I have 10-12 vpn servers, each with a lot of clients, all using my single Pi-Hole server's IPv6 as the DNS resolver.
every few hours the DNS resolution on pihole becomes extremely slow or even not responding at all.
it gets resolved by a restart, but I'm getting tired xD.
All servers are hosted on Hetzner and properly firewalled.
plus, all servers have enough resources and even when it doesn't respond, it's not hitting any limits.
Okay, so let's find out what is happening here. From looking at your debug log, I first have a few suggestions:
interface = "\"\"" ### CHANGED, default = ""
you should remove the extra escaped quotes, even when this does not matter in this context.
As it seems to be a reproducible issue for you, I'd like you to take a look at /var/log/pihole/FTL.log at the time this is happening. In your debug log I have seen a bunch of errors like:
2023-12-16 08:11:53.841 [9272M] ERR: SQLite3 message: cannot open file at line 44110 of [ebead0e723] (14)
2023-12-16 08:11:53.841 [9272M] ERR: SQLite3 message: os_unix.c:44110: (0) open(/etc/pihole/pihole-FTL.db) - (14)
2023-12-16 08:11:53.841 [9272M] ERR: Error while trying to open database: unable to open database file
possibly indicating a file system issue. Even when this should not affect DNS resolution, there may be some obscure hidden bug only happening in such a scenario.
If you do not see anything interesting when this happens, it's getting tricky. You could then try setting various debug flags in pihole.toml to true[1] but be prepared that your FTL.log can grow quickly.
And when I say quickly I do mean possibly gigabytes within hours given you say you have
so please make sure you have room for this. This will obviously making hunting the bug very tricky too as we may have millions of lines. There is also debug.all but this would make it even more tricky...
You do not need to restart pihole-FTL when modifying debug settings, they are automatically applied ↩︎
Thanks for your reply. on top of everything else, disabling "database.DBexport" resolves the issue. I also noted that the pihole-FTL.db gets quite large over time. (last time I checked was 2.1GB).
because the dns server has a lot of clients. (sometimes more than 2000 concurrent IPv6 clients)
the part of admin panel "Client activity over last 24 hours" takes a few minutes to load and makes the whole admin panel unresponsive. is there a solution for that? maybe disabling that part?
I vaguely remember we have discussed this somewhere in the past but it seems there was no conclusion. I will think out aloud in the following. No guarantee for a linear chain of thoughts!
There are two ways of implementing this:
Reduce the amount of data that is sent via the API.
This is actually more tricky that it seems. FTL does not sort global maximum clients but, instead sends the data for all clients. We could rather easily say: Don't send more than the data concerning 20[1] clients. But this comes with no guarantee that these are also the most active ones (hint: they will often not be).
Send the full amount of data and have the frontend (Javascript) deal with reducing it
This has the advantage of that the user's PC running the browser is most often much much beefier than the tiny little thing running Pi-hole but this has several drawbacks as well, most obvious the possible enormous amount of API data that is being returned and then this needing to be handled inside the browser (well, we are talking KB to MB of JSON, not even close to GB here even with thousands of clients)
No. #2 seems to be worse than no. #1 so this is likely the way we go.
But I also don't like the kind of uncertainty that lies in this. We could first make FTL determine the 20[1:1] most active clients and then use these to populate the array for the graph. This would do away with said uncertainty but is more work. Given you have many clients it may actually be a lot of work. However, we should be able to assume that a Pi-hole serving thousands of clients concurrently runs on something better than a PogoPlug[2] so this price may be okay to pay.
Opinions?
The number 20 is kind of an arbitrary choice here, it can surely be discussed ↩︎↩︎
I totally agree. let the machine lift the heavy things instead of the poor browser.
I also think that in cases like mine where we're dealing with thousands of clients, super accurate reportings aren't as neccessary as other things (like the snappyness of the UI) to be our #1 priority.
or at laest we can keep the accuracy but generate the graphs on demand, not automatically on the index page of Pi-Hole admin.
I have an update on this. previously, my vpn servers used the IPv6 as their dns resolver and it had the problem of stopping (without any errors or resource exhaustion) but as soon as I changed the dns resolver to the IPv4 of the Pi-Hole server, the problem stopped reoccuring.
note that the amount of queries and concurrent requests are the same, but Pi-Hole is no longer having problems even in the most busy hours of the day. so what's the catch?
2023-12-22 11:26:34.721 [2485M] ERR: Error while trying to open database: unable to open database file
2023-12-22 11:26:34.721 [2485M] WARNING: Failed to open database in backup_db_sessions()
and a "service pihole-FTL restart" solves it.
