Scuk
October 28, 2020, 7:35pm
1
Padd to continue running without issue.
Padd shutting down due to a connection reset after several hours of running. Padd restarts without issue. No issues seem to exist in Pi-hole.
https://tricorder.pi-hole.net/yfpcgmyse1
Has pihole-FTL
restarted? That error is in a section that has an open file handle to /dev/tcp/localhost/4711
so anything that closes that file handle will crash PADD.
Which probably isn't a good idea to do, @DL6ER will holding open the port cause you any issues? PADD/padd.sh at 1c93c02a36140d30cdc14369e27a592b70cf47f5 · pi-hole/PADD · GitHub
Scuk
October 29, 2020, 12:36am
3
I have not restarted FTL. This happens every 3-4 hours and pi-hole has been up and working for days. I did forward port 4711 TCP on my pi, but it didn't seem to make a difference.
Scuk
October 29, 2020, 1:29am
5
Experiment. Just in my router config. Port forwarding external for raspberry pi only.
Scuk
October 29, 2020, 2:26am
7
ok......
Do you have a suggestion?
Scuk
October 29, 2020, 2:38am
9
How to stop this error from occurring.....
DL6ER
October 29, 2020, 10:17am
10
Resource-wise, maybe. Every connection gets it's dedicated thread to avoid any blocking inside FTL. An open connection without any traffic on it should only sit there, waiting for input to come and isn't doing anything else than waiting. When the connection is closed, the thread is terminated and resources are returned to the system.
@Scuk Do you see any lines when running
cat /var/log/pihole-FTL.log
Scuk
October 29, 2020, 11:33am
12
__ __ __
|__) /\ | \| \ Pi-hole® v5.1.2, Web v5.1.1, FTL v5.2, PADD v3.4
| /--\|__/|__/ [✓] Core [✓] FTL [✓] Your system is healthy.
STATS =========================================================================
Blocking: 281288 domains Piholed: [■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■] 7.2%
Clients: 48 4430 out of 61252 queries
Latest: beacons.gvt2.com
Top Ad: msmetrics.ws.sonos.com
Top Dmn: share-service-download-bucket.s3.amazonaws.com
Top Clnt: homeassistant.lan
FTL ===========================================================================
PID: 19641 CPU Use: 0.3% Mem. Use: 0.1%
DNSCache: 1628 insertions, 0 deletions, 10000 total entries
NETWORK =======================================================================
Hostname: pihole.lan
IPv4 Adr: 192.168.1.43/24 IPv6 Adr:
DNS ===========================================================================
Servers: 2 servers
DNSSEC: Disabled Conditional Fwding: Disabled
DHCP ==========================================================================
DHCP: Enabled IPv6 Spt: Disabled
Range: 192.168.1.2 - 192.168.1.254
SYSTEM ========================================================================
Uptime: 8 days, 23 hours, 37 minutes Memory: [■·········] 5.4%
CPU Temp: 41.4°C CPU Load: 0.34, 0.29, 0.36 CPU Load: [■·········] 8.5%
pi@pihole:~ $ cat /var/log/pihole-FTL.log
[2020-10-29 00:07:41.709 17478M] Shutting down...
[2020-10-29 00:07:41.779 17478M] Finished final database update
[2020-10-29 00:07:41.786 17478M] ########## FTL terminated after 3.572903e+03 s! ##########
[2020-10-29 00:07:43.004 19750M] Using log file /var/log/pihole-FTL.log
[2020-10-29 00:07:43.004 19750M] ########## FTL started! ##########
[2020-10-29 00:07:43.005 19750M] FTL branch: master
[2020-10-29 00:07:43.005 19750M] FTL version: v5.2
[2020-10-29 00:07:43.005 19750M] FTL commit: dbd4a69
[2020-10-29 00:07:43.005 19750M] FTL date: 2020-08-09 22:09:43 +0100
[2020-10-29 00:07:43.005 19750M] FTL user: pihole
[2020-10-29 00:07:43.005 19750M] Compiled for armhf (compiled on CI) using arm-linux-gnueabihf-gcc (Debian 6.3.0-18) 6.3.0 20170516
[2020-10-29 00:07:43.005 19750M] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2020-10-29 00:07:43.005 19750M] SOCKET_LISTENING: only local
[2020-10-29 00:07:43.005 19750M] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2020-10-29 00:07:43.005 19750M] MAXDBDAYS: max age for stored queries is 365 days
[2020-10-29 00:07:43.005 19750M] RESOLVE_IPV6: Resolve IPv6 addresses
[2020-10-29 00:07:43.005 19750M] RESOLVE_IPV4: Resolve IPv4 addresses
[2020-10-29 00:07:43.005 19750M] DBINTERVAL: saving to DB file every minute
[2020-10-29 00:07:43.005 19750M] DBFILE: Using /etc/pihole/pihole-FTL.db
[2020-10-29 00:07:43.005 19750M] MAXLOGAGE: Importing up to 24.0 hours of log data
[2020-10-29 00:07:43.005 19750M] PRIVACYLEVEL: Set to 0
[2020-10-29 00:07:43.005 19750M] IGNORE_LOCALHOST: Show queries from localhost
[2020-10-29 00:07:43.005 19750M] BLOCKINGMODE: Null IPs for blocked domains
[2020-10-29 00:07:43.005 19750M] ANALYZE_ONLY_A_AND_AAAA: Enabled. Analyzing only A and AAAA queries
[2020-10-29 00:07:43.005 19750M] DBIMPORT: Importing history from database
[2020-10-29 00:07:43.005 19750M] PIDFILE: Using /run/pihole-FTL.pid
[2020-10-29 00:07:43.005 19750M] PORTFILE: Using /run/pihole-FTL.port
[2020-10-29 00:07:43.005 19750M] SOCKETFILE: Using /run/pihole/FTL.sock
[2020-10-29 00:07:43.005 19750M] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2020-10-29 00:07:43.006 19750M] MACVENDORDB: Using /etc/pihole/macvendor.db
[2020-10-29 00:07:43.006 19750M] GRAVITYDB: Using /etc/pihole/gravity.db
[2020-10-29 00:07:43.006 19750M] PARSE_ARP_CACHE: Active
[2020-10-29 00:07:43.006 19750M] CNAME_DEEP_INSPECT: Active
[2020-10-29 00:07:43.006 19750M] DELAY_STARTUP: No delay requested.
[2020-10-29 00:07:43.006 19750M] NICE: Set process niceness to -10 (default)
[2020-10-29 00:07:43.006 19750M] BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2020-10-29 00:07:43.006 19750M] NAMES_FROM_NETDB: Enabled, trying to get names from network database
[2020-10-29 00:07:43.006 19750M] Finished config file parsing
[2020-10-29 00:07:43.007 19750M] Database version is 7
[2020-10-29 00:07:43.007 19750M] Database successfully initialized
[2020-10-29 00:07:43.008 19750M] New upstream server: 1.0.0.1 (0/1024)
[2020-10-29 00:07:43.010 19750M] Resizing "/FTL-strings" from 4096 to 8192
[2020-10-29 00:07:43.011 19750M] New upstream server: 1.1.1.1 (1/1024)
[2020-10-29 00:07:43.024 19750M] Resizing "/FTL-queries" from 229376 to 458752
[2020-10-29 00:07:43.030 19750M] Resizing "/FTL-strings" from 8192 to 12288
[2020-10-29 00:07:43.041 19750M] Resizing "/FTL-queries" from 458752 to 688128
[2020-10-29 00:07:43.058 19750M] Resizing "/FTL-queries" from 688128 to 917504
[2020-10-29 00:07:43.068 19750M] Resizing "/FTL-strings" from 12288 to 16384
[2020-10-29 00:07:43.073 19750M] Resizing "/FTL-strings" from 16384 to 20480
[2020-10-29 00:07:43.085 19750M] Resizing "/FTL-queries" from 917504 to 1146880
[2020-10-29 00:07:43.098 19750M] Resizing "/FTL-strings" from 20480 to 24576
[2020-10-29 00:07:43.117 19750M] Resizing "/FTL-queries" from 1146880 to 1376256
[2020-10-29 00:07:43.149 19750M] Resizing "/FTL-queries" from 1376256 to 1605632
[2020-10-29 00:07:43.172 19750M] Resizing "/FTL-strings" from 24576 to 28672
[2020-10-29 00:07:43.181 19750M] Resizing "/FTL-queries" from 1605632 to 1835008
[2020-10-29 00:07:43.211 19750M] Resizing "/FTL-queries" from 1835008 to 2064384
[2020-10-29 00:07:43.243 19750M] Resizing "/FTL-strings" from 28672 to 32768
[2020-10-29 00:07:43.245 19750M] Resizing "/FTL-queries" from 2064384 to 2293760
[2020-10-29 00:07:43.271 19750M] Resizing "/FTL-queries" from 2293760 to 2523136
[2020-10-29 00:07:43.308 19750M] Resizing "/FTL-queries" from 2523136 to 2752512
[2020-10-29 00:07:43.309 19750M] Resizing "/FTL-strings" from 32768 to 36864
[2020-10-29 00:07:43.343 19750M] Resizing "/FTL-queries" from 2752512 to 2981888
[2020-10-29 00:07:43.362 19750M] Resizing "/FTL-strings" from 36864 to 40960
[2020-10-29 00:07:43.387 19750M] Resizing "/FTL-queries" from 2981888 to 3211264
[2020-10-29 00:07:43.448 19750M] Resizing "/FTL-strings" from 40960 to 45056
[2020-10-29 00:07:43.461 19750M] Resizing "/FTL-queries" from 3211264 to 3440640
[2020-10-29 00:07:43.486 19750M] Imported 60502 queries from the long-term database
[2020-10-29 00:07:43.487 19750M] -> Total DNS queries: 60502
[2020-10-29 00:07:43.487 19750M] -> Cached DNS queries: 9369
[2020-10-29 00:07:43.487 19750M] -> Forwarded DNS queries: 46677
[2020-10-29 00:07:43.487 19750M] -> Blocked DNS queries: 4456
[2020-10-29 00:07:43.487 19750M] -> Unknown DNS queries: 0
[2020-10-29 00:07:43.487 19750M] -> Unique domains: 1826
[2020-10-29 00:07:43.487 19750M] -> Unique clients: 50
[2020-10-29 00:07:43.487 19750M] -> Known forward destinations: 2
[2020-10-29 00:07:43.487 19750M] Successfully accessed setupVars.conf
[2020-10-29 00:07:43.493 19761M] PID of FTL process: 19761
[2020-10-29 00:07:43.494 19761/T19762] Listening on port 4711 for incoming IPv4 telnet connections
[2020-10-29 00:07:43.495 19761/T19763] Listening on port 4711 for incoming IPv6 telnet connections
[2020-10-29 00:07:43.495 19761/T19764] Listening on Unix socket
[2020-10-29 00:07:43.496 19761M] Reloading DNS cache
[2020-10-29 00:07:43.496 19761M] Blocking status is enabled
[2020-10-29 00:07:43.530 19761M] INFO: No regex blacklist entries found
[2020-10-29 00:07:43.533 19761M] INFO: No regex whitelist entries found
[2020-10-29 00:07:43.870 19761M] Compiled 0 whitelist and 0 blacklist regex filters for 50 clients in 349.2 msec
[2020-10-29 00:08:00.471 19761/T19768] Resizing "/FTL-strings" from 45056 to 49152
[2020-10-29 00:21:02.171 19761M] Resizing "/FTL-dns-cache" from 4096 to 8192
[2020-10-29 00:27:52.912 19761M] Resizing "/FTL-strings" from 49152 to 53248
[2020-10-29 00:31:44.928 19761M] Resizing "/FTL-queries" from 3440640 to 3670016
[2020-10-29 01:07:38.802 19761M] Shutting down...
