Pi-Hole plus PiVPN
Folks,
Thought I posted this two days back but search shows no trace - hope it is not duplicated.
I have Pi-Hole and PiVPN running on separate devices, did this to get used to both software setups and to save possible confusion.
I would like to consolidate both systems now so, should I add PiVPN to my Pi-Hole setup or vica versa or should it not matter.
Obviously my PiVPN is set up with additional IPTABLE rules whereas the Pi-Hole doesn't require any alteration.
Geffers
I think you did post this already: Order of Installation
Whoops, so I did.
I didn't notice it when I searched for my username; sorry.
Geffers
