Pi-hole Core/Web v5.2.2 and FTL v5.3.4 released!
Originally published at: https://pi-hole.net/2020/12/24/pi-hole-core-web-v5-2-2-and-ftl-v5-3-3-released/
It’s beginning to look a lot like Christmas….
No shiny new features for you this time, but fixes for bugs identified since the last version, and a few tweaks here and there. Full details below.
As ever, before running pihole -up to update, make sure you’ve read over the release notes to ensure there’s nothing that would stop you from upgrading. Pi-hole docker containers will be updated in due course… (before anyone asks “Where’s the Docker update??”)
Update: Just pushed the :v5.3.4 tags for Docker. Merry Christmas!
Core:
  • Update pihole-FTL man-pages #3883 (@ganto)
  • piholeDebug: Fix warning if lighttpd/php are not installed #3902 (@ganto)
  • piholeDebug: Diagnose output if (Web) git directory is not found #3904 (@ganto)
  • Fix chronometer output if web interface is not installed #3900 (@ganto)
  • Adding comma to the adlist table format #3909 (@onegreydot)
  • Add fallback for arch detection on i386/x86_64 #3940 (@dschaper)
Web:
  • Change color of blocked queries in dashboard piechart forward destination to red #1594 (@yubiuser)
  • Switch from fontawesome webfonts to SVG + JS #1619 (@notriddle)
  • Show status of retried DNS queries in query log correctly #1646 (@dnhp)
  • Require auth for recentBlocked function #1650 (@aidentwoods)
  • Use hash_equals when comparing to pwhash from cookie #1652 (@aidantwoods)
  • Validate target domain for CNAME records #1662 (@yubiuser)
  • Fix transactions in groups.php #1664 (@DL6ER)
  • Prevent malformed DNS queries executing JS on querylog/long term query pages #1665 (@PromoFaux)
FTL:
New
  • Immediately resolve host names of clients and upstream destinations #996
  • Add UNKNOWN option for REFRESH_HOSTNAME #985
  • Add lua and luac drop-in support #968
  • Show BOOTP server and file strings used by TFTP in dhcp-discover #963
Tweaks
  • Add DEBUG_EXTRA flag #994
  • Improve compatibility with old (ancient) kernels #984 #969
  • Add more debugging output for domain reloading (on receipt of SIGHUP) #970
  • Implement interrupt-safe systemcalls #969
Fixes
  • Escape spaces by ~ in domains and hostnames to fix API issues with such names #997
  • Fix CNAME query blocking mode #995
  • Fix crashing forks when regex structure changed #982
  • Fix freeing regex pointers to free the global objects #971
  • Fix possible crash in parse_FTLconf() #967
  • Update dnsmasq version to 2.82 #964
What a nice Present thank you and merry Christmas :slight_smile:
Good stuff! Thank you folks!
Thanks for the quick docker update. Give's me some hobby time this Christmas.
I noticed that when I did an update to my PiHole, it reports Core/Web 5.2.2, but FTL is now 5.3.4
I'm guessing there will be an announcement releasing FTL v5.3.4 soon? :wink:
This post is the announcement:
Not sure what is wrong, but while updating (pihole -up) there is an error
[i] Target: https://mirror1.malwaredomains.com/files/justdomains
[✗] Status: Not found
[✗] List download failed: no cached list available
Known issue - you can delete this list:
