password is used
2025-02-19 05:11:18.642 EST [57M] INFO: Wrote config file:
2025-02-19 05:11:18.642 EST [57M] INFO:  - 152 total entries
2025-02-19 05:11:18.642 EST [57M] INFO:  - 147 entries are default
2025-02-19 05:11:18.642 EST [57M] INFO:  - 5 entries are modified
2025-02-19 05:11:18.642 EST [57M] INFO:  - 1 entry is forced through environment
2025-02-19 05:11:18.644 EST [57M] INFO: Parsed config file /etc/pihole/pihole.toml successfully
2025-02-19 05:11:18.644 EST [57M] INFO: PID file does not exist or not readable
2025-02-19 05:11:18.644 EST [57M] INFO: No other running FTL process found.
2025-02-19 05:11:18.649 EST [57M] INFO: PID of FTL process: 57
2025-02-19 05:11:18.650 EST [57M] INFO: listening on 0.0.0.0 port 53
2025-02-19 05:11:18.650 EST [57M] INFO: listening on :: port 53
2025-02-19 05:11:18.652 EST [57M] INFO: PID of FTL process: 57
2025-02-19 05:11:18.653 EST [57M] INFO: Database version is 21
2025-02-19 05:11:18.653 EST [57M] INFO: Database successfully initialized
2025-02-19 05:11:18.664 EST [57M] INFO: Imported 743 queries from the on-disk database (it has 743 rows)
2025-02-19 05:11:18.664 EST [57M] INFO: Parsing queries in database
2025-02-19 05:11:18.669 EST [57M] INFO: Imported 743 queries from the long-term database
2025-02-19 05:11:18.669 EST [57M] INFO:  -> Total DNS queries: 743
2025-02-19 05:11:18.669 EST [57M] INFO:  -> Cached DNS queries: 55
2025-02-19 05:11:18.669 EST [57M] INFO:  -> Forwarded DNS queries: 645
2025-02-19 05:11:18.669 EST [57M] INFO:  -> Blocked DNS queries: 40
2025-02-19 05:11:18.669 EST [57M] INFO:  -> Unknown DNS queries: 0
2025-02-19 05:11:18.669 EST [57M] INFO:  -> Unique domains: 295
2025-02-19 05:11:18.669 EST [57M] INFO:  -> Unique clients: 2
2025-02-19 05:11:18.669 EST [57M] INFO:  -> DNS cache records: 18
2025-02-19 05:11:18.669 EST [57M] INFO:  -> Known forward destinations: 2
2025-02-19 05:11:18.825 EST [57M] INFO: FTL is running as user pihole (UID 1000)
2025-02-19 05:11:18.826 EST [57M] INFO: Reading certificate from /etc/pihole/tls.pem ...
2025-02-19 05:11:18.826 EST [57M] INFO: Using SSL/TLS certificate file /etc/pihole/tls.pem
2025-02-19 05:11:18.827 EST [57M] INFO: Web server ports:
2025-02-19 05:11:18.827 EST [57M] INFO:   - 80 (HTTP, IPv4, optional)
2025-02-19 05:11:18.827 EST [57M] INFO:   - 80 (HTTP, IPv6, optional)
2025-02-19 05:11:18.827 EST [57M] INFO:   - 443 (HTTPS, IPv4, optional)
2025-02-19 05:11:18.827 EST [57M] INFO:   - 443 (HTTPS, IPv6, optional)
2025-02-19 05:11:18.827 EST [57M] INFO: Restored 1 API session from the database
2025-02-19 05:11:18.829 EST [57M] INFO: Blocking status is enabled
2025-02-19 05:11:18.927 EST [57/T59] INFO: Compiled 0 allow and 0 deny regex for 2 clients in 0.2 msec
2025-02-19 05:11:23.070 EST [57/T58] INFO: Received 8/8 valid NTP replies from pool.ntp.org
2025-02-19 05:11:23.070 EST [57/T58] INFO: Time offset: -2.892822e+00 ms (excluded 0 outliers)
2025-02-19 05:11:23.070 EST [57/T58] INFO: Round-trip delay: 2.888209e+01 ms (excluded 0 outliers)
2025-02-19 05:11:23.071 EST [57/T179] INFO: NTP server listening on 0.0.0.0:123 (IPv4)
2025-02-19 05:11:23.071 EST [57/T180] INFO: NTP server listening on :::123 (IPv6)
Yes, that's what we've warned about in Introducing Pi-hole v6:
The exception to this is environment variables. You can start the container with the old variables in place but don’t expect them to work! It is recommended to read the docker section of our docs page before upgrading.
as well as the disclaimer for Pi-hole v6 Docker image:
!!! THE LATEST VERSION CONTAINS BREAKING CHANGES
Pi-hole v6 has been entirely redesigned from the ground up and contains many breaking changes.
Environment variable names have changed, script locations may have changed.
If you are using volumes to persist your configuration, be careful.
Replacing any v5 image (2024.07.0 and earlier) with a v6 image will result in updated configuration files. These changes are irreversible.
WEB_PORT was meant to pass a value to lighttpd's configuration in the container, in the case you ran a container where you can't have Docker map ports (and you typically wouldn't need to do both, like you did with -e WEB_PORT=8888 -p 8888:8888).
Pi-hole v6 doesn't use lighttpd anymore.