[2020-10-29 01:07:38.888 19761M] Finished final database update
[2020-10-29 01:07:38.895 19761M] ########## FTL terminated after 3.595891e+03 s! ##########
[2020-10-29 01:07:40.155 24280M] Using log file /var/log/pihole-FTL.log
[2020-10-29 01:07:40.155 24280M] ########## FTL started! ##########
[2020-10-29 01:07:40.156 24280M] FTL branch: master
[2020-10-29 01:07:40.156 24280M] FTL version: v5.2
[2020-10-29 01:07:40.156 24280M] FTL commit: dbd4a69
[2020-10-29 01:07:40.156 24280M] FTL date: 2020-08-09 22:09:43 +0100
[2020-10-29 01:07:40.156 24280M] FTL user: pihole
[2020-10-29 01:07:40.156 24280M] Compiled for armhf (compiled on CI) using arm-linux-gnueabihf-gcc (Debian 6.3.0-18) 6.3.0 20170516
[2020-10-29 01:07:40.156 24280M] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2020-10-29 01:07:40.156 24280M] SOCKET_LISTENING: only local
[2020-10-29 01:07:40.156 24280M] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2020-10-29 01:07:40.156 24280M] MAXDBDAYS: max age for stored queries is 365 days
[2020-10-29 01:07:40.156 24280M] RESOLVE_IPV6: Resolve IPv6 addresses
[2020-10-29 01:07:40.156 24280M] RESOLVE_IPV4: Resolve IPv4 addresses
[2020-10-29 01:07:40.156 24280M] DBINTERVAL: saving to DB file every minute
[2020-10-29 01:07:40.156 24280M] DBFILE: Using /etc/pihole/pihole-FTL.db
[2020-10-29 01:07:40.156 24280M] MAXLOGAGE: Importing up to 24.0 hours of log data
[2020-10-29 01:07:40.156 24280M] PRIVACYLEVEL: Set to 0
[2020-10-29 01:07:40.156 24280M] IGNORE_LOCALHOST: Show queries from localhost
[2020-10-29 01:07:40.157 24280M] BLOCKINGMODE: Null IPs for blocked domains
[2020-10-29 01:07:40.157 24280M] ANALYZE_ONLY_A_AND_AAAA: Enabled. Analyzing only A and AAAA queries
[2020-10-29 01:07:40.157 24280M] DBIMPORT: Importing history from database
[2020-10-29 01:07:40.157 24280M] PIDFILE: Using /run/pihole-FTL.pid
[2020-10-29 01:07:40.157 24280M] PORTFILE: Using /run/pihole-FTL.port
[2020-10-29 01:07:40.157 24280M] SOCKETFILE: Using /run/pihole/FTL.sock
[2020-10-29 01:07:40.157 24280M] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2020-10-29 01:07:40.157 24280M] MACVENDORDB: Using /etc/pihole/macvendor.db
[2020-10-29 01:07:40.157 24280M] GRAVITYDB: Using /etc/pihole/gravity.db
[2020-10-29 01:07:40.157 24280M] PARSE_ARP_CACHE: Active
[2020-10-29 01:07:40.157 24280M] CNAME_DEEP_INSPECT: Active
[2020-10-29 01:07:40.157 24280M] DELAY_STARTUP: No delay requested.
[2020-10-29 01:07:40.157 24280M] NICE: Set process niceness to -10 (default)
[2020-10-29 01:07:40.157 24280M] BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2020-10-29 01:07:40.157 24280M] NAMES_FROM_NETDB: Enabled, trying to get names from network database
[2020-10-29 01:07:40.158 24280M] Finished config file parsing
[2020-10-29 01:07:40.159 24280M] Database version is 7
[2020-10-29 01:07:40.160 24280M] Database successfully initialized
[2020-10-29 01:07:40.160 24280M] New upstream server: 1.0.0.1 (0/1024)
[2020-10-29 01:07:40.162 24280M] New upstream server: 1.1.1.1 (1/1024)
[2020-10-29 01:07:40.168 24280M] Resizing "/FTL-strings" from 4096 to 8192
[2020-10-29 01:07:40.186 24280M] Resizing "/FTL-queries" from 229376 to 458752
[2020-10-29 01:07:40.192 24280M] Resizing "/FTL-strings" from 8192 to 12288
[2020-10-29 01:07:40.211 24280M] Resizing "/FTL-queries" from 458752 to 688128
[2020-10-29 01:07:40.240 24280M] Resizing "/FTL-strings" from 12288 to 16384
[2020-10-29 01:07:40.241 24280M] Resizing "/FTL-queries" from 688128 to 917504
[2020-10-29 01:07:40.249 24280M] Resizing "/FTL-strings" from 16384 to 20480
[2020-10-29 01:07:40.283 24280M] Resizing "/FTL-strings" from 20480 to 24576
[2020-10-29 01:07:40.285 24280M] Resizing "/FTL-queries" from 917504 to 1146880
[2020-10-29 01:07:40.316 24280M] Resizing "/FTL-queries" from 1146880 to 1376256
[2020-10-29 01:07:40.347 24280M] Resizing "/FTL-queries" from 1376256 to 1605632
[2020-10-29 01:07:40.359 24280M] Resizing "/FTL-strings" from 24576 to 28672
[2020-10-29 01:07:40.378 24280M] Resizing "/FTL-queries" from 1605632 to 1835008
[2020-10-29 01:07:40.409 24280M] Resizing "/FTL-queries" from 1835008 to 2064384
[2020-10-29 01:07:40.428 24280M] Resizing "/FTL-strings" from 28672 to 32768
[2020-10-29 01:07:40.442 24280M] Resizing "/FTL-queries" from 2064384 to 2293760
[2020-10-29 01:07:40.469 24280M] Resizing "/FTL-queries" from 2293760 to 2523136
[2020-10-29 01:07:40.494 24280M] Resizing "/FTL-strings" from 32768 to 36864
[2020-10-29 01:07:40.510 24280M] Resizing "/FTL-queries" from 2523136 to 2752512
[2020-10-29 01:07:40.546 24280M] Resizing "/FTL-queries" from 2752512 to 2981888
[2020-10-29 01:07:40.548 24280M] Resizing "/FTL-strings" from 36864 to 40960
[2020-10-29 01:07:40.601 24280M] Resizing "/FTL-queries" from 2981888 to 3211264
[2020-10-29 01:07:40.634 24280M] Resizing "/FTL-strings" from 40960 to 45056
[2020-10-29 01:07:40.670 24280M] Resizing "/FTL-queries" from 3211264 to 3440640
[2020-10-29 01:07:40.687 24280M] Imported 60566 queries from the long-term database
[2020-10-29 01:07:40.687 24280M] -> Total DNS queries: 60566
[2020-10-29 01:07:40.687 24280M] -> Cached DNS queries: 9396
[2020-10-29 01:07:40.687 24280M] -> Forwarded DNS queries: 46707
[2020-10-29 01:07:40.687 24280M] -> Blocked DNS queries: 4463
[2020-10-29 01:07:40.687 24280M] -> Unknown DNS queries: 0
[2020-10-29 01:07:40.687 24280M] -> Unique domains: 1832
[2020-10-29 01:07:40.687 24280M] -> Unique clients: 50
[2020-10-29 01:07:40.687 24280M] -> Known forward destinations: 2
[2020-10-29 01:07:40.687 24280M] Successfully accessed setupVars.conf
[2020-10-29 01:07:40.693 24282M] PID of FTL process: 24282
[2020-10-29 01:07:40.694 24282/T24283] Listening on port 4711 for incoming IPv4 telnet connections
[2020-10-29 01:07:40.694 24282/T24285] Listening on Unix socket
[2020-10-29 01:07:40.696 24282/T24284] Listening on port 4711 for incoming IPv6 telnet connections
[2020-10-29 01:07:40.696 24282M] Reloading DNS cache
Scuk
October 29, 2020, 11:34am
13
[2020-10-29 01:07:40.696 24282M] Blocking status is enabled
[2020-10-29 01:07:40.731 24282M] INFO: No regex blacklist entries found
[2020-10-29 01:07:40.734 24282M] INFO: No regex whitelist entries found
[2020-10-29 01:07:41.046 24282M] Compiled 0 whitelist and 0 blacklist regex filters for 50 clients in 320.4 msec
[2020-10-29 01:08:00.424 24282/T24288] Resizing "/FTL-strings" from 45056 to 49152
[2020-10-29 01:35:27.786 24282M] Resizing "/FTL-queries" from 3440640 to 3670016
[2020-10-29 01:40:12.569 24282M] Resizing "/FTL-dns-cache" from 4096 to 8192
[2020-10-29 01:52:39.630 24282M] Resizing "/FTL-strings" from 49152 to 53248
[2020-10-29 02:07:43.545 24282M] Shutting down...
