Pi-hole DNS not resolving
Hey ho,
So I have the following problem.
As soon as I have the Pihole IP set up as DNS Server on my desktop, no website is getting resolved anymore. I can access them via IP, but not via FQDN/Domain Name.
Entered its' IP in v4 and v6, also tried deactivating v6.
I can reach the admin interface via Domain when the DNS is set to automatic but only via IP when it's set to the Pihole IP.
pihole up shows:
::: Checking for updates...
::: Pi-hole Core: up to date
::: FTL: up to date
::: Web Interface: up to date
::: Everything is up to date!
pihole status shows:
::: DNS service is running
::: Pi-hole blocking is Enabled
Any idea on this case?
Greetings & Thanks in advance,
Andi
If there is no name resolution at all, it may be a gateway issue.
You should make sure your Pi-hole can reach the Internet.
You can also send us the token generated by
and we can take a look.
The Pi-hole can reach the internet.
Pinging e.g. google.com works and so does the web interface.
pihole -d gave me the token 3mch8pesyf .
I'm seeing several different issues in your log. Can you please run a pihole -r to repair your configuration? If that doesn't work, choose Reconfigure and make sure all the settings are correct for your network.
I've updated Ubuntu and done a full Reconfigure of Pi-hole, but I'm still getting the DNS error in my browser and I can still access sites via IP.
Done another debugging, token: gsxollrt86
What's the output of these commands:
head /var/log/pihole.log
head /etc/pihole/gravity.list
lsof -i -P -n | awk -F' ' '/LISTEN/ {print $9, $1}' | sort -n | uniq | cut -d':' -f2
netstat -tulpn
Feel free to sent this info to tricorder as well. You can save the output of the commands to a file and then send it to tricorder:
I've decided to use pastebin. Here are the outputs:
pihole.log: pihole.log - Pastebin.com
gravity.list: gravity.list - Pastebin.com
lsof: lsof - Pastebin.com
netstat: netstat - Pastebin.com
You have BIND installed, too? It may be conflicting with dnsmasq
Thanks, this fixed it.
I didn't even know that I had BIND installed, maybe it was preinstalled on the Image (it's an image from a webhoster) or installed with something else.
Uninstalled it and everything is running fine now :slight_smile:
A post was split to a new topic: DNS not resolving
