Pi-hole showing zero clients, zero ads blocked yet pihole -t shows active connections
Pi hole should show more than zero clients connected and show connections being blocked.
Zero clients are listed in the web interface though pihole -t shows connections streaming live as expected, however pihole -c -j shows {"domains_being_blocked":122154,"dns_queries_today":0,"ads_blocked_today":0,"ads_percentage_today":0.000000}. This went unnoticed several weeks after running a pihole -up. Running pihole -up now shows that I'm currently up to date.
6k0n9oc3rg
Are you running Jessie on your system? If so, please have a look at the posts I link herein. The problem is that Jessie has a too old version of dnsmasq which we cannot support any longer.
There are basically four things you can do:
Or update your system to the most recent version (Stretch)
I am running Stretch with Dnsmasq version 2.76.
pi@astro:~ $ lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 9.4 (stretch)
Release:        9.4
Codename:       stretch
pi@astro:~ $ dnsmasq --version
Dnsmasq version 2.76  Copyright (c) 2000-2016 Simon Kelley
Compile time options: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth     DNSSEC loop-detect inotify
This software comes with ABSOLUTELY NO WARRANTY.
Dnsmasq is free software, and you are welcome to redistribute it
under the terms of the GNU General Public License, version 2 or 3.
pi@astro:~ $
Make a new debug token.
5otehn0rf2
Run pihole -r to repair. Dnsmasq wasn't configured to use the "extra" logging format, so FTL was unable to parse the log correctly.
That seems to have fixed it! Thank you so much for your help!