[2020-10-29 02:07:43.609 24282M] Finished final database update
[2020-10-29 02:07:43.614 24282M] ########## FTL terminated after 3.603459e+03 s! ##########
[2020-10-29 02:07:44.898 28963M] Using log file /var/log/pihole-FTL.log
[2020-10-29 02:07:44.898 28963M] ########## FTL started! ##########
[2020-10-29 02:07:44.898 28963M] FTL branch: master
[2020-10-29 02:07:44.898 28963M] FTL version: v5.2
[2020-10-29 02:07:44.898 28963M] FTL commit: dbd4a69
[2020-10-29 02:07:44.898 28963M] FTL date: 2020-08-09 22:09:43 +0100
[2020-10-29 02:07:44.898 28963M] FTL user: pihole
[2020-10-29 02:07:44.899 28963M] Compiled for armhf (compiled on CI) using arm-linux-gnueabihf-gcc (Debian 6.3.0-18) 6.3.0 20170516
[2020-10-29 02:07:44.899 28963M] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2020-10-29 02:07:44.899 28963M] SOCKET_LISTENING: only local
[2020-10-29 02:07:44.899 28963M] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2020-10-29 02:07:44.899 28963M] MAXDBDAYS: max age for stored queries is 365 days
[2020-10-29 02:07:44.899 28963M] RESOLVE_IPV6: Resolve IPv6 addresses
[2020-10-29 02:07:44.899 28963M] RESOLVE_IPV4: Resolve IPv4 addresses
[2020-10-29 02:07:44.899 28963M] DBINTERVAL: saving to DB file every minute
[2020-10-29 02:07:44.899 28963M] DBFILE: Using /etc/pihole/pihole-FTL.db
[2020-10-29 02:07:44.899 28963M] MAXLOGAGE: Importing up to 24.0 hours of log data
[2020-10-29 02:07:44.899 28963M] PRIVACYLEVEL: Set to 0
[2020-10-29 02:07:44.899 28963M] IGNORE_LOCALHOST: Show queries from localhost
[2020-10-29 02:07:44.899 28963M] BLOCKINGMODE: Null IPs for blocked domains
[2020-10-29 02:07:44.899 28963M] ANALYZE_ONLY_A_AND_AAAA: Enabled. Analyzing only A and AAAA queries
[2020-10-29 02:07:44.899 28963M] DBIMPORT: Importing history from database
[2020-10-29 02:07:44.900 28963M] PIDFILE: Using /run/pihole-FTL.pid
[2020-10-29 02:07:44.900 28963M] PORTFILE: Using /run/pihole-FTL.port
[2020-10-29 02:07:44.900 28963M] SOCKETFILE: Using /run/pihole/FTL.sock
[2020-10-29 02:07:44.900 28963M] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2020-10-29 02:07:44.900 28963M] MACVENDORDB: Using /etc/pihole/macvendor.db
[2020-10-29 02:07:44.900 28963M] GRAVITYDB: Using /etc/pihole/gravity.db
[2020-10-29 02:07:44.900 28963M] PARSE_ARP_CACHE: Active
[2020-10-29 02:07:44.900 28963M] CNAME_DEEP_INSPECT: Active
[2020-10-29 02:07:44.900 28963M] DELAY_STARTUP: No delay requested.
[2020-10-29 02:07:44.900 28963M] NICE: Set process niceness to -10 (default)
[2020-10-29 02:07:44.900 28963M] BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2020-10-29 02:07:44.900 28963M] NAMES_FROM_NETDB: Enabled, trying to get names from network database
[2020-10-29 02:07:44.900 28963M] Finished config file parsing
[2020-10-29 02:07:44.902 28963M] Database version is 7
[2020-10-29 02:07:44.902 28963M] Database successfully initialized
[2020-10-29 02:07:44.903 28963M] New upstream server: 1.1.1.1 (0/1024)
[2020-10-29 02:07:44.905 28963M] New upstream server: 1.0.0.1 (1/1024)
[2020-10-29 02:07:44.910 28963M] Resizing "/FTL-strings" from 4096 to 8192
[2020-10-29 02:07:44.928 28963M] Resizing "/FTL-queries" from 229376 to 458752
[2020-10-29 02:07:44.946 28963M] Resizing "/FTL-strings" from 8192 to 12288
[2020-10-29 02:07:44.952 28963M] Resizing "/FTL-queries" from 458752 to 688128
[2020-10-29 02:07:44.967 28963M] Resizing "/FTL-strings" from 12288 to 16384
[2020-10-29 02:07:44.974 28963M] Resizing "/FTL-strings" from 16384 to 20480
[2020-10-29 02:07:44.982 28963M] Resizing "/FTL-queries" from 688128 to 917504
[2020-10-29 02:07:44.998 28963M] Resizing "/FTL-strings" from 20480 to 24576
[2020-10-29 02:07:45.013 28963M] Resizing "/FTL-queries" from 917504 to 1146880
[2020-10-29 02:07:45.044 28963M] Resizing "/FTL-queries" from 1146880 to 1376256
[2020-10-29 02:07:45.075 28963M] Resizing "/FTL-queries" from 1376256 to 1605632
[2020-10-29 02:07:45.077 28963M] Resizing "/FTL-strings" from 24576 to 28672
[2020-10-29 02:07:45.104 28963M] Resizing "/FTL-queries" from 1605632 to 1835008
[2020-10-29 02:07:45.139 28963M] Resizing "/FTL-queries" from 1835008 to 2064384
[2020-10-29 02:07:45.146 28963M] Resizing "/FTL-strings" from 28672 to 32768
[2020-10-29 02:07:45.166 28963M] Resizing "/FTL-queries" from 2064384 to 2293760
[2020-10-29 02:07:45.205 28963M] Resizing "/FTL-queries" from 2293760 to 2523136
[2020-10-29 02:07:45.208 28963M] Resizing "/FTL-strings" from 32768 to 36864
[2020-10-29 02:07:45.241 28963M] Resizing "/FTL-queries" from 2523136 to 2752512
[2020-10-29 02:07:45.264 28963M] Resizing "/FTL-strings" from 36864 to 40960
[2020-10-29 02:07:45.289 28963M] Resizing "/FTL-queries" from 2752512 to 2981888
[2020-10-29 02:07:45.355 28963M] Resizing "/FTL-strings" from 40960 to 45056
[2020-10-29 02:07:45.366 28963M] Resizing "/FTL-queries" from 2981888 to 3211264
[2020-10-29 02:07:45.404 28963M] Resizing "/FTL-queries" from 3211264 to 3440640
[2020-10-29 02:07:45.420 28963M] Imported 60488 queries from the long-term database
[2020-10-29 02:07:45.420 28963M] -> Total DNS queries: 60488
[2020-10-29 02:07:45.421 28963M] -> Cached DNS queries: 9401
[2020-10-29 02:07:45.421 28963M] -> Forwarded DNS queries: 46639
[2020-10-29 02:07:45.421 28963M] -> Blocked DNS queries: 4448
[2020-10-29 02:07:45.421 28963M] -> Unknown DNS queries: 0
[2020-10-29 02:07:45.421 28963M] -> Unique domains: 1833
[2020-10-29 02:07:45.421 28963M] -> Unique clients: 49
[2020-10-29 02:07:45.421 28963M] -> Known forward destinations: 2
[2020-10-29 02:07:45.421 28963M] Successfully accessed setupVars.conf
[2020-10-29 02:07:45.427 29042M] PID of FTL process: 29042
[2020-10-29 02:07:45.428 29042/T29046] Listening on Unix socket
[2020-10-29 02:07:45.428 29042/T29044] Listening on port 4711 for incoming IPv4 telnet connections
[2020-10-29 02:07:45.428 29042/T29045] Listening on port 4711 for incoming IPv6 telnet connections
[2020-10-29 02:07:45.428 29042M] Reloading DNS cache
[2020-10-29 02:07:45.429 29042M] Blocking status is enabled
[2020-10-29 02:07:45.470 29042M] INFO: No regex blacklist entries found
[2020-10-29 02:07:45.473 29042M] INFO: No regex whitelist entries found
[2020-10-29 02:07:45.801 29042M] Compiled 0 whitelist and 0 blacklist regex filters for 49 clients in 339.0 msec
[2020-10-29 02:08:00.622 29042/T29049] Resizing "/FTL-strings" from 45056 to 49152
[2020-10-29 02:30:14.637 29042M] Resizing "/FTL-dns-cache" from 4096 to 8192
[2020-10-29 02:32:06.688 29042M] Resizing "/FTL-strings" from 49152 to 53248
[2020-10-29 02:36:41.405 29042M] Resizing "/FTL-queries" from 3440640 to 3670016
[2020-10-29 03:00:01.092 29042M] Resizing "/FTL-dns-cache" from 8192 to 12288
[2020-10-29 03:07:38.758 29042M] Shutting down...
