Delete all AD's and block the websites listed in blacklist only.
It never blocks ADs, for example this website (www.3sk.tv), you can see ads all over the webpage but when I use chrome extensions such as ADBlock or Ublock, they are removed. PiHole won't remove the ADs for a lot of sites, and it just randomly blocks my access from a lot of websites, while I'm surfing the internet, to access the websites, I must keep adding the websites I want to access one by one in the whitelist. It's annoying.
::: Beginning Pi-hole debug at Tue Oct 24 20:03:03 UTC 2017!
::: This process collects information from your Pi-hole, and optionally uploads
::: it to a unique and random directory on tricorder.pi-hole.net.
::: NOTE: All log files auto-delete after 48 hours and ONLY the Pi-hole developers
::: can access your data via the given token. We have taken these extra steps to
::: secure your data and will work to further reduce any personal information gathered.
::: Please read and note any issues, and follow any directions advised during this process.
::: ---= Detecting Installed Package Versions:
::: Pi-hole: v3.1.4 (master:v3.1.4-0-gb0ecedd)
::: Pi-hole Dashboard: v3.1 (master:v3.1-0-gf204b71)
::: lighttpd/1.4.45
::: PHP 7.0.19-1 (cli) (built: May 11 2017 14:04:47) ( NTS )
::: ---= Detecting existence of /etc/pihole/setupVars.conf:
::: File exists, parsing...done and was successfully sourced
::: ---= Detecting installed OS Distribution
::: ---= Checking processor variety
::: ---= Checking IPv6 Stack
::: IPv6 addresses located on eth0
::: No gateway detected.
::: ---= Checking IPv4 Stack
::: IPv4 addresses located on eth0
::: Pinging default IPv4 gateway: ::: Gateway responded.
::: Pinging Internet via IPv4: ::: Query responded.
::: ---= Daemon Process Information
::: Checking http port for lighttpd listener.
::: Correctly configured.
::: Checking domain port for dnsmasq listener.
::: Checking 4711 port for pihole-FTL listener.
::: ---= Processes Check
::: Logging status of lighttpd, dnsmasq and pihole-FTL...
::: ---= Resolver Functions Check (IPv4)
::: ---= Resolver Functions Check (IPv6)
::: Checking for necessary lighttpd files.
::: ---= Detecting existence of /etc/lighttpd/lighttpd.conf:
::: ---= Detecting existence of /var/log/lighttpd/error.log:
::: ---= Detecting existence of /etc/dnsmasq.conf:
::: ---= Detecting contents of /etc/dnsmasq.d/*:
::: ---= File /etc/dnsmasq.d/01-pihole.conf found
::: Parsing...done
::: ---= File /etc/dnsmasq.d/README found
::: Parsing...done
::: ---= Detecting existence of /etc/pihole/whitelist.txt:
::: ---= Detecting existence of /etc/pihole/blacklist.txt:
::: ---= Detecting existence of /etc/pihole/adlists.list:
::: ---= Analyzing gravity.list
::: ---= Analyzing pihole.log
::: ---= Analyzing pihole-FTL.log
::: --= User Action Required =--
::: Try loading a site that you are having trouble with now from a client web browser..
::: (Press CTRL+C to finish logging.)
::: ---= pihole.log
::: Logging will automatically teminate in 60 seconds
::: 60 seconds left.
::: 55 seconds left.
::: 50 seconds left.
::: 45 seconds left.
::: 40 seconds left.
::: 35 seconds left.
::: 30 seconds left.
::: 25 seconds left.
::: 20 seconds left.
::: 15 seconds left.
::: 10 seconds left.
::: 5 seconds left.
::: Finshed debugging!
::: The debug log can be uploaded to tricorder.pi-hole.net for sharing with developers only.
::: Debug script running in automated mode, uploading log to tricorder...
::: ---=== Your debug token is : z84mc0x1z2 Please make a note of it. ===---
::: Contact the Pi-hole team with your token for assistance.
::: Thank you.
::: A local copy of the Debug log can be found at : /var/log/pihole_debug.log
