Can you even ping 192.168.1.12?
I Get This When I Ping The 192.168.1.12
Pinging 192.168.1.12 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.1.12:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
This doesn't look like it's related to Pi-hole:
A failing ping
would suggest a network issue, which seems in line with your ERR_ADDR_UNREACHABLE message from your earlier screenshot from one of your clients.
Assuming a 192.168.1.0/24
subnet, at least your Windows client at 192.168.1.11
seems to be on the same network as your Pi-hole host machine at 192.168.1.12
You should check your router for possible reasons why it wouldn't route packets to your Pi-hole machine.
Maybe you've assigned that .12
IP address twice, or your subnet mask is not a /24
, or your router has enabled a feature like wifi client isolation, preventing wifi clients from being able to communicate with other machines in your network.
Yes,wifi client isolatotion was on after all,that was the issue, now the page works, thank you all guys, your awesome