[2020-10-29 03:07:38.817 29042M] Finished final database update
[2020-10-29 03:07:38.824 29042M] ########## FTL terminated after 3.593926e+03 s! ##########
[2020-10-29 03:07:40.013 1062M] Using log file /var/log/pihole-FTL.log
[2020-10-29 03:07:40.013 1062M] ########## FTL started! ##########
[2020-10-29 03:07:40.013 1062M] FTL branch: master
[2020-10-29 03:07:40.013 1062M] FTL version: v5.2
[2020-10-29 03:07:40.013 1062M] FTL commit: dbd4a69
[2020-10-29 03:07:40.013 1062M] FTL date: 2020-08-09 22:09:43 +0100
[2020-10-29 03:07:40.013 1062M] FTL user: pihole
[2020-10-29 03:07:40.013 1062M] Compiled for armhf (compiled on CI) using arm-linux-gnueabihf-gcc (Debian 6.3.0-18) 6.3.0 20170516
[2020-10-29 03:07:40.013 1062M] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2020-10-29 03:07:40.013 1062M] SOCKET_LISTENING: only local
[2020-10-29 03:07:40.013 1062M] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2020-10-29 03:07:40.013 1062M] MAXDBDAYS: max age for stored queries is 365 days[2020-10-29 03:07:40.013 1062M] RESOLVE_IPV6: Resolve IPv6 addresses
[2020-10-29 03:07:40.013 1062M] RESOLVE_IPV4: Resolve IPv4 addresses
[2020-10-29 03:07:40.013 1062M] DBINTERVAL: saving to DB file every minute
[2020-10-29 03:07:40.013 1062M] DBFILE: Using /etc/pihole/pihole-FTL.db
[2020-10-29 03:07:40.014 1062M] MAXLOGAGE: Importing up to 24.0 hours of log data[2020-10-29 03:07:40.014 1062M] PRIVACYLEVEL: Set to 0
[2020-10-29 03:07:40.014 1062M] IGNORE_LOCALHOST: Show queries from localhost
[2020-10-29 03:07:40.014 1062M] BLOCKINGMODE: Null IPs for blocked domains
[2020-10-29 03:07:40.014 1062M] ANALYZE_ONLY_A_AND_AAAA: Enabled. Analyzing only A and AAAA queries
[2020-10-29 03:07:40.014 1062M] DBIMPORT: Importing history from database
[2020-10-29 03:07:40.014 1062M] PIDFILE: Using /run/pihole-FTL.pid
[2020-10-29 03:07:40.014 1062M] PORTFILE: Using /run/pihole-FTL.port
[2020-10-29 03:07:40.014 1062M] SOCKETFILE: Using /run/pihole/FTL.sock
[2020-10-29 03:07:40.014 1062M] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2020-10-29 03:07:40.014 1062M] MACVENDORDB: Using /etc/pihole/macvendor.db
[2020-10-29 03:07:40.014 1062M] GRAVITYDB: Using /etc/pihole/gravity.db
[2020-10-29 03:07:40.014 1062M] PARSE_ARP_CACHE: Active
[2020-10-29 03:07:40.014 1062M] CNAME_DEEP_INSPECT: Active
[2020-10-29 03:07:40.014 1062M] DELAY_STARTUP: No delay requested.
[2020-10-29 03:07:40.014 1062M] NICE: Set process niceness to -10 (default)
[2020-10-29 03:07:40.014 1062M] BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2020-10-29 03:07:40.014 1062M] NAMES_FROM_NETDB: Enabled, trying to get names from network database
[2020-10-29 03:07:40.014 1062M] Finished config file parsing
[2020-10-29 03:07:40.016 1062M] Database version is 7
[2020-10-29 03:07:40.016 1062M] Database successfully initialized
[2020-10-29 03:07:40.016 1062M] New upstream server: 1.1.1.1 (0/1024)
[2020-10-29 03:07:40.017 1062M] New upstream server: 1.0.0.1 (1/1024)
[2020-10-29 03:07:40.019 1062M] Resizing "/FTL-strings" from 4096 to 8192
[2020-10-29 03:07:40.032 1062M] Resizing "/FTL-queries" from 229376 to 458752
[2020-10-29 03:07:40.048 1062M] Resizing "/FTL-strings" from 8192 to 12288
[2020-10-29 03:07:40.052 1062M] Resizing "/FTL-queries" from 458752 to 688128
[2020-10-29 03:07:40.052 1062M] Resizing "/FTL-strings" from 12288 to 16384
[2020-10-29 03:07:40.068 1062M] Resizing "/FTL-strings" from 16384 to 20480
[2020-10-29 03:07:40.081 1062M] Resizing "/FTL-queries" from 688128 to 917504
[2020-10-29 03:07:40.095 1062M] Resizing "/FTL-strings" from 20480 to 24576
[2020-10-29 03:07:40.109 1062M] Resizing "/FTL-queries" from 917504 to 1146880
[2020-10-29 03:07:40.137 1062M] Resizing "/FTL-queries" from 1146880 to 1376256
[2020-10-29 03:07:40.166 1062M] Resizing "/FTL-queries" from 1376256 to 1605632
[2020-10-29 03:07:40.193 1062M] Resizing "/FTL-queries" from 1605632 to 1835008
[2020-10-29 03:07:40.196 1062M] Resizing "/FTL-strings" from 24576 to 28672
[2020-10-29 03:07:40.225 1062M] Resizing "/FTL-queries" from 1835008 to 2064384
[2020-10-29 03:07:40.240 1062M] Resizing "/FTL-strings" from 28672 to 32768
[2020-10-29 03:07:40.252 1062M] Resizing "/FTL-queries" from 2064384 to 2293760
[2020-10-29 03:07:40.291 1062M] Resizing "/FTL-queries" from 2293760 to 2523136
[2020-10-29 03:07:40.296 1062M] Resizing "/FTL-strings" from 32768 to 36864
[2020-10-29 03:07:40.328 1062M] Resizing "/FTL-queries" from 2523136 to 2752512
[2020-10-29 03:07:40.342 1062M] Resizing "/FTL-strings" from 36864 to 40960
[2020-10-29 03:07:40.380 1062M] Resizing "/FTL-queries" from 2752512 to 2981888
[2020-10-29 03:07:40.413 1062M] Resizing "/FTL-strings" from 40960 to 45056
[2020-10-29 03:07:40.443 1062M] Resizing "/FTL-queries" from 2981888 to 3211264
[2020-10-29 03:07:40.462 1062M] Resizing "/FTL-queries" from 3211264 to 3440640
[2020-10-29 03:07:40.478 1062M] Imported 60448 queries from the long-term database
[2020-10-29 03:07:40.479 1062M] -> Total DNS queries: 60448
[2020-10-29 03:07:40.479 1062M] -> Cached DNS queries: 9376
[2020-10-29 03:07:40.479 1062M] -> Forwarded DNS queries: 46609
[2020-10-29 03:07:40.479 1062M] -> Blocked DNS queries: 4463
[2020-10-29 03:07:40.479 1062M] -> Unknown DNS queries: 0
[2020-10-29 03:07:40.479 1062M] -> Unique domains: 1823
[2020-10-29 03:07:40.479 1062M] -> Unique clients: 49
[2020-10-29 03:07:40.479 1062M] -> Known forward destinations: 2
[2020-10-29 03:07:40.479 1062M] Successfully accessed setupVars.conf
[2020-10-29 03:07:40.485 1064M] PID of FTL process: 1064
[2020-10-29 03:07:40.485 1064/T1065] Listening on port 4711 for incoming IPv4 telnet connections
[2020-10-29 03:07:40.485 1064/T1067] Listening on Unix socket
[2020-10-29 03:07:40.486 1064/T1066] Listening on port 4711 for incoming IPv6 telnet connections
[2020-10-29 03:07:40.486 1064M] Reloading DNS cache
[2020-10-29 03:07:40.486 1064M] Blocking status is enabled
[2020-10-29 03:07:40.515 1064M] INFO: No regex blacklist entries found
[2020-10-29 03:07:40.518 1064M] INFO: No regex whitelist entries found
[2020-10-29 03:07:40.838 1064M] Compiled 0 whitelist and 0 blacklist regex filters for 49 clients in 329.6 msec
[2020-10-29 03:08:00.367 1064/T1070] Resizing "/FTL-strings" from 45056 to 49152
[2020-10-29 03:31:46.648 1064M] Resizing "/FTL-dns-cache" from 4096 to 8192
[2020-10-29 03:37:47.452 1064M] Resizing "/FTL-queries" from 3440640 to 3670016
[2020-10-29 04:07:40.023 1064M] Shutting down...
