I've set up a pihole as the LAN dhcp server + upstream dns, it has the static ip .3 and the S.O. boot is ok, but after some minutes the pihole lose its own IP address (.3)
to keep the .3 ip and keep serving ip allocations for other devices
O.S. details:
$uname -r
6.1.0-rpi8-rpi-v8
$uname -a
Linux rpi-srv 6.1.0-rpi8-rpi-v8 #1 SMP PREEMPT Debian 1:6.1.73-1+rpt1 (2024-01-25) aarch64 GNU/Linux
$lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 12 (bookworm)
Release: 12
Codename: bookworm
pihole boot with IP .3, then after 2-3 minutes lose that IP
$ip add
eth0 no ip address details
so internet connection lost, dns not working
debug log
[ Followon new topic from Pihole as DHCP on bookworm ]
This might benefit from a fresh set of eyes. I can't work out what's going on. A moment ago (in the previous thread) your debug log looked good. In this one, the Pi-hole DHCP server is not reponding to itself and Pi-hole is flagging such packets, external adlists are indeed unreachable. Yet it does have the static IP assigned as expected.
Is this a fresh install or was it modified from the setup in the opening post on the other thread where you had this same problem? It looks like it was modified, since the log references earlier nameserver options?
Is there anything else running on the OS worth noting? Any kind of firewall? It looks like the OS retains its IP addressing but network traffic gets blocked, causing external lists to fail and DHCP to go nowhere.
I just installed the Pihole on my rpi 3b+, I've been using it before and love it, so just made a fresh install on the Pihole, trying to get it up an running as it used to be.
I've ufw active and enabled ports as per doc
$sudo ufw status
To Action From
22/tcp ALLOW Anywhere
80 ALLOW Anywhere
80/tcp ALLOW Anywhere
53/tcp ALLOW Anywhere
53/udp ALLOW Anywhere
67/udp ALLOW Anywhere
67/tcp ALLOW Anywhere
4711/tcp ALLOW Anywhere
5335/tcp ALLOW Anywhere
22/tcp (v6) ALLOW Anywhere (v6)
80 (v6) ALLOW Anywhere (v6)
80/tcp (v6) ALLOW Anywhere (v6)
53/tcp (v6) ALLOW Anywhere (v6)
53/udp (v6) ALLOW Anywhere (v6)
67/udp (v6) ALLOW Anywhere (v6)
67/tcp (v6) ALLOW Anywhere (v6)
4711/tcp (v6) ALLOW Anywhere (v6)
5335/tcp (v6) ALLOW Anywhere (v6)
A DHCP server can't give an IP to itself.
You need a static IP.
related to the addlists, I've fixed the typo (change tap://... for http://..) and now it works without any issue I can see the domain list being updated
See previous topic – IP is .3 static assigned in NM, DHCP range is .4 upwards
Pihole has the static ip config (trying to use .3) and DHCP range from .4 to .250 and .1 as gateway (same as router)
This seems like a networking or perhaps hardware issue.
Even if there is no IP address, the output should at least consist of two lines
link/ether <redacted> brd ff:ff:ff:ff:ff:ff
How did you go about assigning a static IP address to the machine hosting your Pi-hole?
What's the result of
sudo awk '/\[ipv4\]/,/method/' /etc/NetworkManager/system-connections/*.nmconnection
not sure why and/or what was the fix, but after some reboots of router and rpi, now it is working without any issue
