On reboot pi-hole maintains client hostnames in top clients list
When I reboot the pi-hole (Intel NUC) the top clients list is IP addresses instead of hostnames
o3yoq3cxsg
I use my router as the DNS/DHCP server, so forward and reverse lookups work fine. It's only when I reboot the Intel NUC that pi-hole displays the clients as IP addresses when it's been displaying hostnames fine.
Doing 'sudo service pihole-FTL restart' shows the hostnames again
I'm very sorry for not having checked back with you for so long, I've been buried under additional stuff at work and haven't had much free time lately. Does your issue still exist? If so, could you please generate another debug log?
Yes, I agree with your interpretation of what is happening. This also matches what your debug log contains: one client is recognized as ra*** but for the others only IPs are shown.
We are doing final tests for FTL v2.11 which contains a bug fix that addresses your issue:
Yeah, I don't think we should do that too often to prevent flooding with PTR requests. However, I think that once per hour is a fair compromise. It also allows FTL to keep track of changing host names.
I marked your thread as solved as you gave a positive feedback.