[2020-10-29 04:07:40.096 1064M] Finished final database update
[2020-10-29 04:07:40.101 1064M] ########## FTL terminated after 3.600088e+03 s! ##########
[2020-10-29 04:07:41.303 5594M] Using log file /var/log/pihole-FTL.log
[2020-10-29 04:07:41.303 5594M] ########## FTL started! ##########
[2020-10-29 04:07:41.303 5594M] FTL branch: master
[2020-10-29 04:07:41.303 5594M] FTL version: v5.2
[2020-10-29 04:07:41.303 5594M] FTL commit: dbd4a69
[2020-10-29 04:07:41.303 5594M] FTL date: 2020-08-09 22:09:43 +0100
[2020-10-29 04:07:41.303 5594M] FTL user: pihole
[2020-10-29 04:07:41.303 5594M] Compiled for armhf (compiled on CI) using arm-linux-gnueabihf-gcc (Debian 6.3.0-18) 6.3.0 20170516
[2020-10-29 04:07:41.303 5594M] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2020-10-29 04:07:41.304 5594M] SOCKET_LISTENING: only local
[2020-10-29 04:07:41.304 5594M] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2020-10-29 04:07:41.304 5594M] MAXDBDAYS: max age for stored queries is 365 days[2020-10-29 04:07:41.304 5594M] RESOLVE_IPV6: Resolve IPv6 addresses
[2020-10-29 04:07:41.304 5594M] RESOLVE_IPV4: Resolve IPv4 addresses
[2020-10-29 04:07:41.304 5594M] DBINTERVAL: saving to DB file every minute
[2020-10-29 04:07:41.304 5594M] DBFILE: Using /etc/pihole/pihole-FTL.db
[2020-10-29 04:07:41.304 5594M] MAXLOGAGE: Importing up to 24.0 hours of log data[2020-10-29 04:07:41.304 5594M] PRIVACYLEVEL: Set to 0
[2020-10-29 04:07:41.304 5594M] IGNORE_LOCALHOST: Show queries from localhost
[2020-10-29 04:07:41.304 5594M] BLOCKINGMODE: Null IPs for blocked domains
[2020-10-29 04:07:41.304 5594M] ANALYZE_ONLY_A_AND_AAAA: Enabled. Analyzing only A and AAAA queries
[2020-10-29 04:07:41.304 5594M] DBIMPORT: Importing history from database
[2020-10-29 04:07:41.304 5594M] PIDFILE: Using /run/pihole-FTL.pid
[2020-10-29 04:07:41.304 5594M] PORTFILE: Using /run/pihole-FTL.port
[2020-10-29 04:07:41.304 5594M] SOCKETFILE: Using /run/pihole/FTL.sock
[2020-10-29 04:07:41.304 5594M] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2020-10-29 04:07:41.304 5594M] MACVENDORDB: Using /etc/pihole/macvendor.db
[2020-10-29 04:07:41.304 5594M] GRAVITYDB: Using /etc/pihole/gravity.db
[2020-10-29 04:07:41.304 5594M] PARSE_ARP_CACHE: Active
[2020-10-29 04:07:41.304 5594M] CNAME_DEEP_INSPECT: Active
[2020-10-29 04:07:41.304 5594M] DELAY_STARTUP: No delay requested.
[2020-10-29 04:07:41.305 5594M] NICE: Set process niceness to -10 (default)
[2020-10-29 04:07:41.305 5594M] BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2020-10-29 04:07:41.305 5594M] NAMES_FROM_NETDB: Enabled, trying to get names from network database
[2020-10-29 04:07:41.305 5594M] Finished config file parsing
[2020-10-29 04:07:41.306 5594M] Database version is 7
[2020-10-29 04:07:41.306 5594M] Database successfully initialized
[2020-10-29 04:07:41.306 5594M] New upstream server: 1.1.1.1 (0/1024)
[2020-10-29 04:07:41.308 5594M] New upstream server: 1.0.0.1 (1/1024)
[2020-10-29 04:07:41.310 5594M] Resizing "/FTL-strings" from 4096 to 8192
[2020-10-29 04:07:41.322 5594M] Resizing "/FTL-queries" from 229376 to 458752
[2020-10-29 04:07:41.330 5594M] Resizing "/FTL-strings" from 8192 to 12288
[2020-10-29 04:07:41.335 5594M] Resizing "/FTL-strings" from 12288 to 16384
[2020-10-29 04:07:41.346 5594M] Resizing "/FTL-queries" from 458752 to 688128
[2020-10-29 04:07:41.351 5594M] Resizing "/FTL-strings" from 16384 to 20480
[2020-10-29 04:07:41.374 5594M] Resizing "/FTL-queries" from 688128 to 917504
[2020-10-29 04:07:41.378 5594M] Resizing "/FTL-strings" from 20480 to 24576
[2020-10-29 04:07:41.402 5594M] Resizing "/FTL-queries" from 917504 to 1146880
[2020-10-29 04:07:41.429 5594M] Resizing "/FTL-queries" from 1146880 to 1376256
[2020-10-29 04:07:41.455 5594M] Resizing "/FTL-queries" from 1376256 to 1605632
[2020-10-29 04:07:41.473 5594M] Resizing "/FTL-strings" from 24576 to 28672
[2020-10-29 04:07:41.487 5594M] Resizing "/FTL-queries" from 1605632 to 1835008
[2020-10-29 04:07:41.510 5594M] Resizing "/FTL-queries" from 1835008 to 2064384
[2020-10-29 04:07:41.519 5594M] Resizing "/FTL-strings" from 28672 to 32768
[2020-10-29 04:07:41.547 5594M] Resizing "/FTL-queries" from 2064384 to 2293760
[2020-10-29 04:07:41.576 5594M] Resizing "/FTL-strings" from 32768 to 36864
[2020-10-29 04:07:41.582 5594M] Resizing "/FTL-queries" from 2293760 to 2523136
[2020-10-29 04:07:41.618 5594M] Resizing "/FTL-strings" from 36864 to 40960
[2020-10-29 04:07:41.625 5594M] Resizing "/FTL-queries" from 2523136 to 2752512
[2020-10-29 04:07:41.689 5594M] Resizing "/FTL-strings" from 40960 to 45056
[2020-10-29 04:07:41.695 5594M] Resizing "/FTL-queries" from 2752512 to 2981888
[2020-10-29 04:07:41.728 5594M] Resizing "/FTL-queries" from 2981888 to 3211264
[2020-10-29 04:07:41.747 5594M] Resizing "/FTL-queries" from 3211264 to 3440640
[2020-10-29 04:07:41.761 5594M] Imported 60425 queries from the long-term database
[2020-10-29 04:07:41.762 5594M] -> Total DNS queries: 60425
[2020-10-29 04:07:41.762 5594M] -> Cached DNS queries: 9381
[2020-10-29 04:07:41.762 5594M] -> Forwarded DNS queries: 46602
[2020-10-29 04:07:41.762 5594M] -> Blocked DNS queries: 4442
[2020-10-29 04:07:41.762 5594M] -> Unknown DNS queries: 0
[2020-10-29 04:07:41.762 5594M] -> Unique domains: 1824
[2020-10-29 04:07:41.762 5594M] -> Unique clients: 48
[2020-10-29 04:07:41.762 5594M] -> Known forward destinations: 2
Scuk
14
[2020-10-29 04:07:41.762 5594M] Successfully accessed setupVars.conf
[2020-10-29 04:07:41.768 5596M] PID of FTL process: 5596
[2020-10-29 04:07:41.769 5596/T5597] Listening on port 4711 for incoming IPv4 telnet connections
[2020-10-29 04:07:41.770 5596/T5599] Listening on Unix socket
[2020-10-29 04:07:41.770 5596/T5598] Listening on port 4711 for incoming IPv6 telnet connections
[2020-10-29 04:07:41.771 5596M] Reloading DNS cache
[2020-10-29 04:07:41.771 5596M] Blocking status is enabled
[2020-10-29 04:07:41.807 5596M] INFO: No regex blacklist entries found
[2020-10-29 04:07:41.810 5596M] INFO: No regex whitelist entries found
[2020-10-29 04:07:42.126 5596M] Compiled 0 whitelist and 0 blacklist regex filters for 48 clients in 325.8 msec
[2020-10-29 04:08:00.567 5596/T5602] Resizing "/FTL-strings" from 45056 to 49152
[2020-10-29 04:30:59.960 5596M] Resizing "/FTL-dns-cache" from 4096 to 8192
[2020-10-29 04:33:27.780 5596M] Resizing "/FTL-strings" from 49152 to 53248
[2020-10-29 04:38:14.405 5596M] Resizing "/FTL-queries" from 3440640 to 3670016
[2020-10-29 05:07:41.288 5596M] Shutting down...
