Per client White and Black Lists
  1. It would be great if you could create Black Lists for individual devices or a device groups.
For example Group: Kids . --> block you tube etc.
  1. Even better if you could schedule it.
  2. Have a filtered Dashboard based on Groups.
Best regards
Stefan
This is technically not feasible. The DNS server is not able to respond individually to different clients. The required code changes would be way too extensive.
See also this
One year later, I feel like I should update this. Pi-hole has moved quite a bit in this time, even though much of the movement is in the interiors and mostly hidden from the end-user. However, parts of the changes enables us to redesign critical parts. I'm not yet saying that we are going to have it in the end, however, we already have a working variant of the FTL daemon which is actually able to do per-client black- and white listing. Even per-client blocking lists is already implemented.
There are still technical details to clarify. While there are important benefits, such as a massively reduced memory footprint, there are also downsides, one being the notable degraded regex performance. This is caused by us not being able to apply some performance tricks we invented for our current universal (as in the opposite of per-client) implementation.
Stay tuned!
Update: I was able to resolve the mentioned performance penalties this morning. First tests look very promising.
Implemented in pihole v5.0. via Group management.
