Pi-hole not blocking ads; using DD-WRT router & VM
Pi-hole blocks ads
I can visit any website very quickly, but Pi-hole does not block ads
wdv2l3hb85
System:
Xubuntu 18.04.1 LTS running virtualbox. pihole is running on Ubuntu Server 18.04.2 in a VM in virtualbox (bridged adapter) and has a static IP from my router (DD-WRT).
For my router, I followed both Method 1 & Method 2 from this guide: How do I configure my devices to use Pi-hole as their DNS server? . I currently have Method 2 in my router.
My test page was this: Test your ad blocker (in a few simple steps) - Ads-blocker.com , but ads still show up.
Upon loading the pihole VM it goes straight to asking for the user login (pihole runs in background). Once logged in, if I use the "pihole status" command, I get the following:
sudo: unable to resolve host pihole1
[sudo] password for xxxx: *****
[green diamond] DNS service is running
[green diamond] Pi-Hole blocking is enabled
Your debug log shows that your gravity list is empty. Rebuild gravity with pihole -g -f
Thanks! That was it, solved!