[2020-10-29 05:07:41.365 5596M] Finished final database update
[2020-10-29 05:07:41.370 5596M] ########## FTL terminated after 3.600067e+03 s! ##########
[2020-10-29 05:07:42.558 10273M] Using log file /var/log/pihole-FTL.log
[2020-10-29 05:07:42.558 10273M] ########## FTL started! ##########
[2020-10-29 05:07:42.558 10273M] FTL branch: master
[2020-10-29 05:07:42.558 10273M] FTL version: v5.2
[2020-10-29 05:07:42.558 10273M] FTL commit: dbd4a69
[2020-10-29 05:07:42.558 10273M] FTL date: 2020-08-09 22:09:43 +0100
[2020-10-29 05:07:42.558 10273M] FTL user: pihole
[2020-10-29 05:07:42.558 10273M] Compiled for armhf (compiled on CI) using arm-linux-gnueabihf-gcc (Debian 6.3.0-18) 6.3.0 20170516
[2020-10-29 05:07:42.558 10273M] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2020-10-29 05:07:42.558 10273M] SOCKET_LISTENING: only local
[2020-10-29 05:07:42.558 10273M] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2020-10-29 05:07:42.558 10273M] MAXDBDAYS: max age for stored queries is 365 days
[2020-10-29 05:07:42.559 10273M] RESOLVE_IPV6: Resolve IPv6 addresses
[2020-10-29 05:07:42.559 10273M] RESOLVE_IPV4: Resolve IPv4 addresses
[2020-10-29 05:07:42.559 10273M] DBINTERVAL: saving to DB file every minute
[2020-10-29 05:07:42.559 10273M] DBFILE: Using /etc/pihole/pihole-FTL.db
[2020-10-29 05:07:42.559 10273M] MAXLOGAGE: Importing up to 24.0 hours of log data
[2020-10-29 05:07:42.559 10273M] PRIVACYLEVEL: Set to 0
[2020-10-29 05:07:42.559 10273M] IGNORE_LOCALHOST: Show queries from localhost
[2020-10-29 05:07:42.559 10273M] BLOCKINGMODE: Null IPs for blocked domains
[2020-10-29 05:07:42.559 10273M] ANALYZE_ONLY_A_AND_AAAA: Enabled. Analyzing only A and AAAA queries
[2020-10-29 05:07:42.559 10273M] DBIMPORT: Importing history from database
[2020-10-29 05:07:42.559 10273M] PIDFILE: Using /run/pihole-FTL.pid
[2020-10-29 05:07:42.559 10273M] PORTFILE: Using /run/pihole-FTL.port
[2020-10-29 05:07:42.559 10273M] SOCKETFILE: Using /run/pihole/FTL.sock
[2020-10-29 05:07:42.559 10273M] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2020-10-29 05:07:42.559 10273M] MACVENDORDB: Using /etc/pihole/macvendor.db
[2020-10-29 05:07:42.559 10273M] GRAVITYDB: Using /etc/pihole/gravity.db
[2020-10-29 05:07:42.559 10273M] PARSE_ARP_CACHE: Active
[2020-10-29 05:07:42.559 10273M] CNAME_DEEP_INSPECT: Active
[2020-10-29 05:07:42.559 10273M] DELAY_STARTUP: No delay requested.
[2020-10-29 05:07:42.559 10273M] NICE: Set process niceness to -10 (default)
[2020-10-29 05:07:42.559 10273M] BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2020-10-29 05:07:42.559 10273M] NAMES_FROM_NETDB: Enabled, trying to get names from network database
[2020-10-29 05:07:42.560 10273M] Finished config file parsing
[2020-10-29 05:07:42.561 10273M] Database version is 7
[2020-10-29 05:07:42.561 10273M] Database successfully initialized
[2020-10-29 05:07:42.561 10273M] New upstream server: 1.1.1.1 (0/1024)
[2020-10-29 05:07:42.562 10273M] New upstream server: 1.0.0.1 (1/1024)
[2020-10-29 05:07:42.565 10273M] Resizing "/FTL-strings" from 4096 to 8192
[2020-10-29 05:07:42.578 10273M] Resizing "/FTL-strings" from 8192 to 12288
[2020-10-29 05:07:42.580 10273M] Resizing "/FTL-queries" from 229376 to 458752
[2020-10-29 05:07:42.582 10273M] Resizing "/FTL-strings" from 12288 to 16384
[2020-10-29 05:07:42.599 10273M] Resizing "/FTL-strings" from 16384 to 20480
[2020-10-29 05:07:42.608 10273M] Resizing "/FTL-queries" from 458752 to 688128
[2020-10-29 05:07:42.627 10273M] Resizing "/FTL-strings" from 20480 to 24576
[2020-10-29 05:07:42.635 10273M] Resizing "/FTL-queries" from 688128 to 917504
[2020-10-29 05:07:42.662 10273M] Resizing "/FTL-queries" from 917504 to 1146880
[2020-10-29 05:07:42.690 10273M] Resizing "/FTL-queries" from 1146880 to 1376256
[2020-10-29 05:07:42.717 10273M] Resizing "/FTL-queries" from 1376256 to 1605632
[2020-10-29 05:07:42.721 10273M] Resizing "/FTL-strings" from 24576 to 28672
[2020-10-29 05:07:42.748 10273M] Resizing "/FTL-queries" from 1605632 to 1835008
[2020-10-29 05:07:42.768 10273M] Resizing "/FTL-strings" from 28672 to 32768
[2020-10-29 05:07:42.774 10273M] Resizing "/FTL-queries" from 1835008 to 2064384
[2020-10-29 05:07:42.813 10273M] Resizing "/FTL-queries" from 2064384 to 2293760
[2020-10-29 05:07:42.826 10273M] Resizing "/FTL-strings" from 32768 to 36864
[2020-10-29 05:07:42.848 10273M] Resizing "/FTL-queries" from 2293760 to 2523136
[2020-10-29 05:07:42.871 10273M] Resizing "/FTL-strings" from 36864 to 40960
[2020-10-29 05:07:42.900 10273M] Resizing "/FTL-queries" from 2523136 to 2752512
[2020-10-29 05:07:42.938 10273M] Resizing "/FTL-strings" from 40960 to 45056
[2020-10-29 05:07:42.965 10273M] Resizing "/FTL-queries" from 2752512 to 2981888
[2020-10-29 05:07:42.985 10273M] Resizing "/FTL-queries" from 2981888 to 3211264
[2020-10-29 05:07:43.006 10273M] Resizing "/FTL-queries" from 3211264 to 3440640
[2020-10-29 05:07:43.019 10273M] Imported 60352 queries from the long-term database
[2020-10-29 05:07:43.020 10273M] -> Total DNS queries: 60352
[2020-10-29 05:07:43.020 10273M] -> Cached DNS queries: 9345
[2020-10-29 05:07:43.020 10273M] -> Forwarded DNS queries: 46585
[2020-10-29 05:07:43.020 10273M] -> Blocked DNS queries: 4422
[2020-10-29 05:07:43.020 10273M] -> Unknown DNS queries: 0
[2020-10-29 05:07:43.020 10273M] -> Unique domains: 1828
[2020-10-29 05:07:43.020 10273M] -> Unique clients: 48
[2020-10-29 05:07:43.020 10273M] -> Known forward destinations: 2
[2020-10-29 05:07:43.020 10273M] Successfully accessed setupVars.conf
[2020-10-29 05:07:43.026 10275M] PID of FTL process: 10275
[2020-10-29 05:07:43.026 10275/T10276] Listening on port 4711 for incoming IPv4 telnet connections
[2020-10-29 05:07:43.027 10275/T10277] Listening on port 4711 for incoming IPv6 telnet connections
[2020-10-29 05:07:43.027 10275/T10278] Listening on Unix socket
[2020-10-29 05:07:43.027 10275M] Reloading DNS cache
[2020-10-29 05:07:43.027 10275M] Blocking status is enabled
[2020-10-29 05:07:43.065 10275M] INFO: No regex blacklist entries found
[2020-10-29 05:07:43.069 10275M] INFO: No regex whitelist entries found
[2020-10-29 05:07:43.385 10275M] Compiled 0 whitelist and 0 blacklist regex filters for 48 clients in 325.1 msec
[2020-10-29 05:08:00.249 10275/T10281] Resizing "/FTL-strings" from 45056 to 49152
[2020-10-29 05:32:31.859 10275M] Resizing "/FTL-dns-cache" from 4096 to 8192
[2020-10-29 05:39:57.497 10275M] Resizing "/FTL-queries" from 3440640 to 3670016
[2020-10-29 05:41:27.452 10275M] Resizing "/FTL-strings" from 49152 to 53248
[2020-10-29 06:07:37.953 10275M] Shutting down...
