Pi-Hole not blocking everything on iPhone
Hello,
We had a power outage for a few hours back in June. Ever since then, I've been having an issue on my iPhone where ads are no longer being blocked in the ntv app. I'm also seeing ads again on macrumors.com. Ad blocking still works perfectly on all my other devices.
Does anyone have an idea what could be causing this? Out of several iPads, iPhones, etc., this only affects this one device.
On your iPhone, go to Settings/iCloud/Private Relay and see if that's enabled; this setting will redirect your DNS queries, bypassing Pihole. Note, I think this feature is only available to iCloud+ users, so the setting may not be visible (in which case it is not enabled).
Is the device on your network or on its mobile network or VPN? Is the device in the correct Group in Pi-hole, if you are using that management feature?
Yes, Private Relay is disabled. It’s also assigned to the correct group in Pi-hole, and the correct MAC address (which I’ve already renewed) is configured.
The strange thing is that it works while I’m on vacation in Spain, both on the hotel Wi-Fi and over mobile data (via VPN). But as soon as I’m back in Germany, it stops working.
On your iPhone, what DNS addresses show up for the SSID you're connecting with? Does it match your Pihole IP address? Might provide some clues as to what's going on.
Yes, DNS Server is my pihole ip adress.
I have now reset the settings again and assigned a new MAC address to the iPhone. As soon as I am connected to my Wi-Fi at home, I see advertisements. When using mobile data via VPN or other Wi-Fi networks via VPN, everything works without advertisements.
This sounds like your Pi-hole is being by-passed, either via IPv6 or via an iOS feature labeled Connectivity Assist, available and possibly active by default on iOS 27 and above (I don't run any iPhones, so can't verify).
There are reports that Connectivity Assist -when active- seems to route DNS lookups to public DNS servers via its mobile data connection, even when connected to a wifi network.
For checking potential IPv6 by-passes, please upload a debug log and post just the token URL that is generated after the log is uploaded by running the following command from the Pi-hole host terminal:
sudo pihole -d
Hey,
thank you! It‘s the connectivity assist in iOS27. When deactivated pi-hole is blocking.