And no. when Pi-Hole's IPv6 is used, each 'individual' client sees it. the vpn servers mostly have a /112 IPv6 range routed to them and each client gets a /128 so the number of clients shown on Pi-Hole goes up to the total number of vpn clients. (which is 2500+).
And now that I'm using the IPv4, when that db file gets large enough, the same thing happens, it just takes a longer time. and when it happens, either it the dns resolution becomes extremely slow or it doesn't respond at all. so basically I guess whatever the problem is, its about the database file.
There is nothing before this? The reason I'm asking is that this is a message that is only shown when FTL is shutting down. Quite obvious it stop reacting when it shut down
So now we need to find out why it was shut down and if this was triggered internally or externally.
It stopped working again. note that the logs were cleared with "rm -f /var/log/pihole/*" and then the "pihole restartdns" were run. used it for a few hours, and now this is the log files in the 'unresponsive' state.
FTL.log.1:
2023-12-22 23:51:10.014 [35747M] INFO: Shutting down... // exit code 0 // jmpret 0
2023-12-22 23:51:10.329 [35747M] INFO: Finished final database update
2023-12-22 23:51:10.329 [35747M] INFO: Waiting for threads to join
2023-12-22 23:51:10.329 [35747M] INFO: Thread database (0) is idle, terminating it.
2023-12-22 23:51:10.329 [35747M] INFO: Thread housekeeper (1) is idle, terminating it.
2023-12-22 23:51:10.329 [35747M] INFO: Thread DNS client (2) is idle, terminating it.
2023-12-22 23:51:10.329 [35747M] INFO: All threads joined
2023-12-22 23:51:10.333 [35747M] INFO: Stored 1 API session in the database
2023-12-22 23:51:12.320 [35747M] INFO: ########## FTL terminated after 12m 55s (code 0)! ##########
2023-12-22 23:51:12.397 [36017M] INFO: ########## FTL started on Stark-Smart-DNS! ##########
2023-12-22 23:51:12.397 [36017M] INFO: FTL branch: development-v6
2023-12-22 23:51:12.397 [36017M] INFO: FTL version: vDev-7b59c65
2023-12-22 23:51:12.397 [36017M] INFO: FTL commit: 7b59c651
2023-12-22 23:51:12.397 [36017M] INFO: FTL date: 2023-12-17 06:52:04 +0100
2023-12-22 23:51:12.398 [36017M] INFO: FTL user: pihole
2023-12-22 23:51:12.398 [36017M] INFO: Compiled for linux/arm64/v8 (compiled on CI) using cc (Alpine 12.2.1_git20220924-r10) 12.2.1 20220924
2023-12-22 23:51:12.400 [36017M] INFO: Parsed config file /etc/pihole/pihole.toml successfully
2023-12-22 23:51:12.400 [36017M] INFO: PID of FTL process: 36017
2023-12-22 23:51:12.401 [36017M] INFO: Database version is 16
2023-12-22 23:51:12.401 [36017M] INFO: Database successfully initialized
2023-12-22 23:51:12.406 [36017M] INFO: -> Total DNS queries: 0
2023-12-22 23:51:12.406 [36017M] INFO: -> Cached DNS queries: 0
2023-12-22 23:51:12.407 [36017M] INFO: -> Forwarded DNS queries: 0
2023-12-22 23:51:12.407 [36017M] INFO: -> Blocked DNS queries: 0
2023-12-22 23:51:12.407 [36017M] INFO: -> Unknown DNS queries: 0
2023-12-22 23:51:12.407 [36017M] INFO: -> Unique domains: 0
2023-12-22 23:51:12.407 [36017M] INFO: -> Unique clients: 0
2023-12-22 23:51:12.407 [36017M] INFO: -> Known forward destinations: 0
2023-12-22 23:51:12.407 [36017M] INFO: listening on 0.0.0.0 port 53
2023-12-22 23:51:12.407 [36017M] INFO: listening on :: port 53
2023-12-22 23:51:12.408 [36017M] INFO: PID of FTL process: 36017
2023-12-22 23:51:12.408 [36017M] INFO: FTL is running as user pihole (UID 998)
2023-12-22 23:51:12.408 [36017M] INFO: Reading certificate from /etc/pihole/tls.pem ...
