Pi-hole and Virgin MediaHub problem
I've installed pi-hole on my P3b+ as per the instructions, and it is working perfectly on the Rpi using chromium.
However, because I'm using a VirginMedia hub I can't define pi-hole's DNS server. I tried setting the DNS server address on my Mac, but then no internet page will load!
Apologies if this is a simple question / known solution. Best I could come up with searching the forums is that I need to buy a 3rd party router, but hopefully there's a software based solution.
Debug token yr4wmdkhpa
Thanks!
You can use your Pi-Hole as the DHCP server:
Your debug log shows no IP addresses assigned to the Pi. Pi-Hole is listening on 192.168.0.22, but that is not the IP of the Pi. Check in your router settings and verify that the Pi has a reserved IP of 22.
[✗] No IPv4 address(es) found on the eth0 interface.
[✗] No IPv6 address(es) found on the eth0 interface.
[i] Default IPv4 gateway: 192.168.0.1
   * Pinging 192.168.0.1...
Thanks
I started by disabling my router DHCP server and enabling Pi-hole DHCP, but for some reason that stopped my Pi connecting. The Pi did have a reserved IP of 22. I ran the debug again and got lots of errors, so I reinstalled and ran debug - code is czcj6lw3aj
The debug is still saying the gateway didn't respond. I used netstat -nr | grep default to confirm that the gateway is 192.168.0.01
The pi seems to be on 192.168.0.12 and the Hub has a reserved IP of 192.168.0.12/24
Thanks again for helping - sorry if the problem is my technical mistakes!
You have the same problem as before.
I think it was me being stupid.... I was connecting via wifi not ethernet so I reconfigured with wlan and now it works perfectly!
I've configured my devices to use the pi-hole DNS rather than using pi-hole as the DHCP - should I swap or does it not really matter if it works?
Thanks again
It is your preference. Some IOT devices don't have configurable DNS settings - they take whatever DNS is provided during the DHCP handshake. If you have none of those and your current setup works, then stick with it.
