I am a happy user of Pi-Hole, having it set up a few weeks ago. Starting after about two weeks, Pi-Hole suddenly becomes unresponsive. DNS resolution is no longer possible and Pi-Hole becomes unreachable via the internal private IP. Other internal private IPs stay reachable.
This happens some 2 -3 times a day.
After a reboot, everything is back to normal, till it becomes unreachable again.
I do operate Pi-Hole on a RasperryPi. Native and without any modifications.
Dear deHakkelaar,
thank you for your hint. The RPi was indeed showing under voltage messages. I was not expecting the issue at that end. I replaced the "cheap 12W Apple" power supply with another one. And now I will observe the situation for 24h.