[2020-10-29 06:07:38.102 10275M] Finished final database update
[2020-10-29 06:07:38.111 10275M] ########## FTL terminated after 3.595553e+03 s! ##########
[2020-10-29 06:07:39.229 14741M] Using log file /var/log/pihole-FTL.log
[2020-10-29 06:07:39.229 14741M] ########## FTL started! ##########
[2020-10-29 06:07:39.229 14741M] FTL branch: master
[2020-10-29 06:07:39.229 14741M] FTL version: v5.2
[2020-10-29 06:07:39.230 14741M] FTL commit: dbd4a69
[2020-10-29 06:07:39.230 14741M] FTL date: 2020-08-09 22:09:43 +0100
[2020-10-29 06:07:39.230 14741M] FTL user: pihole
[2020-10-29 06:07:39.230 14741M] Compiled for armhf (compiled on CI) using arm-linux-gnueabihf-gcc (Debian 6.3.0-18) 6.3.0 20170516
[2020-10-29 06:07:39.230 14741M] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2020-10-29 06:07:39.230 14741M] SOCKET_LISTENING: only local
[2020-10-29 06:07:39.230 14741M] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2020-10-29 06:07:39.230 14741M] MAXDBDAYS: max age for stored queries is 365 days
[2020-10-29 06:07:39.230 14741M] RESOLVE_IPV6: Resolve IPv6 addresses
[2020-10-29 06:07:39.230 14741M] RESOLVE_IPV4: Resolve IPv4 addresses
[2020-10-29 06:07:39.230 14741M] DBINTERVAL: saving to DB file every minute
[2020-10-29 06:07:39.230 14741M] DBFILE: Using /etc/pihole/pihole-FTL.db
[2020-10-29 06:07:39.230 14741M] MAXLOGAGE: Importing up to 24.0 hours of log data
[2020-10-29 06:07:39.230 14741M] PRIVACYLEVEL: Set to 0
[2020-10-29 06:07:39.230 14741M] IGNORE_LOCALHOST: Show queries from localhost
[2020-10-29 06:07:39.230 14741M] BLOCKINGMODE: Null IPs for blocked domains
[2020-10-29 06:07:39.230 14741M] ANALYZE_ONLY_A_AND_AAAA: Enabled. Analyzing only A and AAAA queries
[2020-10-29 06:07:39.230 14741M] DBIMPORT: Importing history from database
[2020-10-29 06:07:39.230 14741M] PIDFILE: Using /run/pihole-FTL.pid
[2020-10-29 06:07:39.230 14741M] PORTFILE: Using /run/pihole-FTL.port
[2020-10-29 06:07:39.231 14741M] SOCKETFILE: Using /run/pihole/FTL.sock
[2020-10-29 06:07:39.231 14741M] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2020-10-29 06:07:39.231 14741M] MACVENDORDB: Using /etc/pihole/macvendor.db
[2020-10-29 06:07:39.231 14741M] GRAVITYDB: Using /etc/pihole/gravity.db
[2020-10-29 06:07:39.231 14741M] PARSE_ARP_CACHE: Active
[2020-10-29 06:07:39.231 14741M] CNAME_DEEP_INSPECT: Active
[2020-10-29 06:07:39.231 14741M] DELAY_STARTUP: No delay requested.
[2020-10-29 06:07:39.231 14741M] NICE: Set process niceness to -10 (default)
[2020-10-29 06:07:39.231 14741M] BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2020-10-29 06:07:39.231 14741M] NAMES_FROM_NETDB: Enabled, trying to get names from network database
[2020-10-29 06:07:39.231 14741M] Finished config file parsing
[2020-10-29 06:07:39.232 14741M] Database version is 7
[2020-10-29 06:07:39.232 14741M] Database successfully initialized
[2020-10-29 06:07:39.233 14741M] New upstream server: 1.0.0.1 (0/1024)
[2020-10-29 06:07:39.236 14741M] New upstream server: 1.1.1.1 (1/1024)
[2020-10-29 06:07:39.236 14741M] Resizing "/FTL-strings" from 4096 to 8192
[2020-10-29 06:07:39.244 14741M] Resizing "/FTL-strings" from 8192 to 12288
[2020-10-29 06:07:39.249 14741M] Resizing "/FTL-strings" from 12288 to 16384
[2020-10-29 06:07:39.259 14741M] Resizing "/FTL-queries" from 229376 to 458752
[2020-10-29 06:07:39.267 14741M] Resizing "/FTL-strings" from 16384 to 20480
[2020-10-29 06:07:39.288 14741M] Resizing "/FTL-queries" from 458752 to 688128
[2020-10-29 06:07:39.303 14741M] Resizing "/FTL-strings" from 20480 to 24576
[2020-10-29 06:07:39.317 14741M] Resizing "/FTL-queries" from 688128 to 917504
[2020-10-29 06:07:39.346 14741M] Resizing "/FTL-queries" from 917504 to 1146880
[2020-10-29 06:07:39.375 14741M] Resizing "/FTL-queries" from 1146880 to 1376256
[2020-10-29 06:07:39.398 14741M] Resizing "/FTL-strings" from 24576 to 28672
[2020-10-29 06:07:39.409 14741M] Resizing "/FTL-queries" from 1376256 to 1605632
[2020-10-29 06:07:39.433 14741M] Resizing "/FTL-queries" from 1605632 to 1835008
[2020-10-29 06:07:39.447 14741M] Resizing "/FTL-strings" from 28672 to 32768
[2020-10-29 06:07:39.471 14741M] Resizing "/FTL-queries" from 1835008 to 2064384
[2020-10-29 06:07:39.507 14741M] Resizing "/FTL-queries" from 2064384 to 2293760
[2020-10-29 06:07:39.508 14741M] Resizing "/FTL-strings" from 32768 to 36864
[2020-10-29 06:07:39.551 14741M] Resizing "/FTL-queries" from 2293760 to 2523136
[2020-10-29 06:07:39.555 14741M] Resizing "/FTL-strings" from 36864 to 40960
[2020-10-29 06:07:39.623 14741M] Resizing "/FTL-queries" from 2523136 to 2752512
[2020-10-29 06:07:39.624 14741M] Resizing "/FTL-strings" from 40960 to 45056
[2020-10-29 06:07:39.658 14741M] Resizing "/FTL-queries" from 2752512 to 2981888
[2020-10-29 06:07:39.677 14741M] Resizing "/FTL-queries" from 2981888 to 3211264
[2020-10-29 06:07:39.698 14741M] Resizing "/FTL-queries" from 3211264 to 3440640
[2020-10-29 06:07:39.713 14741M] Imported 60353 queries from the long-term database
[2020-10-29 06:07:39.714 14741M] -> Total DNS queries: 60353
[2020-10-29 06:07:39.714 14741M] -> Cached DNS queries: 9369
[2020-10-29 06:07:39.714 14741M] -> Forwarded DNS queries: 46574
[2020-10-29 06:07:39.714 14741M] -> Blocked DNS queries: 4410
[2020-10-29 06:07:39.714 14741M] -> Unknown DNS queries: 0
[2020-10-29 06:07:39.714 14741M] -> Unique domains: 1837
[2020-10-29 06:07:39.714 14741M] -> Unique clients: 48
[2020-10-29 06:07:39.714 14741M] -> Known forward destinations: 2
[2020-10-29 06:07:39.714 14741M] Successfully accessed setupVars.conf
[2020-10-29 06:07:39.719 14794M] PID of FTL process: 14794
[2020-10-29 06:07:39.720 14794/T14795] Listening on port 4711 for incoming IPv4 telnet connections
[2020-10-29 06:07:39.720 14794/T14797] Listening on Unix socket
[2020-10-29 06:07:39.723 14794/T14796] Listening on port 4711 for incoming IPv6 telnet connections
[2020-10-29 06:07:39.723 14794M] Reloading DNS cache
[2020-10-29 06:07:39.723 14794M] Blocking status is enabled
[2020-10-29 06:07:39.751 14794M] INFO: No regex blacklist entries found
[2020-10-29 06:07:39.754 14794M] INFO: No regex whitelist entries found
[2020-10-29 06:07:40.051 14794M] Compiled 0 whitelist and 0 blacklist regex filters for 48 clients in 306.2 msec
[2020-10-29 06:07:44.186 14794M] Resizing "/FTL-strings" from 45056 to 49152
[2020-10-29 06:29:47.642 14794M] Resizing "/FTL-strings" from 49152 to 53248
[2020-10-29 06:29:49.421 14794M] Resizing "/FTL-dns-cache" from 4096 to 8192
[2020-10-29 06:37:20.087 14794M] Resizing "/FTL-queries" from 3440640 to 3670016
[2020-10-29 06:52:53.893 14794M] Resizing "/FTL-dns-cache" from 8192 to 12288
[2020-10-29 06:53:24.197 14794M] Resizing "/FTL-strings" from 53248 to 57344
[2020-10-29 06:54:00.440 14794M] Resizing "/FTL-dns-cache" from 12288 to 16384
[2020-10-29 06:54:01.527 14794M] Resizing "/FTL-strings" from 57344 to 61440
[2020-10-29 06:54:42.498 14794M] Resizing "/FTL-strings" from 61440 to 65536
[2020-10-29 06:54:44.608 14794M] Resizing "/FTL-dns-cache" from 16384 to 20480
[2020-10-29 06:59:22.145 14794M] Resizing "/FTL-strings" from 65536 to 69632
[2020-10-29 07:06:40.630 14794M] Resizing "/FTL-dns-cache" from 20480 to 24576
[2020-10-29 07:07:41.028 14794M] Shutting down...