Depending on your Pi-hole container's Docker network mode, you can either map the port in your docker-compose or docker run script, or you tell Pi-hole's embedded webserver to bind a different port by setting FTLCONF_webserver_port.
seems weird but after killing the process and then editing the pihole.toml file changed the port line and now its fine restarting
port = "8888o,[::]:8888o,1443so,[::]:1443so" ### CHANGED, default = "80o,[::]:80o,443so,[::]:443so"
2025-02-19 05:22:13.750 EST [57M] INFO: ########## FTL started on 629a5a81c7fc! ##########
2025-02-19 05:22:13.750 EST [57M] INFO: FTL branch: master
2025-02-19 05:22:13.750 EST [57M] INFO: FTL version: v6.0
2025-02-19 05:22:13.750 EST [57M] INFO: FTL commit: eaa7dbb4
2025-02-19 05:22:13.750 EST [57M] INFO: FTL date: 2025-02-18 17:19:26 +0000
2025-02-19 05:22:13.750 EST [57M] INFO: FTL user: pihole
2025-02-19 05:22:13.750 EST [57M] INFO: Compiled for linux/amd64 (compiled on CI) using cc (Alpine 14.2.0) 14.2.0
2025-02-19 05:22:14.021 EST [57M] INFO: 2 FTLCONF environment variables found (2 used, 0 invalid, 0 ignored)
2025-02-19 05:22:14.021 EST [57M] INFO: [✓] FTLCONF_dns_listeningMode is used
2025-02-19 05:22:14.021 EST [57M] INFO: [✓] FTLCONF_webserver_api_password is used
2025-02-19 05:22:14.022 EST [57M] INFO: Wrote config file:
2025-02-19 05:22:14.023 EST [57M] INFO: - 152 total entries
2025-02-19 05:22:14.023 EST [57M] INFO: - 146 entries are default
2025-02-19 05:22:14.023 EST [57M] INFO: - 6 entries are modified
2025-02-19 05:22:14.023 EST [57M] INFO: - 1 entry is forced through environment
2025-02-19 05:22:14.024 EST [57M] INFO: Parsed config file /etc/pihole/pihole.toml successfully
2025-02-19 05:22:14.024 EST [57M] INFO: PID file does not exist or not readable
2025-02-19 05:22:14.024 EST [57M] INFO: No other running FTL process found.
2025-02-19 05:22:14.029 EST [57M] INFO: PID of FTL process: 57
2025-02-19 05:22:14.030 EST [57M] INFO: listening on 0.0.0.0 port 53
2025-02-19 05:22:14.030 EST [57M] INFO: listening on :: port 53
2025-02-19 05:22:14.032 EST [57M] INFO: PID of FTL process: 57
2025-02-19 05:22:14.033 EST [57M] INFO: Database version is 21
2025-02-19 05:22:14.034 EST [57M] INFO: Database successfully initialized
2025-02-19 05:22:14.047 EST [57M] INFO: Imported 859 queries from the on-disk database (it has 859 rows)
2025-02-19 05:22:14.047 EST [57M] INFO: Parsing queries in database
2025-02-19 05:22:14.052 EST [57M] INFO: Imported 859 queries from the long-term database
2025-02-19 05:22:14.052 EST [57M] INFO: -> Total DNS queries: 859
2025-02-19 05:22:14.052 EST [57M] INFO: -> Cached DNS queries: 77
2025-02-19 05:22:14.052 EST [57M] INFO: -> Forwarded DNS queries: 735
2025-02-19 05:22:14.052 EST [57M] INFO: -> Blocked DNS queries: 43
2025-02-19 05:22:14.052 EST [57M] INFO: -> Unknown DNS queries: 0
2025-02-19 05:22:14.052 EST [57M] INFO: -> Unique domains: 322
2025-02-19 05:22:14.052 EST [57M] INFO: -> Unique clients: 2
2025-02-19 05:22:14.052 EST [57M] INFO: -> DNS cache records: 19
2025-02-19 05:22:14.052 EST [57M] INFO: -> Known forward destinations: 2
2025-02-19 05:22:14.209 EST [57M] INFO: FTL is running as user pihole (UID 1000)
2025-02-19 05:22:14.209 EST [57M] INFO: Reading certificate from /etc/pihole/tls.pem ...
2025-02-19 05:22:14.209 EST [57M] INFO: Using SSL/TLS certificate file /etc/pihole/tls.pem
2025-02-19 05:22:14.210 EST [57M] INFO: Web server ports:
2025-02-19 05:22:14.210 EST [57M] INFO: - 8888 (HTTP, IPv4, optional)
2025-02-19 05:22:14.210 EST [57M] INFO: - 8888 (HTTP, IPv6, optional)
2025-02-19 05:22:14.210 EST [57M] INFO: - 1443 (HTTPS, IPv4, optional)
2025-02-19 05:22:14.210 EST [57M] INFO: - 1443 (HTTPS, IPv6, optional)
2025-02-19 05:22:14.210 EST [57M] INFO: Restored 1 API session from the database
2025-02-19 05:22:14.212 EST [57M] INFO: Blocking status is enabled
2025-02-19 05:22:14.310 EST [57/T59] INFO: Compiled 0 allow and 0 deny regex for 2 clients in 0.2 msec
2025-02-19 05:22:18.341 EST [57/T58] INFO: Received 8/8 valid NTP replies from pool.ntp.org
2025-02-19 05:22:18.341 EST [57/T58] INFO: Time offset: 7.260186e-01 ms (excluded 1 outliers)
2025-02-19 05:22:18.341 EST [57/T58] INFO: Round-trip delay: 1.407909e+01 ms (excluded 1 outliers)
2025-02-19 05:22:18.341 EST [57/T179] INFO: NTP server listening on 0.0.0.0:123 (IPv4)
2025-02-19 05:22:18.342 EST [57/T180] INFO: NTP server listening on :::123 (IPv6)
