I have
Running with unbound running on a Raspberry Pi 2 Model B Rev 1.1 at
http://192.168.1.210/admin/login
once authenticated brought to
when my admin session times out, no link on whatever web interface page I am at can get me back to the login url. Im forces to go back to my bookmark.
expected behavior would be at session time out the very top left link Pi-hole with the url to http://192.168.1.210/admin/ SHOULD take me to http://192.168.1.210/admin/login .
Im not sure if this bookmark requirement is planned or something amiss in my config.
Thanks!
There is nothing showing an issue in your log.
Does the same happen if you try to access from a different device or using a different browser?
D_S
April 25, 2025, 10:50pm
5
i had this issue and i had to delete my tab/bookmark and "re-map" it. been working ever since.
Still have not tried other browsers, except for Firefox on my Android and after time out, the login screen appears as it should..
Not a high priority, but at least am curious so will look into it some more
system
Closed
May 18, 2025, 8:25am
7