2023-12-22 23:51:12.408 [36017M] INFO: Using SSL/TLS certificate file /etc/pihole/tls.pem
2023-12-22 23:51:12.410 [36017M] INFO: Restored 1 API session from the database
2023-12-22 23:51:12.414 [36017M] INFO: Blocking status is enabled
2023-12-22 23:51:12.517 [36017/T36018] INFO: Compiled 0 allow and 17 deny regex for 3 clients in 6.9 msec
pihole.log.1:
Dec 22 23:51:12 dnsmasq[36017]: started, version pi-hole-v2.89-e1de9c2 cache disabled
Dec 22 23:51:12 dnsmasq[36017]: compile time options: IPv6 GNU-getopt no-DBus no-UBus no-i18n IDN2 DHCP DHCPv6 Lua TFTP no-conntrack ipset no-nftset auth cryptohash DNSSEC loop-detect inotify dumpfile
Dec 22 23:51:12 dnsmasq[36017]: using nameserver 8.8.8.8#53
Dec 22 23:51:12 dnsmasq[36017]: using nameserver 8.8.4.4#53
Dec 22 23:51:12 dnsmasq[36017]: using only locally-known addresses for onion
Dec 22 23:51:12 dnsmasq[36017]: using only locally-known addresses for bind
Dec 22 23:51:12 dnsmasq[36017]: using only locally-known addresses for invalid
Dec 22 23:51:12 dnsmasq[36017]: using only locally-known addresses for localhost
Dec 22 23:51:12 dnsmasq[36017]: using only locally-known addresses for test
Dec 22 23:51:12 dnsmasq[36017]: using only locally-known addresses for lan
Dec 22 23:51:12 dnsmasq[36017]: read /etc/hosts - 16 names
Dec 22 23:51:12 dnsmasq[36017]: read /etc/pihole/local.list - 0 names
Dec 22 23:51:12 dnsmasq[36017]: read /etc/pihole/hosts/custom.list - 0 names
root@Stark-Smart-DNS:/etc/pihole# ls -ls
total 402260
4 -rw-rw---- 1 pihole pihole 65 Dec 20 12:48 adlists.list
4 drwxr-xr-x 2 pihole pihole 4096 Dec 21 00:01 config_backups
0 -rw-rw---- 1 pihole pihole 0 Dec 19 12:42 dhcp.leases
8 -rw-rw---- 1 pihole pihole 5037 Dec 20 14:56 dnsmasq.conf
4 -rw-rw---- 1 pihole pihole 651 Dec 20 14:43 dns-servers.conf
4 -rw-rw---- 1 pihole pihole 15 Dec 20 12:47 ftlbranch
104 -rw-rw---- 1 pihole pihole 106496 Dec 22 07:49 gravity.db
104 -rw-rw---- 1 pihole pihole 106496 Dec 20 12:48 gravity_old.db
4 drwxr-xr-x 2 pihole pihole 4096 Dec 20 12:48 hosts
4 -rw-rw---- 1 pihole pihole 408 Dec 20 14:43 install.log
4 -rw-rw---- 1 pihole pihole 65 Dec 20 14:44 local.list
4 -rw-r--r-- 1 root root 245 Dec 19 12:42 logrotate
3044 -rw-rw---- 1 pihole pihole 3117056 Dec 20 12:48 macvendor.db
4 drwxr-xr-x 2 pihole pihole 4096 Dec 19 12:42 migration_backup
398904 -rw-rw-r-- 1 pihole pihole 408473600 Dec 23 14:04 pihole-FTL.db
44 -rw-rw---- 1 pihole pihole 44764 Dec 21 00:01 pihole.toml
4 -rw-rw---- 1 pihole pihole 441 Dec 20 08:05 setupVars.conf
4 -rw-rw---- 1 pihole pihole 668 Dec 20 12:48 tls.crt
4 -rw-rw---- 1 pihole pihole 956 Dec 20 12:48 tls.pem
4 -rw-rw---- 1 pihole pihole 380 Dec 22 23:32 versions
root@Stark-Smart-DNS:/etc/pihole# du -msh
394M .
So this confirms it: Something on your system is shutting down FTL intentionally. But we don't know who is doing that.
My suggestion would be to run
sudo pihole checkout ftl new/who_murders_me
in about half an hour from now (when the binaries are all built). When FTL from this branch is asked to terminate, it tries to determine who is the murderer and logs a line like
2023-12-23 16:00:47.926 [2260911M] INFO: Asked to terminate by "/lib/systemd/systemd --system --deserialize 56" (PID 1, user root UID 0)
This should help finding what is going on and seems useful to have.
