I deactivated dhcp on my router and activated it in pi-hole, but now the devices dont get ip adresses anymore
tpy0ky4370!
Your debug log shows some setup problems with the Pi. You have Pi-Hole configured for IP 2 on ethernet, but there is no IPv4 address on that interface.
[✗] No IPv4 address(es) found on the eth0 interface.
[✗] No IPv6 address(es) found on the eth0 interface.
[i] Default IPv4 gateway: 192.168.0.1
* Pinging 192.168.0.1...
[✓] view.atdmt.com.26110.9201.302br.net is 0.0.0.0 via localhost (127.0.0.1)
[✗] Failed to resolve view.atdmt.com.26110.9201.302br.net via Pi-hole (192.168.0.2)
Check that the Pi has a valid IPv4 address: ip a
Look in the router and see which IP the Pi is using to connect to the router.
With that IP reserved or static, reconfigure Pi-Hole for that IP - pihole -r and select "reconfigure"
