Pandora on android still gets ads
Android still gets pandora ads - i get they may be tricky w/ their strategy but it can be beat right?
After all, using adblock on chrome (desktop) i get no ads.
I tried blacklisting URLs based on this post; but still getting ads.
Unrelated question - how do you make suggestions for "master" lists like gravity? for example - it seems adserver.pandora.com is not in the default pi-hole ad blocking source lists yet.
Since Pi-hole does not work like your normal browser ad blocker, so it might not be possible to block their style of ads. You can manually blacklist domains, and this guide will be helpful:
Pi-hole adds many lists together to create the gravity list, so you can add lists such as the ones found on this site to block more domains:
https://wally3k.github.io/