[2020-10-29 07:07:41.089 14794M] Finished final database update
[2020-10-29 07:07:41.095 14794M] ########## FTL terminated after 3.601865e+03 s! ##########
[2020-10-29 07:07:42.282 19590M] Using log file /var/log/pihole-FTL.log
[2020-10-29 07:07:42.282 19590M] ########## FTL started! ##########
[2020-10-29 07:07:42.282 19590M] FTL branch: master
[2020-10-29 07:07:42.282 19590M] FTL version: v5.2
[2020-10-29 07:07:42.282 19590M] FTL commit: dbd4a69
[2020-10-29 07:07:42.283 19590M] FTL date: 2020-08-09 22:09:43 +0100
[2020-10-29 07:07:42.283 19590M] FTL user: pihole
[2020-10-29 07:07:42.283 19590M] Compiled for armhf (compiled on CI) using arm-linux-gnueabihf-gcc (Debian 6.3.0-18) 6.3.0 20170516
[2020-10-29 07:07:42.283 19590M] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2020-10-29 07:07:42.283 19590M] SOCKET_LISTENING: only local
[2020-10-29 07:07:42.283 19590M] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2020-10-29 07:07:42.283 19590M] MAXDBDAYS: max age for stored queries is 365 days
[2020-10-29 07:07:42.283 19590M] RESOLVE_IPV6: Resolve IPv6 addresses
[2020-10-29 07:07:42.283 19590M] RESOLVE_IPV4: Resolve IPv4 addresses
[2020-10-29 07:07:42.283 19590M] DBINTERVAL: saving to DB file every minute
[2020-10-29 07:07:42.283 19590M] DBFILE: Using /etc/pihole/pihole-FTL.db
[2020-10-29 07:07:42.283 19590M] MAXLOGAGE: Importing up to 24.0 hours of log data
[2020-10-29 07:07:42.283 19590M] PRIVACYLEVEL: Set to 0
[2020-10-29 07:07:42.283 19590M] IGNORE_LOCALHOST: Show queries from localhost
[2020-10-29 07:07:42.283 19590M] BLOCKINGMODE: Null IPs for blocked domains
[2020-10-29 07:07:42.283 19590M] ANALYZE_ONLY_A_AND_AAAA: Enabled. Analyzing only A and AAAA queries
[2020-10-29 07:07:42.283 19590M] DBIMPORT: Importing history from database
[2020-10-29 07:07:42.283 19590M] PIDFILE: Using /run/pihole-FTL.pid
[2020-10-29 07:07:42.284 19590M] PORTFILE: Using /run/pihole-FTL.port
[2020-10-29 07:07:42.284 19590M] SOCKETFILE: Using /run/pihole/FTL.sock
[2020-10-29 07:07:42.284 19590M] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2020-10-29 07:07:42.284 19590M] MACVENDORDB: Using /etc/pihole/macvendor.db
[2020-10-29 07:07:42.284 19590M] GRAVITYDB: Using /etc/pihole/gravity.db
[2020-10-29 07:07:42.284 19590M] PARSE_ARP_CACHE: Active
[2020-10-29 07:07:42.284 19590M] CNAME_DEEP_INSPECT: Active
[2020-10-29 07:07:42.284 19590M] DELAY_STARTUP: No delay requested.
[2020-10-29 07:07:42.284 19590M] NICE: Set process niceness to -10 (default)
[2020-10-29 07:07:42.284 19590M] BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2020-10-29 07:07:42.284 19590M] NAMES_FROM_NETDB: Enabled, trying to get names from network database
[2020-10-29 07:07:42.284 19590M] Finished config file parsing
[2020-10-29 07:07:42.286 19590M] Database version is 7
[2020-10-29 07:07:42.286 19590M] Database successfully initialized
[2020-10-29 07:07:42.286 19590M] New upstream server: 1.1.1.1 (0/1024)
[2020-10-29 07:07:42.287 19590M] New upstream server: 1.0.0.1 (1/1024)
[2020-10-29 07:07:42.290 19590M] Resizing "/FTL-strings" from 4096 to 8192
[2020-10-29 07:07:42.298 19590M] Resizing "/FTL-strings" from 8192 to 12288
[2020-10-29 07:07:42.306 19590M] Resizing "/FTL-strings" from 12288 to 16384
[2020-10-29 07:07:42.309 19590M] Resizing "/FTL-queries" from 229376 to 458752
[2020-10-29 07:07:42.331 19590M] Resizing "/FTL-queries" from 458752 to 688128
[2020-10-29 07:07:42.354 19590M] Resizing "/FTL-queries" from 688128 to 917504
[2020-10-29 07:07:42.355 19590M] Resizing "/FTL-strings" from 16384 to 20480
[2020-10-29 07:07:42.378 19590M] Resizing "/FTL-queries" from 917504 to 1146880
[2020-10-29 07:07:42.402 19590M] Resizing "/FTL-queries" from 1146880 to 1376256
[2020-10-29 07:07:42.405 19590M] Resizing "/FTL-strings" from 20480 to 24576
[2020-10-29 07:07:42.433 19590M] Resizing "/FTL-queries" from 1376256 to 1605632
[2020-10-29 07:07:42.450 19590M] Resizing "/FTL-strings" from 24576 to 28672
[2020-10-29 07:07:42.464 19590M] Resizing "/FTL-queries" from 1605632 to 1835008
[2020-10-29 07:07:42.501 19590M] Resizing "/FTL-queries" from 1835008 to 2064384
[2020-10-29 07:07:42.502 19590M] Resizing "/FTL-strings" from 28672 to 32768
[2020-10-29 07:07:42.538 19590M] Resizing "/FTL-queries" from 2064384 to 2293760
[2020-10-29 07:07:42.545 19590M] Resizing "/FTL-strings" from 32768 to 36864
[2020-10-29 07:07:42.597 19590M] Resizing "/FTL-queries" from 2293760 to 2523136
[2020-10-29 07:07:42.613 19590M] Resizing "/FTL-strings" from 36864 to 40960
[2020-10-29 07:07:42.644 19590M] Resizing "/FTL-queries" from 2523136 to 2752512
[2020-10-29 07:07:42.666 19590M] Resizing "/FTL-queries" from 2752512 to 2981888
[2020-10-29 07:07:42.688 19590M] Resizing "/FTL-queries" from 2981888 to 3211264
[2020-10-29 07:07:42.702 19590M] Resizing "/FTL-strings" from 40960 to 45056
[2020-10-29 07:07:42.710 19590M] Resizing "/FTL-queries" from 3211264 to 3440640
[2020-10-29 07:07:42.731 19590M] Resizing "/FTL-strings" from 45056 to 49152
[2020-10-29 07:07:42.739 19590M] Imported 60649 queries from the long-term database
[2020-10-29 07:07:42.740 19590M] -> Total DNS queries: 60649
[2020-10-29 07:07:42.740 19590M] -> Cached DNS queries: 9457
[2020-10-29 07:07:42.740 19590M] -> Forwarded DNS queries: 46796
[2020-10-29 07:07:42.740 19590M] -> Blocked DNS queries: 4396
[2020-10-29 07:07:42.740 19590M] -> Unknown DNS queries: 0
[2020-10-29 07:07:42.740 19590M] -> Unique domains: 1923
[2020-10-29 07:07:42.740 19590M] -> Unique clients: 48
[2020-10-29 07:07:42.740 19590M] -> Known forward destinations: 2
[2020-10-29 07:07:42.740 19590M] Successfully accessed setupVars.conf
[2020-10-29 07:07:42.746 19641M] PID of FTL process: 19641
[2020-10-29 07:07:42.747 19641/T19644] Listening on Unix socket
[2020-10-29 07:07:42.747 19641/T19642] Listening on port 4711 for incoming IPv4 telnet connections
[2020-10-29 07:07:42.747 19641/T19643] Listening on port 4711 for incoming IPv6 telnet connections
[2020-10-29 07:07:42.747 19641M] Reloading DNS cache
[2020-10-29 07:07:42.747 19641M] Blocking status is enabled
[2020-10-29 07:07:42.773 19641M] INFO: No regex blacklist entries found
[2020-10-29 07:07:42.776 19641M] INFO: No regex whitelist entries found
[2020-10-29 07:07:43.073 19641M] Compiled 0 whitelist and 0 blacklist regex filters for 48 clients in 306.5 msec
[2020-10-29 07:13:09.632 19641M] Resizing "/FTL-strings" from 49152 to 53248
[2020-10-29 07:21:35.444 19641M] Resizing "/FTL-dns-cache" from 4096 to 8192
pi@pihole:~ $
Every time you see a line that says FTL terminated
that indicates FTL has been stopped.
Run
grep "Shutting down" /var/log/pihole-FTL.log
Scuk
October 29, 2020, 7:17pm
17
pi@pihole:~ $ grep "Shutting down" /var/log/pihole-FTL.log
[2020-10-29 08:07:40.769 19641M] Shutting down...
[2020-10-29 09:07:37.096 25613M] Shutting down...
[2020-10-29 10:06:26.038 30078M] Shutting down...
[2020-10-29 11:06:26.699 5541M] Shutting down...
[2020-10-29 12:06:24.191 13650M] Shutting down...
[2020-10-29 13:06:25.375 21544M] Shutting down...
[2020-10-29 14:06:28.309 29430M] Shutting down...
[2020-10-29 15:06:24.581 4897M] Shutting down...
Scuk
October 29, 2020, 7:20pm
19
I see that. Now... any idea how to fix that? I'm pretty novice with all this. Learning as I go. Thanks for the help!
Looks like you're running a script or a cronjob that is restarting Pi-hole once an hour.
Scuk
October 29, 2020, 7:30pm
21
This is the only crontab I've created. Could this cause it? It's set to once an hour.
0 */1 * * * sudo /home/pi/youTube_ads_4_pi-hole/youtube.sh >/dev/null
Would it make sense to add this?
0 */1 * * * sudo pihole -g
0 */1 * * * sudo pihole restartdns
