I have Pi-Hole and PiVPN installed on separate Pi devices, I initially kept them apart to get used to how they worked, particularly PiVPN but would now like them on the same device.
Can anyone think of any preference to install PiVPN onto Pi-Hole device or vicar versa?
I have heard of some configuration problems installing both on same device.
It should work fine. There are a few guides out there that might help. It might make it slightly more complex to have both on one Pi, but it isn't too hard (or so I hear).
