Pi-Hole is forwarding local dns entries to upstream for AAAA entries
Hello,
i try to disable these forwarding. I already read this thread:
There is said, that a custom dnsmasq config should be set.
So i set:
root@dns01:~# cat /etc/dnsmasq.d/01-local.conf
local=/intern.my_url.com/
And set in pihole.toml: etc_dnsmasq_d = true
Requesting sub.intern.my_url.com is not sent upstream whether for A nor for AAAA records.
It's sent upstream.
Query received on:  2025-02-27 21:11:54.006
Client:  10.0.14.11
Query Status:  Forwarded to 10.0.13.1#53
Reply:  No reply received
Database ID:
    * Error message: curl: (22) The requested URL returned error: 400
   * A local copy of the debug log can be found at: /var/log/pihole/pihole_debug.log
What is the output of the following pcommand from the Pi-hole host OS terminal?
cat /etc/resolv.conf
That's the output:
domain intern.my_url.com
search intern.my_url.com
nameserver 10.0.13.111
10.0.13.111 is the PiHole IP.
Edit the file, change the contents to this (delete everything else)
nameserver 1.1.1.1
Close the file and try to upload a new debug log.
Hey, the debug token is: https://tricorder.pi-hole.net/mRMqYJqm/
