Set the DHCP to Pi-hole, and disable DHCP on the router.
I flipped DHCP to disabled on my router and clicked enable on Pi-Hole, but still no luck
Try renew DHCP lease on the Linux client:
sudo dhclient -r; sudo dhclient -v
Restart the router and renew the DHCP lease on all connected clients.
I accidentally unplugged the ethernet cable from the raspberry pi, when I plugged it back in everything started to work fine. Thank you guys for all the help! I really appreciate it !
